Create Domain Groups
You can create groups of domains.
You can create groups of domains called domain groups. This helps to track groups of measures and improve quality.
To create a domain group:
  1. Select Edit Target Plan next to the contract for which you want to create a domain group.
  2. Select Domain Groups from the right side of the page.
  3. Select Add Domain Groups.
  4. Enter a name for the domain group and a description.
  5. Select Save.
