Organizations View
The Organizations view provides quality performance information from the perspective of different organizations.
The Organizations view displays relevant organizations (as set up in Oracle Personnel tool) for the specific user. The Organizations view provides quality performance information from the perspective of different organizations. This view can be helpful when attempting to identify different organization areas and their respective quality measure performance in the same healthcare organization.
Quality Performance organization view
Table 2-4 Organization view columns
Column Definition
Name The name of the organization as configured in the Oracle Personnel tool.
Organization Class The organization class for this specific organization. Organization classes are defined in the Personnel tool and allow users to group together similar organizations based on criteria such as geography, size, or specialty (for example, pediatric organizations).
Composite Score The composite score for the organization. See Understanding Composite Scores in HealtheRegistries on Oracle Health wiki for details.
If the organization has not set up a score plan, No Target Set is displayed.
Measures The total number of measures being scored (set up in Score Plan tool) for the organization.
Met The combined met percent for all measures that are scored for this organization. This percentage is calculated using the total number of patients that have met measures in this organization divided by the total number of scorable patients for this organization.
Total Patients The number of patients in the denominator for all measures enabled for this organization.
You can select the numerical value to access the Patients page to view the list of patients for this specific row.
vs. Last Month The difference in composite score between last month's composite score and the current composite score. For example, if today is July 5, compare the composite score with June 1. Snapshots are taken at the beginning of every month, so data points are compared to the beginning of the previous month.
If data is not available, No Data is displayed.
vs. Last Year The difference in composite score between last year's composite score and the current composite score. For example, if today is July 5, 2024, compare the composite score with July 1, 2023. Snapshots are taken at the beginning of every month, so data points are compared to the beginning of the same month from the previous year.
