Use Quality Smart Search
You can filter data that is displayed on the Quality Performance dashboard.
Quality smart search field with scorability, organization class, organization, provider, registry, and measure filters displayed.
The smart search component allows you to filter data presented in the pivot view tables. To search for specific filter values, select one of the available filtering values and view the options. You can select multiple filters.
Table 2-2 Quality Performance filters
Filter Definition
Measure The name of the measure. Use this filter to search and filter for specific measures. For example, Blood Pressure Management.
Organization The name of the organization. If a user is a member or administrator of multiple organizations, they can use this filter to select a specific organization.
Patients that are not attributed to any provider and are not affiliated with any organization are grouped together under the No Data organization.
Organization Class The name of the organization class. If a user is a member or administrator of multiple organization classes, they can use this filter to select a specific organization class.
Provider The name of the provider. Use this filter to search for and select specific providers in the organization.
This filter is available only to administrators. If a user is only a member, they can only select their own name in the Provider filter.
Registry The name of the registry. Use this filter to narrow down the listed quality measures and view measures from a specific registry.
Scorability Allows you to view measures, providers, and organizations that are scorable.
For example, if you select the hypertension registry and Baseline East Clinic as the organization, the list of measures in the grid displays measures from the hypertension registry that have been enabled for Baseline East.
Quality smart search with hypertension registry and baseline east organization filters selected.
