11 Maintenance Code Setup
In the Maintenance Code feature, you can customized the locations, task codes, work order type used, workers within the workgroup, items used for repair and maintenance and the priority order for the task.
The steps to configure the codes below are the same while other codes such as Workers in Workgroup, Task Code, and Items require more steps.
  • Location Codes: Define the location that requires maintenance work outside the cabins.
  • Work Order Type: Define the type of maintenance work required.
  • Priority: Define the work order priority.
  • Location Usable Status: Define the location availability.
Setting Up Maintenance Codes
Figure 11-1 Maintenance Locations Setup
This figure shows the set up window of Maintenance Locations.
  1. From the Maintenance Setup menu, select the Locations.
  2. Right-click the left pane and select Add New.
  3. Enter a code, description, and comment.
  4. Click OK to save
You can also use the Customized Location as a sub-category, to further define the location, for example, vending machine at bar area, open shower at Pool Deck.
  1. From the Maintenance Setup menu, select the Customized Locations.
  3. Enter a code, description and comment.
  4. Click Apply to save.
  5. Right-click the newly created location and select Add Location or Add Category, depending on your requirement.
  6. Enter a code, description and comment.
  7. Check the Crew Supervision Assignment if that task requires supervision.
  8. Click OK to save.
The Worker in Workgroup is a sub-category of Work Order Type, where workers are grouped according to their skills and expertise.
  1. Select Workers in Workgroup from the Maintenance Setup menu.
  2. Right-click and select Add Group.
  3. Enter a code, description, and comments.
  5. Right-click on the newly created code and select Add Worker.
  6. Select to Assign by Crew or Assign by Operation Position, then select the crew name or position from the Name field.
  7. Enter a description and click Apply to save.
  8. Click OK to close the window.
Adding Task Code
The Task Code is used to define the required task, crew involved, and task priority.
Figure 11-2 Maintenance Task Codes
This figure shows the Maintenance Task Codes Setup window.
  1. Select Maintenance Task Code Setup from the Maintenance Setup menu.
  2. Right-click and select Add New.
  3. Enter a code, description, and comments, and then select the Work Types, Work Group and Priority from the drop-down list.
Adding Items Code
The Item codes is used to describe the items required for repair work. You can add a cost and inventory to the items.
Figure 11-3 Maintenance Item Setup
This figure shows the setup window of Maintenance Items
  1. Select Items from the Maintenance Setup menu.
  2. Right-click on the left pane and select Add Item Type.
    Figure 11-4 Maintenance Item Type
    This figure shows the setup window of Maintenance Item Type
  5. Right-click on the newly created item code and select Add Item Type.
  6. Enter the Item Code, Description, Average Price, and Stock On Hand.
  7. Click OK to save.
