3 WPF Security
The WPF Security login window can display the type of Gate and Traffic direction according to the ships operational needs. This is determined by the Exit Application Without Prompt Password and Gangway Location Functionality parameters.
Begin the WPF Security application and at the Gate Settings dialog box, select the type of Gate, Traffic Direction, and Gate Location.
Figure 3-1 WPF Security Gate Settings
Table 3-1 Gate Settings Type
Gate Type/Direction Description Gangway
The Gangway gate is used by passengers and crew when boarding/alighting the ship. The system maintains a running count of passengers and crew that are currently onboard and at shore side.
Internal Gate
The Internal Gate is usedby Department Head/Training Manager to monitor the crew training attendance and movements in restricted area or shore duty. The in/out entries through the gate are updated except the shipboard status.
Immigration Gate
The Immigration Gate is used to facilitate the immigration process by swiping the passenger’s board card in and out for Immigration inspections. The Immigration information is updated except for shipboard status.
Both Way
Used for passengers and crew going ashore and coming on board.
Outwards
Used for passengers and crew going ashore only.
Inward
Used for passengers and crew coming onboard only.
Click OK to access the main menu.
At the Login prompt, enter the user name and password or click Exit to access the Main menu.
The selected gate, traffic direction and location appear below the toolbar of the main window. Clicking the Close Program prompts a Security Logon dialog box. You must enter your login credential before you can close the program. You can disable the dialog box by setting the Exit Application Without Prompt Password=1 parameter.
Figure 3-2 WPF Security Toolbar
Navigating through WPF Security Main Functions
As the program predominantly records passenger movement through the gangway, the functionality in this program is scaled down to minimize the queue from building up. The functions in this module are a Refresh Count, Gangway Log, Visitor and Accessibility Handling, Immigration Gate handling, and others.
Figure 3-3 WPF Security Main Functions
Table 3-2 Field Description of WPF Security Main Functions
Function | Description |
Refresh Count |
Recalculates and updates the total counts of the Account Statistics Board. |
Gangway Log |
Starts the Gangway Log window, which allows the Security Officer to view or search the gangway activities when necessary. |
Visitor |
Starts the Visitor window and enables the Security Officer to enter the visitor’s information, produce a visitor card, and track the visitor onboard/ashore status. |
Accessibility |
Allows the Security Officer to assign an accessibility status for passenger with disabilities who comes onboard. |
Take Picture |
Allows the Security Officer to take the picture and store the picture of a selected account in the system. |
Close Program |
Closes the WPF Security program. |
Account Status Board |
Onboard |
Total Passenger/Crew/Resident currently on-board the ship. |
Shoreside |
Total Passenger/Crew/Resident currently at shore. |
Overnight Tour |
Total Passenger/Crew/Resident currently on shore for overnight tour, which includes Crew accompanying passengers for overnight tour. |
Expected |
Total number of Passengers/Crew/Residents expected to check in today. |
Disembarked |
Total Passenger/Crew/Resident disembarked today. |
Disembarking |
Total PassengersCrew/Residents expected to disembark today. |
Visitor Onboard |
Total number of Visitors currently onboard. |
Information Board |
Onboard / Ashore |
The Onboard or Ashore Information board shows the account information by name, sex, nationality, photo, last event log, and other information when someone goes onboard from shoreside. Double clicking the board will show the account, allowing the Security Officer to search and change account status from onboard to ashore. |
Gangway History Activity |
Displays the last 10 movement activities with account name and photo. |
Status Bar |
Ship |
Current Ship’s name. |
Sys Date |
Current Ship’s SPMS system date. |
PC |
PC name of current gangway workstation. |
DSN |
SPMS Database name. |
Reader |
Card reader device currently connected to the gangway workstation. |
CO Guest Enabled |
Denotes “Gangway”, “AutoCheckOutPax” parameter is enabled, allowing you to check-out a passenger account by swiping the board card. |
CO Crew Enabled |
Denotes “Gangway”, “AutoCheckOutCrw” parameter is enabled, allowing you to check-out a crew account by swiping the board card. |
Light bulb image |
Database connectivity status. Green denotes online, and Red denotes offline. |
