2 AQCI Functions
The Advance Quick Check In (AQCI) module is designed to ease the check-in process using the quick passenger registration and collection of passport details, and by printing the Board Card at the end of the process. All these processes are performed from the Home Tab.
Figure 2-1 AQCI Functions
Created a New Reservation
A vast majority of guests arrive with confirmed reservations. However, there are instances where new reservations are added on the spot.
Click New at the ribbon bar.
At the Reservation Form, enter all the relevant details manually or scan the passport through the passport scanner.
Select the Notice and Consent check-box. If this is left unchecked, the system prompts a warning message and prevents you from continuing.
Click Save on the ribbon bar to save the reservation. The newly created reservation is grouped under the Expected reservation category.
Renewing a Reservation
Search for the passenger account in the Account Search section, select Reserv Status as History, and select the past Embark Date using the date editor.
In the results grid, select the passenger name, update the passenger details, select a cabin from the available cabin list, and click Renew at the ribbon bar.
At the Information has been changed. Do you want to save? prompt, select Yes to complete the process.
Route
At Account Search section, search for the guest account and select the desired account by holding the CTRL+ key or SHIFT+ key.
At the ribbon bar, click Route and select the account to route. The first account you select is the Payer, and the Payer account is tagged with the letter P. The Routed account is tagged with the letter R.
To cancel the routing, select the account and click Cancel Route on the ribbon bar.
Figure 2-2 Route Function
Take Picture
The Take Picture function allows you to recapture the picture of the pre-embark guest or for a new reservation. To take a picture, select the account and click Take Picture at the ribbon bar.
Check In
The Check In function checks in the select account(s) and changes the booking status from Reservation to Embark when all passenger information is corrected and updated accordingly.
The system validates the guest mandatory fields based on defined Coast Guard agency requirements in Administration, System Setup, Database Parameter Setup, General, APIS Border Custom Handling. For example, if the parameter value is CARICOM, the system validates guest mandatory fields based on parameter CARICOM, Mandatory Fields For <NONCREW>.
Search for the account using the selection filters in Account Search section.
Select the account and click Check In at the ribbon bar. The system does not allow a check-in into a dirty cabin.
Print Board Card
At the selected account, click Print Board Card on the ribbon bar.
Select the Print Board Card reason when prompted and click OK. This encodes a card that includes the door lock combination, depending on the type of door lock interface, and the guest details such as cabin number and the embark/disembark date.
Print Passport Label
The Print Passport Label prints an identification label tagged to the passenger’s passport. You must configure the supported hardware in Setup, General Setup, Printer, Passport Label Printer. You can also configure the same in Management module, Options, Hardware, Printer. Consult Oracle Customer Support for supported hardware or assistance.
Return Key
The Return Key function allows the Check-in agent to request a key (board card) for a passenger during embarkation from a central location where the keys are stored. This additional printing process handling speeds up the check in process by allowing the Key Runner to pull out the key for those passengers, based on the requests stated on the printed receipt.
These keys are physically handed to the respective Check-in agent. To use this function, you must turn on parameters in Administration module, System Setup, Database Parameter Setup, Enable Key Runner Remote Printing and Auto Print Key Runner Receipt.
Edit the passenger’s passport number.
Edit the passenger’s credit card information.
Scan the Booking Number barcode.
Auto Print Key Runner Receipt = 1
Extend Search Criteria = RES_BOOKNR
When searching for a guest, change the search criteria to Same Booking No. If three guests with same booking number and same cabin are found, a single Key Runner Receipt is printed. For three guests with different cabins, three different Key Runner receipts are printed.
Guest with the same embarkation date and cabin are printed in a single Key Runner receipt.
You must configure the Key Runner printer in General Setup, Printer, Key Runner Printer and select the required printer from the drop-down list.
The Return Key is re-enabled at the ribbon bar of the Check In screen once the receipt is printed for the passenger. The receipt prints only once for the same cabin unless the Return Key is clicked to reset the key status. This would then allow you to send the key request again to the Key Runner.
Figure 2-3 Key Runner Request
Check In Status
You can view the total number of Reservations, Checked-In, and Remaining status of the guests that have not checked-in based on the current date and time.
Copy/Paste Address
The Copy Address function allows you to copy the address from one reservation to another reservation which saves data entry time when both reservations share the same address.
At the Passenger Details screen of the selected account, click Copy Address on the ribbon bar.
Select the account to copy to and click Paste Address.
Swipe Passport
The Swipe Passport function allows you to capture the passenger’s passport details by swiping the passport through a passport scanner instead of manually entering the details. This requires a configured passport reader in General Setup, Hardware, Card Reader section.
