2 Quality Performance
Quality Management hosts various workflows, starting with Quality Performance workflows from HealtheRegistries. Quality Performance workflows include Quality (Scorecards) and Patients (Patient Lists)
- Quality Performance Introduction
Quality Performance allows you to view quality initiatives for an organization. - Quality Performance Data Requirements
Quality Performance workflows are available through the Registries application. - Quality Performance Personas
Personnel groups are used to grant access to the Quality Performance workflows. - Quality Performance Access Considerations
Access level determines what information you can view on the Quality Performance summary view. - Select a Reporting Project
Select the reporting project you want to view. - View the Quality Performance Dashboard
The Quality Performance dashboard provides an overview of the measures for an organization. - Use Quality Smart Search
You can filter data that is displayed on the Quality Performance dashboard. - Use Pivot Views
Pivot views provide further insight into measures, organizations, and providers. - Measures View
The Measures view displays a list of relevant quality measures and their current status. - Measure Detail View
The measure detail page displays details for a specific measure. - Organizations View
The Organizations view provides quality performance information from the perspective of different organizations. - Providers View
Administrators can view quality performance information from the perspective of different providers. - Search for a Provider
Locate and view provider details using the Quality tab. Use search or filters to find a provider, then access associated organizations and measures. - Search for an Organization
Locate and view organization details using the Quality tab. Use search or filters to find an organization, then access associated providers and measures. - Filter the Measures View
Filter and refine the measures view using criteria such as scorability, organization, provider, registry, and measure.
