Prerequisites, Supported Systems and Compatibility
This section describes the minimum requirements for the Application Server for Mobile Mustering and Gangway Security module.
Prerequisites
FCMobile Database
Patch 33492113: OHC Shipboard Property Management System Mobile 8.0.6
Cabin Station Setup
Application Server for Mobile Services
Preinstalled Oracle Data Access Components (ODAC) for PC running SPMS applications.
- ODTwithODAC112030 or
- ODTwithODAC121021
Supported Operating System
See Compatibility Matrix at http://docs.oracle.com/en/industries/hospitality/.
Supported Hardware
Oracle MICROS 721 Tablet
Windows Mobile device with a camera
Server based CPU (Xeon X3440 2.53 GHz)
Minimum RAM 8GB
Compatibility
SPMS version 20.1 or later. For customers operating on version 20.1 and below, database upgrade to the recommended or latest version is required
