Select a Reporting Project
Select the reporting project you want to view.
A reporting project consists of the following main properties
  • Content (Registries and Measures)
  • Measurement Period (Calendar year versus rolling 365 days)
  • Population
    The following table contains examples of two different reporting projects:
    Reporting Project Content Measurement Period Population
    Clinical Standard Registries and measures from the clinical standard v4 content catalog are included. Rolling 365 days, patient outcomes are calculated based on results from last 365 days. Full HealtheRegistries population.
    HEDIS MY2025 Measures from the HEDIS MY2025 content catalog are included. Calendar year; patient outcomes are calculated based on results from current calendar year. Full HealtheRegistries population.
The above two reporting projects apply to the same population. The Clinical Standard reporting project hosts information related to the clinical standard measures while the HEDIS MY2025 includes all HEDIS MY2025 measures. Access to multiple reporting projects allows you to view content from various catalogs in the same workflow and application.
You can select the reporting project for which you want to view details from the Reporting Project menu. You can access all reporting projects your organization is tracking against from Quality Management in the Quality view and the Patients view. The default reporting project is Quality Performance and includes the set of content your organization had enabled in HealtheRegistries.
You can access the Reporting Project menu from both the Quality and Patients views. Reporting projects displayed on the menu are enabled in Console. When you access the Reporting Project menu from the Patients view, additional projects may be displayed related to Value Based Care contracts if your organization is using Contract Performance.
From the Reporting Project menu, select the reporting project you want to view. Data for that reporting project is displayed.
For information on enabling reporting projects in Quality Performance, see the Oracle Health Quality Management Administrator Guide.
