Providers View
Administrators can view quality performance information from the perspective of different providers.
The Providers view displays the list of all providers (as set up in Oracle Personnel tool) for this specific user. Only organization administrators can see multiple providers in this view. A member of an organization can only see themselves in this view. The Providers view provides the administrator with quality performance information from the perspective of different providers. This view can be helpful when attempting to identify different organization areas and their respective quality measure performance in the same healthcare organization. Only members who are part of a scorable personnel group are displayed in this list. If an organization filter is used, only users that are a member of that organization are displayed in this list. If a user is an administrator of the organization, they are not displayed in this list.
All providers are displayed by default, both scorable and nonscorable. Nonscorable providers display No Target Set in the Target column. To view only scorable providers, use the Scorability filter.
Table 2-5 Providers view columns
Column Definition
Provider The name of the provider as configured in the Oracle Personnel tool.
Composite Score The composite score for this provider. See Understanding Composite Scores in HealtheRegistries.
If the provider has not set up a score plan, No Target Set is displayed.
Measures The total number of measures being scored (set up in Score Plan tool) for this provider.
Met The combined met percent for all measures that are scored for this provider. This percentage is calculated using the total number of patients that have met measures for this provider divided by the total number of scorable patients for the provider.
Total Patients The number of attributed patients in the denominator for all measures scored for this provider.
You can select the numerical value to access the Patients page to view the list of patients for this specific row.
vs. Last Month The difference in composite score between last month's composite score and the current composite score. For example, if today is July 5, compare the composite score with June 1. Snapshots are taken at the beginning of every month, so data points are compared to the beginning of the previous month.
If data is not available, the system displays No Data.
vs. Last Year The difference in composite score between last year's composite score and the current composite score. For example, if today is July 5, 2024, compare the composite score with July 1, 2023. Snapshots are taken at the beginning of every month, so data points are compared to the beginning of the same month from the previous year.
If data is not available, they system displays No Data.
