26 Confiscated Item
Figure 26-1 Confiscated Item
The Confiscated Item page provides the security officer a list of items checked- in by the guest, visitor or crew during embarkation, which the guest is allowed to check out for/from an excursion. After the guest passes all the validations, the system will prompts a list of returnable items when the guest goes ashore or comes onboard.
The Security officer has an option to return/collect the selected items by checking the check boxes, then select the Return/Collect button or Cancel if there is no item to be returned/collected from the guest.
