Oracle Health Quality Management 2026.02
The solution changes below are available with the Oracle Health Quality Management 2026.02 release.
Solution Change Details
Solution Change Component, Description, and UI Impact Reference Materials Validation Guidelines Implementation and Maintenance Impact
Enhancement HNVBC-36518 Component: Console
When you edit a contract and change the reporting ID, a warning message is displayed.
UI Impact: Workflow (Automatic)
When Quality Management users edit a contract, an error message is displayed and you must review and acknowledge the message to continue.
Contract Information Verify that when you edit a contract, a message is displayed.
Implementation Impact:
None
Maintenance Impact:
None
Enhancement 1-000000584849 Component: Quality
The Patient drawer and Payer section are available. The Source column indicates where each payer record originates.
Quality users can filter payer and plan information so that only data from enrollment files is used in quality workflows. This enhancement helps ensure that workflows rely on the most current and relevant enrollment-based data. To enable this filtering, please submit a Service Request (SR).
Quality Performance Verify that the most current and relevant enrollment-based data is included and that you can filter on.
Low
Submit a Service Request (SR) to enable this setting.
Maintenance Impact:
None
Correction 1-000000582828 Component: Quality
The number of unmet patients now is displayed in the Measure table. Previously 0 was displayed.
UI Impact: None
None Verify that the appropriate number of unment patients is displayed.
None
Maintenance Impact:
None
Correction 1-000000579137 Component: Contracts
The Shared Context now works as expected.
UI Impact: None
Set Cost and Utilization Targets Verify that you can successfully complete the workflows in the Reference Materials.
None
Maintenance Impact:
None
Correction 1-000000580127 Component: Contracts
When you select Contract Opportunities, you are taken to the Patient list and the expected number of patients are displayed.
UI Impact:
None
Contract Overview Verify that you can successfully complete the workflows in the Reference Materials.
None
Maintenance Impact:
None
Correction 1-000000581402 Component: Contracts
The Quality Performance tab displays the number of measures present instead of how many measures were met.
UI Impact:
None
None Verify that when you select Quality Performance, the number of measures present is displayed, instead of the number of measures met compared to the number of measures present.
None
Maintenance Impact:
None
Correction 1-000000581533 Component: Contracts
Metrics are displayed in units that make sense for the type of data.
UI Impact:
None
None Verify that the appropriate units of measure are displayed based on the type of data.
None
Maintenance Impact:
None
Correction 1-000000582302 Component: Contracts
When you delete a domain or domain group, a more specific error message is displayed depending on whether there is a problem with the item being deleted.
UI Impact: Visual Only
A specific error message is displayed.
None Verify that when you delete a domain or category, an informative error message is displayed.
None
Maintenance Impact:
None
Correction 1-000000581637 Component: Contracts
When you add a new contract and select a payer, a single plan is pre-selected. Previously, if all a plan had the same plan name, all plans were pre-selected even though they had unique plan IDs.
UI Impact: None
None Verify that when you add a new contract and select a payer, a single plan is pre-selected.
None
Maintenance Impact:
None
Correction 1-000000581643 Component: Console
Enrollment sources and claim sources with identical names are differentiated so users can select the correct enrollment source or claim source.
Enrollment sources and claim sources are indicated in the dropdown.
None Verify that enrollment sources and claim sources with identical names are differentiated in the list.
None
Maintenance Impact:
None
Correction 1-000000583039 Component: Quality
Performance reporting accuracy is improved in aggregated views in the Quality tab for negative polarity measures. Previously, the measure status was interpreted based on the health outcome of the patient instead of the measure status.
UI Impact: None
None Identify a test patient with a negative polarity measure (such as an HbA1c result greater than or equal to 9%). Verify that the measure shows as MET.
None
Maintenance Impact:
None
