Running the Autoprocess VTAs/VTIs Job
The Autoprocess VTAs/VTIs job automatically handles many of the changes required by the new dictionary version's impact on your VTAs and VTIs. The job inserts affected VTAs and VTIs into the predictionary tables if they are not already there, so that it can operate on them and you can too, in the Maintain Predictionary VTAs/VTIs window. (The VTAs and VTIs remain in production as well.) The job makes the following changes:
The job reclassifies VTAs and VTIs whose dictionary term has been moved from one coding level to another.
The job declassifies VTAs and VTIs whose dictionary term has been deleted
If you set the Reclassify Direct Matches? parameter to Yes, the job reclassifies verbatim terms to new dictionary terms that are a direct match.
To run the Autoprocess VTAs/VTIs job, do the following:
Parent topic: Upgrading to a New Dictionary Version
