4 History Movement
The History Movement function allow you to look up the past movement records.
Figure 4-1 History Movement Page
History Movement Search
From the Gateway Security menu, select the History Movement sub-menu.
On the History Movement page, search the record by name (either first name, middle name or last name) and/or stateroom.
Enter the value in the search box.
Click the Search button.
History Movement Advanced Search
On the History Movement page, click Go to Advanced Search. See below for available fields.
On the Advanced Search page, search by using manual entry or selecting from the list the values in the Search box.
Click Search.
Location: The Gate location that the passenger used to come onboard or go ashore
Movement: Indicates the gate direction used by the passenger (onboard, ashore)
Start Date: Date and time the passenger embarked or disembarked from the ship through the gateway
End Date: Date and time the passenger embarked or disembarked from the ship through the gateway
Profile Type: Profile Type to be searched, guest, crew, and so on
Name: The First name, middle name, last name of the passenger
Stateroom: The Stateroom number of the passenger
