Create a Campaign in Oracle Eloqua
Create a campaign in Oracle Eloqua.
Once you have created and saved a campaign segment in Oracle Health Quality Management, the campaign segment is available in Oracle Eloqua. The segment represents the clinically informed audience that you defined based on patient data. You can use the campaign feature in Oracle Eloqua to build and execute the outreach campaign.
Oracle Eloqua does not allow multiple contacts with the same email address by default. Oracle Eloqua uses the email address as the unique key for each contact record. It is not recommended to use personalization in emails as it could potentially identify another contact with the same email address.See Creating simple email campaigns on the Oracle Eloqua Help Center.
Parent topic: Patient Outreach
