Part III Entry / Exit System
As a prerequisite, the European Travel Information and Authorisation System (ETIAS) will undergo a detailed checked on each applicant to determine whether they can be allowed to enter any country within the Schengen Zone. Therefore, ships must submit their passengers/guests and onboard crew list for verification before they are allowed to depart from the harbor. The Entry/Exit System (EES) is used for the purpose to generate the EES data file for submission, either manually or uploaded to an application provided by EES.
Once EES processes the application file and generate a response file, you are required to upload the response file data and update the passengers, guest’s and onboard crew’s ETIAS status into SPMS Desktop Application using EES module.
