Prerequisites, Supported Systems and Compatibility
This section describes the minimum requirements to run the Cashbook program in SPMS.
Prerequisites
Cashbook.exe
Administration.exe
Parameter “Cashier”, “Use Full Cashier”
Compatibility
SPMS version 20.1 or later. For customers operating on version 20.1 and below, database upgrade to the recommended or latest version is required
