7 Language Template
The Language Template option enables you to configure the languages needed to setup the questionnaire template, and the Questionnaire page in the Check-In application.
The Language Template option can be found in the Administration menu, Enterprise, Language Template.
Search and Enable the Language
Figure 7-1 Language Template
Navigate to the Language Template option where the system displays all language records from the database with disabled status on first time setup.
Search the language by entering the language name or language code at the search field and select the Search button.
If no matching record is found, the system displays the message, “No data to display.”
To enable/disable the language, toggle the Status button on the language that you want, and the system displays the notification, “Language updated successfully.”
To view the enabled language record, deselect the Show Inactive check box.
