Oracle Health Clinical Intelligence 2025_RTP36
The solution changes below are available with the Oracle Health Clinical Intelligence 2025_RTP36 release.
- Preproduction Release Date: September 3, 2025
- Production Release Date: September 3, 2025
| Solution Change | Component, Description, and UI Impact | Reference Materials | Validation Guidelines | Implementation and Maintenance Impact |
| Enhancement 1-000000555298 |
Component: Clinical Intelligence Visit Type is added to all visit information in the patient dialog box. UI Impact: Visual Only |
View Patient Information | Verify that the visit type is displayed in the patient dialog box. | Implementation Impact: None
Maintenance Impact: None |
| Correction 1-000000559309 |
Component: Clinical Intelligence Tooltips are displayed as expected when you hover over a tooltip-enabled element. UI Impact: Visual Only |
Not applicable | Verify that tooltips are displayed when you hover over a tooltip-enabled element. | Implementation Impact: None Maintenance Impact: None |
Parent topic: Previous Releases
