6 Reports
The Report function gives you the option to view, print or export all the reports available in the system.
Click the Reports button at the ribbon bar to view all the available reports.
Expand the report group and select the desire report.
At the Print tab, select the Printer and the number of copies to print.
To preview the report before printing, go to the Preview tab.
At the ribbon bar, you can perform these functions by selecting Export, Custom Excel Export, or Search Report, or close the screen.
