Sample report: Patient demographics
Oracle Analytics contains example reports so you can see how you can visualize Oracle Health Immunization Management data. For example, you may want to create a report with details on your patient profiles.
After accessing the sample reports from a Shared Folder, you can select the different tabs from the bottom row to review different types of data. The following report shows four bar graphs with details on ethnicity, gender, age band, and race of a number of patients.
You can select options in the left panel to change the view. For example, you can change the bars from horizontal to vertical.
Oracle Analytics does not save any changes you make to the view. After you close the report, it reverts back to the original sample data view.
Parent topic: Sample Reports
