Running Dictionary Upgrade Reports
TMS includes the following dictionary upgrade reports:
- Dictionary Impacts Report
- Predict VTA/VTI Report
- Site Impacts Report
- Omission Impacts Report
- Cross Dictionary Impacts Report
Parent topic: Upgrading to a New Dictionary Version
The Dictionary Impacts Report displays all the global VTAs, VTIs, and current omissions that will be affected by a base dictionary upgrade. You can run the Dictionary Impacts Report before or after the Autoprocess VTAs/VTIs job. You can run this report only on a base dictionary and in the global domain.
The report includes the following sections:
The Assigned Dictionary Term Will Be Deleted for the Following VTAs/VTIs If the new dictionary version deletes dictionary terms to which VTAs or VTIs are currently classified, you must reclassify the affected terms.
Each row of the report displays one verbatim term that will be declassified, with the following information:
The affected dictionary
The affected domain
The verbatim term
The classification type: VTA or VTI
The VTA or VTI ID
The dictionary term and its ID
The Assigned Dictionary Term Will Be Updated for the Following VTAs/VTIs If the new dictionary version modifies some dictionary terms to which VTAs or VTIs are currently classified, you may want to reclassify the affected terms.
Each row of the report displays one affected verbatim term, with the following information:
The affected domain
The verbatim term
The VTA or VTI ID
The approval status of the existing VTA or VTI
There Will Be a Direct Match for the Following VTAs If the new dictionary version includes new terms that are a direct match to VTAs that are currently to nonmatching dictionary terms, you may want to reclassify the verbatim terms to the new, matching dictionary terms. (You can do this automatically by running the Autoprocess VTAs/VTIs job with Reclassify Direct Matches set to Yes.)
If any dictionary/domain combination allows classification to nonapproved dictionary terms, this report includes verbatim terms in that dictionary domain that are a direct match to both approved and nonapproved dictionary terms. This could be the case in MedDRA-J, for example. See Assigning a Dictionary to a Domain for more information.
The affected domain
The verbatim term
The new dictionary term that is a direct match
There Will Be a Direct Match for the Following VTIs If the new dictionary version includes new terms that are a direct match to VTIs that are currently to nonmatching dictionary terms, you may want to reclassify the verbatim terms to the new, matching dictionary terms. (You can do this automatically by running the Autoprocess VTAs/VTIs job with Reclassify Direct Matches set to Yes.)
If the new, matching dictionary term is unique, it may be a candidate for a VTA. If it is not unique, any auxiliary information is not processed. You must manually classify the VTI if you are using auxiliary information.
The affected domain
The verbatim term
The approval status of the existing VTI
The new dictionary term that is a direct match, and its ID
Whether or not the dictionary term is unique in its level
To generate a Dictionary Impacts Report:
Parent topic: Running Dictionary Upgrade Reports
The Predict VTA/VTI Report shows the current state of VTAs and VTIs in the predictionary tables for a particular Activation Group and dictionary specified at runtime and indicated in the report header.
Accordingly, the report groups the VTAs and VTIs into the following sections:
Classifications: Displays verbatim terms in the predictionary classification table.
Reclassifications: Displays the terms in the predictionary reclassifications table. These reclassifications may have been done by the Autoprocess VTAs/VTIs job or manually.
Declassifications: Displays terms in the predictionary declassifications table. These declassifications may have been done manually or by the Autoprocess VTAs/VTIs job.
The following columns are displayed in the above report sections:
Dictionary
Domain
Verbatim Term
Type: VTA or VTI
VTA or VTI ID
Dictionary Term and its ID (This is blank for declassifications)
Old Dictionary Term and its ID (only for Reclassifications)
Only Superusers can run this report
To generate a Predict VTA/VTI Report:
Site Impacts Report
The Site Impacts Report displays the X Areas affected by a dictionary upgrade on a particular site.
In Oracle Clinical, an X Area is a study. If you select Oracle Clinical as the external system, the report displays actual study names. If you are using a different external systems, the report displays either the X Area ID or a recognizable name you specify using a function. See Defining External System Information in TMS.
Run the Site Impacts Report after the Autoprocess VTA job.
The Site Impacts Report displays the following:
The external system in use
The list of X Areas affected by the upgrade
The corresponding X Area names
The external system instance
This report includes sites affected by an upgrade because at least one dictionary/domain combination allows classification to nonapproved dictionary terms, and the upgrade includes nonapproved dictionary terms that are a direct match to verbatim terms currently to a different dictionary term. This could be the case in MedDRA-J, for example. See Assigning a Dictionary to a Domain for more information.
To generate a Site Impacts Report:
A dictionary upgrade resolves omissions if a new dictionary term is added that is a direct match, and creates new omissions if the dictionary term to which a VTA or VTI is mapped is deleted.
For both omissions that will be resolved and omissions that will be created, the Omission Impacts Report displays the following:
Domain
Dictionary
External system instance
External system name
X Area
X Area name (if available)
Term
Number of records affected
For omissions that will be resolved, this report includes omissions that are a direct match to a nonapproved dictionary term, if their dictionary domain allows classification to nonapproved dictionary terms. This could be the case in MedDRA-J, for example. See Assigning a Dictionary to a Domain for more information.
To generate an Omission Impacts Report, do the following:
If you have mapped terms across dictionaries using named relationships (NRLs), these mappings will be affected if either of the related terms is deleted. The Cross Dictionary Impacts Report lists all affected relations.
Run the Cross Dictionary Impacts Report before or after the autoprocess VTA job.
For each affected named relation, the Cross Dictionary Impacts Report displays the following:
Domain
The dictionary and dictionary level on the From side of the relation
The dictionary and dictionary level on the To side of the relation
The term on the From side of the relation
The named relationship definition used
The term on the To side of the relation
The DML
The error message (gives the ID of the missing term)
To generate a Cross Dictionary Impacts Report:
