4 Setting Up CIW
This section describes the configurations required prior to using the CIW function.
Accessing the Setup Page
The setup function is accessible by launching the Advance Quick Check In module, and navigate to the Setup tab on the main page.
Only users who has the permission are able access to the Setup tab, General Setup, Wizard Travel Rules and Wizard Travel Documents Eligibility assignment.
Setting Up Wizard Travel Rules
Before you begin using the CIW function, you must configure the travel rules for each nationality, by first creating a template and assign the nationalities to the template.
Figure 4-1 CIW Travel Rules
Adding New Travel Document Rules Template
At the main page, select the Setup tab and the Wizard Travel Rules at the ribbon bar to open the rules eligibility screen.
By default, all the entry fields are disabled. At the Travel Document Rules Eligibility page, click Add or select an existing Template to activate the fields.
Enter the Region Template Name and Comment, then select Embark/Disembark Country from the drop-down list.
In the Select Accepted Document Type, check mark the applicable checkboxes.
In the next section, check mark the applicable checkboxes if the field is editable or mandatory and click Save to save the template.
Select the Nationality and check the appropriate document types accepted under Select Accepted Document Type section. The accepted document types are defined in parameter Advance QCI, Wizard DocType xxx.
Select the requirement for document type whether it is editable or mandatory in the Immigration, Visa or Other information screen in AQCI.
To add more nationality to the rule, repeat steps 6 to 7.
Click Save to save the template.
Duplicating Nationality Rules
You can duplicate an existing rules defined in a nationality to other nationalities.
Figure 4-2 Copy/Paste Rules Based Nationality
At the Travel Document Rules Eligibility page, click the Nationality button.
Select from the drop-down list the Nationality to Copy From.
Choose the nationalities at List of All Nationalities and click the double right arrow to transfer the information to Paste to Selected Nationalities window.
To remove the selection, select the nationality from Paste to Selected Nationalities, and click the double left arrow.
Click OK to copy.
Duplicating a Template
You can copy an existing template if the rules defined are relatively similar.
At the Travel Document Rules Eligibility page, select a Region Template from the drop-down list.
Click the Template at the ribbon bar and insert the new template name when prompt, and click OK to copy
Defining Template to a CIW User
Figure 4-3 CIW Travel Documents Eligibility
Once you have the travel rules configured in the template, you can choose the template to use based on the voyage.
At the main AQCI page, navigate to the Setup tab.
Click the General Setup on the ribbon bar.
At the Parameters tab, select the Travel Rules Name under Wizard Travel Documents Eligibility drop-down list, and click OK to save.
The system then updates the selected template in parameter Advance QCI, Travel Documents Eligibility Setup, and selected template is shown.
Setting Up Barcode Scanner
The CIW supports barcode scanning of passenger’s board card, and the field used to search the passenger’s record is defined in Parameter, Advance QCI, Wizard - Scan Barcode field. Typically, the search uses the reservation board card external number to identify the passenger as the external number is usually printed on a document such as set-sail pass.
Figure 4-4 CIW Hardware Tab
At the main AQCI page, navigate to the Setup tab and click the General Setup at the ribbon bar.
At the Hardware tab, check the Barcode Reader (RS232 Connection) checkbox and set the speed to 9600, and use the system defaulted port number, parity, stop bits and data bits setting. The supported barcode format is Interleaved2of5, Code 39 and Barcode C128, minimum speed at 9600.
Click OK to save.
Setting Up Passport Reader
The CIW function supports a number of passport reader that is used for registration.
To configure the passport reader,
Repeat step 1 of Setting up Barcode scanner.
At the Hardware tab, select the Card Reader for a swipe type reader or Passport Reader for a scanner type reader from the drop-down list and use the system default settings.
Click OK to save.
