VTA and VTI Maintenance Reports
The following are VTA Maintenance reports:
- Nonapproved VTs Report
- Classification to a New Domain Report
- Verbatim Term Modifications Report
- X Areas with Outstanding Changes Report
Parent topic: VTA and VTI Maintenance
The Non Approved VTs report displays nonapproved VTs in chronological order, with the most recent first. It also displays actions and notes associated with the VTs.
You can generate this report in MS Excel.
The Non Approved VTs report provides the following information about VTs:
The dictionary and domain names
The verbatim term
Dictionary term to which the VT maps
The dictionary term's level
The VT's status
The user ID of the person who created the VT
The report provides the following information about actions:
The verbatim term
The action text
The action code as it appears in TMS
The action description
The user ID of the person who created the action
To run the Non Approved VTs report:
Parent topic: VTA and VTI Maintenance Reports
This report is useful when you are planning to move to a new domain and a different dictionary or a new rendition of the same dictionary; for example from WHO-ART to MedDRA. This report displays information about the amount of recoding that is required for this move. You can use the Copy Domain feature to make the coding similar in the two domains, if you so require. See Copying Domains.
The report displays:
The omissions that will remain omissions
The omissions that will be resolved (VTAs or VTIs)
The VTAs and VTIs that will remain VTAs or VTIs
The VTAs and VTIs that will be reclassified
The VTAs and VTIs that will be declassified (omissions)
For each verbatim term, the report displays:
The term type (VTA or VTI)
The VT status and ID
The original domain's dictionary term and its ID
The new domain's dictionary term and its ID
To run the Classification to a New Domain Report:
You can keep track of the coding changes that a Verbatim Term (VT) has undergone within a specified time period and data set with the VT Modifications Report. It specifies the type of change in the VT - classification, declassification, reclassification and applied actions. You can also view the author of the change and the reason for it.
You can confine your search to a verbatim term in a particular external system or include all external systems. You can define an External Value to narrow your search to a particular data set. For example, in Oracle Clinical, you can define an External Value as a study and assign an External Value Number to each study. TMS generates a report based on the specified study only.
The Verbatim Term Modifications Report displays the following:
Dictionary: The selected dictionary or dictionaries on which the report is run.
Domain: The active domain or domains on which the report is run.
Verbatim Term: The Verbatim Term queried.
External Value: This indicates the query criteria, if any.
VT Status: The changes undergone by the VT (classification, declassification, reclassification and applied actions), the coder User ID, and the time of change.
Dictionary Term & Action Text: This is the Dictionary Term for an approved VTA. For an Action, the Action text is displayed.
To run the Verbatim Term Modifications Report:
This report displays X Areas for which the data exchange job between the external system and TMS should be run. If the external system is Oracle Clinical, an X Area is a study, and the report displays the study names for which Batch Validation should be run.
If you are not running the data exchange job on a regular basis—for example, you have finished data collection in a study—you can run this job to detect X Areas where data cleaning in the external system or changes such as reclassifications in TMS have produced data changes that should be propagated to the other system.
If the external system is not Oracle Clinical, you can write a function to display a meaningful name for X Areas if appropriate; see Defining the External System in TMS and Defining Views and Functions in the External System.
The report displays the X Area and other external system information for:
omissions that originated in all instances
source terms that originated locally only
To run the report, do the following:
