3 IIS Configuration
Configure Web Service Run Privilege
The SPMS Web Services (OHC WebServices or OHC TransactionsService) by default are configured to run with ApplicationPoolIdentity. The default run privilege is restricted and will not be able to retrieve the Digital Signing certificate stored in the Windows Certificate Store when digital signing is required. Therefore, it is important to note that when Norwegian Fiscal Enhancements feature is enabled, the Cruise IT personnel is required to change the web service run privilege, using the steps below.
Open the IIS Manager.
Select the web services (OHC WebServices or OHC TransactionsService) from the application pool. Right-click and select Advanced Settings⦠option.
Figure 3-1 Application Pool Settings
Under Process Model group, select Identity option.
Figure 3-2 Application Pool Advanced Settings
At the Application Pool Identify form, change the Windows user access by selecting Custom Account and click Set.
At the Set Credentials form, enter the User Name, Password and Confirm Password when prompt.
Click OK to save and exit.
