Measures View
The Measures view displays a list of relevant quality measures and their current status.
The Measures view provides information required to understand the healthcare organization’s quality performance and identify areas for improvement. If a provider filter is used, this displays the measures that the specific provider is scored against in the Score Plan tool. If an organization filter is used, measures that the organization is scored against in the Score Plan tool are displayed. If an organization class only has provider score cards set up and no organization score card set up in the Score Plan tool, no measures are displayed in the Measures tab. If a provider filter is added, only the measures the filtered provider is scored against are displayed in the Measure tab.
All measures are displayed by default, both scorable and nonscorable. Nonscorable measures display No Target Set in the Target column. To view only scorable measures, use the Scorability filter.
Measures View in Quality tab showing the Scorability filter selected and set to Scorable. The Status column is displayed.
Table 2-3 Measures view columns
Column Definition
Status
The Status column is not displayed by default. Set the Scorability filter to Scorable to view the Status column.
The status of the measure as defined by the Top Opportunity algorithm. See Overview of the Opportunity Index in HealtheRegistries on Oracle Health wiki for details. The status can have one of the following labels:
  • Top Opportunity: Displayed on all top opportunity measures using the Top Opportunity algorithm.
  • Met: Displayed for all measures where Met percentage is greater than Target.
  • Below Threshold: This measure does not meet the minimum patient threshold set by your organization. At least X (minimum threshold set by your organization) patients must be included in this measure for it to be scorable.
  • Partial Credit: This measure is receiving partial credit. To receive full credit, at least X (minimum threshold set by your organization) patients must be included in this measure.
  • No Valid Patients: This measure has no valid patients in the denominator. At least one patient must be included in this measure for it to be scorable.
  • Missing Data: This measure is missing data required to understand performance.
All other measures have no status label.
Measure The name of the measure. The measure name is displayed with the associated registry in parentheses.
For example:
  • Blood Pressure Measurement (Comprehensive Adult Wellness)
  • Blood Pressure Measurement (Hypertension)
Selecting a measure name directs you to the measure detail page for that measure. See Measure Detail View.
You can use the score plan tool to define links for external measures. For links that use placeholder values for organizations or providers, users with access to multiple scorecards must filter by a single organization or provider to view the link; otherwise, no link is displayed. For users with access to a single scorecard, that scorecard is used to fill the placeholder, and the custom measure link is displayed using the user's scorecard.
Met The met percentage of the specific measure. This percentage is calculated using the total number of scorable patients that have met the specific measure divided by the total number of scorable patients in the measure’s denominator.
For custom external measures, values can be displayed as numerical or string values.
Target The target the user has set for this measure in the Score Plan tool. If no target is set, No Target Set is displayed. The target value used in this column is identical to the value used on the scorecard in HealtheRegistries.
Unmet Patients The total count of unmet patients included in this measure based on the measure's inclusion criteria. You can select the numerical value to access the Patients page to view the list of patients for this specific row.
Total Patients The total count of patients included in this measure based on the measure's inclusion criteria. This includes patients that have both met and not met this measure.
vs. Last Month
The difference in met percentage between last month's met percentage and the current met percentage. For example, if today is July 5, compare the met percentage with June 1. Snapshots are taken at the beginning of every month, so data points are compared to the beginning of the previous month.
If data is not available, the system displays No Data. This can happen if the measure was recently enabled.
vs. Last Year
The difference in met percentage between last year's current percentage and the current met percentage. For example, if today is July 5, 2024, compare the met percentage with July 1, 2023. Snapshots are taken at the beginning of every month, so data points are compared to the beginning of the same month from the previous year.
If data is not available, they system displays No Data.
