1 Parameters
This section lists the Parameters available to Cashbook module. Setting these parameters will alter the program behavior. Please consult Oracle Customer Support for further clarification before proceeding.
Table 1-1 PAR_GROUP Cashbook
| PAR Name | PAR Value | Description |
Cashbook Balance Bring Forward Enabled |
<0,1> |
0 – Disable cash book balance to bring forward 1 – Enable cash book balance to bring forward |
Payout Balance Code |
<Pay-Out Code> |
A valid Pay-Out code (TRC_CODE) must be setup in the setup Transaction Code function and the code is used to balance current cruise balance and create a new brought forward balance in the next cruise. |
Payin Balance Code |
<Pay-In Code> |
A valid Pay-In code (TRC_CODE) must be setup in the setup Transaction Code function and the code is used to balance current cruise balance and create a new brought forward balance in the next cruise. |
Cashbook Current Cruise |
<Current Cruise ID>. |
0 – Regular system cruise number to be used >0 – Present current cruise number used by cashbook system (SCR_ID) |
Read Only Other Person Cashbook |
<0,1> |
0 – Disable 1 – Enable |
Credit Voiding |
<0,1> |
0 – Voiding with minus amount on same account side |
Same Payin/out Codes |
<0,1> |
0 – Not same payin/out codes 1 – Same payin/out codes |
Cashbook Voucher Reset Date |
<dd-mm> |
The date when the Cashbook Voucher No. will be reset to 1 in “D-MM” format |
Cashbook Lock Status |
<0,1> |
0 – Release 1 – Locked |
Enable Currency Denomination Tracking |
<0,1> |
