Oracle Health Quality Management 2026_RTP07
The solution changes below are available with the Oracle Health Quality Management 2026_RTP07 release.
- Preproduction Release Date: Not applicable
- Production Release Date: March 2, 2026
| Solution Change | Component, Description, and UI Impact | Reference Materials | Validation Guidelines | Implementation and Maintenance Impact |
| Enhancement 1-000000579465 |
Component: Quality Performance The Status column now is only viewable when you select the Scorability filter to view scorable measures. Previously the Status column was viewable by default. Measures on the score plan now can be sorted into four new status descriptions, in addition to Top Opportunity status. The following new statuses are included:
UI Impact: Visual Only |
See Measures View for more information. | Verify that when you select the Scorability filter in the Measures view of Quality Performance, only scorable measures are displayed. Verify that statuses other than Top Opportunity are displayed for scorable measures. |
Implementation Impact: None
Maintenance Impact: None |
| Correction 1-000000575665 |
Component: Quality Performance External measures values now are displayed as either numerical or string values in the Met and Target columns on the Measures view. UI Impact: Visual Only |
See Measures View for more information. | Verify that any custom external measure values are displayed as either numerical or string values. |
Parent topic: Previous Releases
