Oracle Health Quality Management 2025_RTP43
The solution changes below are available with the Oracle Health Quality Management 2025_RTP43 release.
- Preproduction Release Date: October 23, 2025
- Production Release Date: October 23, 2025
| Solution Change | Component, Description, and UI Impact | Reference Materials | Validation Guidelines | Implementation and Maintenance Impact |
| Enhancement 1-000000570268 |
Component: Quality Management A Measure Detail page now is available for each measure that serves as a centralized location for all relevant information about that measure. UI Impact: Workflow Automatic When you select a measure you are directed to a Measure Detail page. |
See Measure Detail View for more information. | Verify that you can successfully complete the workflows in the Reference Materials. | Implementation Impact: None
Maintenance Impact: None |
| Enhancement 1-000000570269 |
Component: Quality Management - Patients List Patients list now includes task management and patient selection functionality. UI Impact: Workflow Automatic You now can select patients and take patient-level notes from Patients list. |
See View the Patient List for more information. | Verify that you can successfully complete the workflows in the Reference Materials. | Implementation Impact: None
| Enhancement 1-000000570270 | Component: Quality Management
You now can view multiple reporting projects from Quality Management. UI Impact: Workflow Automatic You now can view multiple reporting projects in Quality Management using the Reporting Project menu. |
See Select a Reporting Project for more information. | Verify that you can successfully complete the workflows in the Reference Materials. | Implementation Impact: None Maintenance Impact: None |
| Enhancement 1-000000570271 | Component: Quality Management
A home page now is available for Quality Management. From the home page, you can view key performance indicators (KPIs) and top opportunities. UI Impact: Workflow Automatic You now can view the home page in Quality Management. |
See Quality Management Home for more information. | Verify that you can successfully complete the workflows in the Reference Materials. | Implementation Impact: None
| Enhancement 1-000000552233 | Component: Population AI Assistant
You now can search for a patient using their name, medical record number (MRN), or enterprise master patient index (EMPI) number. UI Impact: Workflow Automatic The search bar now indicates that you can search by name, MRN, or EMPI. |
See Search for a Patient for more information. | Verify that you can successfully complete the workflows in the Reference Materials. | Implementation Impact: None
| Enhancement 1-000000567389 | Component: Quality Management
CRM Connector now is available. You can use CRM Connector to create outreach campaigns in Quality Management. UI Impact: Workflow Automatic When you select the Outreach button in Quality Management, CRM Connector opens. |
See Patient Outreach for more information. | Verify that you can successfully complete the workflows in the Reference Materials. | Implementation Impact: None
| Configure Contract Performance in Console | Component: Quality Management - Contract Performance
You now can configure value-based care contracts in Console. UI Impact: Workflow Automatic Contract Performance workflows now are available in Console. |
See Create a Contract for more information. | Verify that you can successfully complete the workflows in the Reference Materials. | Implementation Impact: None
| View contract gate information and set contract cost and utilization target values. | Component: Quality Management - Contract Performance
Contract gate and target achievement information now is displayed in Contract Performance. You now can set cost and utilization targets in Contract Performance. UI Impact: Visual Only |
See Set Cost and Utilzation Targets for more information. | Verify that you can successfully complete the workflows in the Reference Materials. | Implementation Impact: None
Parent topic: Previous Releases
