Preface
The DGS ResOnline module is an interface between Oracle Hospitality Cruise Fleet Management (FMS) and Oracle Hospitality Cruise Shipboard Property Management System (SPMS), transferring the guest reservations information, including Shore Excursion booking, Special Requests, Gift orders and others. The data are imported using an Extensible Markup Language (XML) format, based on the available mapping fields.
Audience
This document is intended for project managers, application specialists and users of Oracle Hospitality Cruise Shipboard Property Management System.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
September 2020 |
Initial Publication |
January 2024 |
Updated Customer Portal URL Updated document to new format |
