Add Domains to a Domain Group
Select the domains to add to a domain group.
You can add domains to a domain group to group similar domains together.
To add domains to a domain group:
- Select Edit Domain Group next to the domain group you want to edit.
- Select the domains you want to add to the domain group.
- Select Save.
Parent topic: Contract Performance
