2 Parameters
This section describes the Parameters available to WPF Security.
Table 2-1 Parameters
| PAR Name | Description |
Allow Auto Status Change for Last Account |
Allows auto Change of last account status by pressing CTRL+S. 0 – Do not allow 1 – Allow the auto Change |
Allow Mark Message as Delivered |
0 – The message will not mark as delivered. 1 – Prompt to user to confirm to mark the message. 2 – The message are marked as delivered when prompt. |
Allow offline expected embarkation today on board |
This is use in conjunction with Advance Quick Check In module offline mode. 0 – Disable 1 – Enable |
Auto Refresh People Count |
Enabling this parameter will impact the performance and it ‘disable’ by default. 0 –Disable else set number of second to refresh the people count |
Allow Crew Card Login Bypass |
Allows crew to login by scanning the crew card provided the credential is valid in Mobile Database. |
Allow not expected guest to check-in |
0 – Do not allow expected guest to check-in 1 – Allow not expected guest to check-in. |
AutoCheckOutCrw |
Auto check out crew after card swipe for going offshore. 0 – Disable 1 – Enable |
AutoCheckOutPax |
Auto check out passenger after card swipe for going offshore. 0 – Disable 1 – Enable |
Check Document Returned |
Flag to check whether the pax document is returned during gangway movement. 0 – No checking 1 – Check disembark pax document. 2 – Check transit and disembark pax document |
Check Message |
0 – Disable message checking 1 – Enable |
Check Visitor Card |
0 – No checking performed. 1 – Check on the validity of visitor card; |
Check-in Message Popup Duration |
Number of milliseconds the auto check in message is shown. |
Check-in via OHC Security |
0 – Disable check in via OHC Security. 1 – Enable |
Custom SQL to show additional info for crew |
N/A |
DCL corporate card facility code |
Null –Accepts all cards; card must match the facility code |
Default Queue Workstation |
Default chips workstation ID. Reference to TYP_QST. |
Disable Search Grid Drag/Drop |
Disables the ability to rearrange columns using drag/drop. |
Disable Visual Keyboard |
Disables the display of the visual keyboard. |
Disable/Enable Phone when pax shoreside/onboard |
Allows phone to be disabled/enabled when passenger goes ashore or onboard. |
Eliminate OHC Security Login |
When enabled, it will eliminate the OHC Security Log-ins when Disabling Cards. 0 – Disable 1 – Enable |
Enable Auto Quick Balance |
1 – Enable Auto Balance for guest with credit cards Register |
Enable Handicap Assignment |
0 – Disable 1 – Enable Accessibility Assignment |
Enable Immigration Gate |
0 – Disable the access to Immigration Gate. 1 – Enable |
Enable Internal Gate |
0 – Disable the access to Internet Gate. 1 – Enable |
Enable Minor Disembarkation Authorization |
0 – No Authorization is require for Minor, 1 – Authorization of guardian company is required |
Enable Tender Option |
0 – Disable Tender Option. 1 – Enable option for Gangway to serve tender/ |
Exclude Port from Minor Dis Authorization |
Specify the ports of call a minor is authorized to debark un-escorted. For example 'AtSea', 'AtSea1' |
Exit Application Without Prompt Password |
1 – Exit Application Without Prompt Password |
Extended Search Criteria |
It can be any VarChar2 or Char field from RES and UXP table. |
Extended Search Criteria Check-in |
0 – Extended Search Criteria at gangway is disabled. 1 – Passengers will be checked in when found. 2 – Passengers will be allowed onboard but not checked in. |
Gangway Location Functionality |
The value determine whether to prompt the Gangway Location window at logon. 0 – Not used 1 – Used |
Grid Font Size |
Specifies the Font Size of the Search Grid |
Grid Refresh Duration |
Number of seconds to auto-refresh the Grid data |
Picture Taking Functionality |
0 – Disable picture taking functionality. 1 – Enable |
Prompt Message When Crew Disembark Today |
1 – Prompt Message when Crew Disembark Today |
SLD Manual Override |
Prompts a message to override shore leave denied message if no Time and Attendance validation. 0 – No overriding 1 – Prompt override SLD message, |
Show Check-in Cabin Person Count |
0 – Do not show other guest. 1 – Show other guest |
Show Other Guest with Same Booking Number |
Tender Threshold Count |
Threshold Count that triggers a warning. |
Update Visitor Name |
0 – Do not overwrite 1 – Overwrite existing visitor name during passport scanning |
Use Ashore Denied Message |
0 – Do not use denied message in Ashore/Onboard Denied function. 1 – Use |
Use ON/OFF Icon |
0 – Do not use on/off Icon. 1 – Use On/Off Icon |
