Prerequisites, Supported Systems and Compatibility
This section describes the minimum requirements to run the DGS ResOnline module.
Prerequisites
OHC Admnistration.exe
OHC Tools.exe
OHC DGS ResOnline.exe
Supported Operating System
See Compatibility Matrix at http://docs.oracle.com/en/industries/hospitality/.
Compatibility
SPMS version 20.1 or later. For customers operating on version 20.1 and below, database upgrade to the recommended or latest version is required
