3 User Access Right
Before you use the Cashbook module, you must enable the following Parameter “Cashier”, “User Full Cashier” and grant users the following User Access Rights:
Modules\Cashbook and its sub-category
Modules\Consolidation Viewer —#852 — Cashbook
General\Menu\Printing — #69 — Cashbook
Granting User Access
Login to Administration module.
Select the System Setup, Database Parameters from the Administration menu.
Enable the parameter “Cashier”, “Use Full Cashier”. The option “Cashier Function” and “Cashbook Assigned” are enabled for selection in the User Security Access assignment.
Launch OHC Launch Panel and navigate to Utilities, User Security.
Grant the above user rights to the group.
Navigate to individual user access.
Under the Various section, Cashbook Assigned, select the category from the drop-down list.
In Cashbook module, login with a user that has Cashbook assigned, the Cashbook value always defaults to the Cashbook that was setup for that particular user.
For more information, see Administration User Guide and Launch Panel User Guide.
