Audit Quality Management
Audit Quality Management to view which reports are being viewed most frequently.
You can audit Quality Management to determine which reports are being viewed most frequently. Contact your Oracle representative for a list of audit events.
To audit Quality Management:
- Open P2Sentinel. See Accessing P2Sentinel for information on gaining access to P2Sentinel.
- From the Patient Privacy menu, select Cloud Interactions, then select Cloud Discrete Details.
- Enter the system name you want to view in the System Names field and select the appropriate system.
- Select Submit. The discrete details for the selected system are displayed.
- Select the Selected Events tab and enter a keyword in the Event Keys field.
- Select the event you want to view and select Submit. Details for that event are displayed.
The table below displays available audit events. When you send the audit event in the Heading column to the system, the system returns the information included in the Attributes column. For example, if you wanted to know which providers have been viewed in the Providers list in the Quality tab, you would send the VIEW_PROVIDERS_QUALITY_PERFORMANCE event. The system would return the names and IDs of the providers that were viewed.
| Workflow | Heading | Description | Attributes |
| Quality | VIEW_PROVIDERS_QUALITY_PERFORMANCE | This event indicates that a user accessed the Providers table in the Quality Tab. |
| Quality | VIEW_ORGANIZATIONS_QUALITY_PERFORMANCE | This event indicates that a user accessed the Organizations table in the Quality tab. |
| Quality | VIEW_MEASURES_QUALITY_PERFORMANCE | This event indicates that a user accessed the Measures table in the Quality tab. |
| Patient List | SAVED_VIEW_ACTION | This event indicates that a user interacted with views from the preference service. |
| Patient List | VIEW_PERSON_DRAWER | This event indicates that a user interacted with the patient dialog box on the Patients list. |
| Patient List | DELETE_PATIENT_NOTE | This event indicates that a user deleted a patient note. |
| Patient List | UPDATE_PATIENT_NOTE | This event indicates that a user updated a patient note. |
| Patient List | CREATE_PATIENT_NOTE | This event indicates that a user created a patient note. |
| Patient List | VIEW_PATIENT_NOTES | This event indicates that a user viewed a list of notes for a patient. |
| Patient List | VIEW_PATIENT_LIST | This event indicates that a user accessed the patient worklist. |
| Outreach | CAMPAIGN_OUTREACH_ACTION | This event indicates that a user interacted with outreach campaign creation. |
| Contracts | UPDATE_TARGET_MEASURE | This event indicates that a user updated a target measure. |
| Contracts | CREATE_TARGET_MEASURE | This event indicates that a user created a target measure. |
| Contracts | VIEW_TARGET_MEASURE | This event indicates that a user viewed a single target measure. |
| Contracts | VIEW_TARGET_MEASURES | This event indicates that a user viewed a group of target measures. |
| Contracts | UPDATE_DOMAIN | This event indicates that a user updated a domain. |
| Contracts | CREATE_DOMAIN | This event indicates that a user created a domain. |
| Contracts | VIEW_DOMAIN | This event indicates that a user viewed a single domain. |
| Contracts | VIEW_DOMAINS | This event indicates that a user viewed a group of domains. |
| Contracts | CREATE_COLLECTION_DOMAIN | This event indicates that a user created a collection domain. |
| Contracts | UPDATE_COLLECTION | This event indicates that a user updated a collection. |
| Contracts | CREATE_COLLECTION | This event indicates that a user created a collection. |
| Contracts | VIEW_COLLECTION | This event indicates that a user viewed a single collection. |
| Contracts | VIEW_COLLECTIONS | This event indicates that a user viewed a group of collections. |
| Contracts | VIEW_CONTRACT_DETAILS | This event indicates that a user accessed a single contract. |
Parent topic: Oracle Health Quality Management Introduction
