6 FEIG OBID RFID Encoder
Prerequisites Certifications and Compatibility for FEIG RFID OBID
This section describes the minimum requirements for the FEIG RFID OBID encoder Installation module in SPMS.
Obtain the following program executable from FEIG or your local vendor.
OBID driver: setup_cprusbio_v2.50 (build 20130214)
Card reader driver: ID_CPRStart2014_V090701.msi
Download Visual C++ runtime from Microsoft’s website.
Vcredist_x86.exe (8.0.50727.6195)
Compatibility
SPMS version 20.1 or later. For customer operating on a version below 20.1 database upgrade to the recommended or latest version is required.
Installing FEIG OBID RFID Encoder
This section describes the steps to set up the FEIG OBID RFID Encoder for use in SPMS.
Run the vcredist_x86.exe (version 8.0.50727.6195) to install.
Follow the steps in the setup wizard to complete the installation.
FEIG OBID RFID Driver Installation
Run the setup.exe of the folder setup_cprusbio_v2.50 (build 20130214) to install.
Apply the card reader driver patch by running the ID_CPRStart2014_V090701.msi.
From OHC Launch Panel, press F12 to start the upload to Special Applications.
Upload:
fecom.dll
FedmIscCoreVC80.dll
FedmIscMyAxxessVC80.dll
fefu.dll
feiscl.dll
fetcl.dll
fetcp.dll
feusb.dll
OBIDISC4NET.dll
OBIDISC4NETnative.dll
