Set Targets for Domain Groups
Set target values for a domain group.
You can set target information for a domain group.
To set target information for a domain group:
  1. Select Edit Domain Groups next to the domain group for which you want to set a target.
  2. Select Add Target to add a target value to the domain.
  3. Select a value from the Score Type menu. Options include:
    • Weighted Average
    • Unweighted Average
    • Measures Meeting Goal
  4. Select a value from the Target Type menu. Options include:
    • Simple Percentage
    • Simple Number
    • Tiered Percentage
    • Tiered Number
  5. Enter a value in the Target Value field.
  6. Optionally, select a value from the Payout Type field. Options include:
    • PMPM
    • PMPY
    • Lump Sum
    • Per Care Gap Measure Closure
  7. Optionally, enter a value in the Payout Values field.
  8. Optionally, enter a value in the Organizational Goal field.
  9. Optionally, select a value from the Contract Gate field.
  10. Select Save.
