Prerequisites, Supported Systems and Compatibility
This section describes the minimum requirements for the Mobile Mustering module.
Prerequisites
Mobile Mustering.exe version 8.0.6
WPFDash.exe
Complete set up of the Mobile Mustering and Gangway Security Application Server and the requirements listed in the Mobile Mustering and Gangway Security Installation Guide.
Supported Operating System/Technology
See Compatibility Matrix at http://docs.oracle.com/en/industries/hospitality/.
Does not support Barcode/RFID scanning.
Supported Hardware
Oracle MICROS 721 Tablet.
Windows Mobile device with a camera.
Compatibility
SPMS version 20.2 or later. For customers operating on version 20.2 and below, database upgrade to the recommended or latest version is required.
