27 Movement History
The Movement History function allows you to look up past movement records.
Figure 27-1 Movement History Page
Movement History Search
From the List menu, select Gateway Security menu, and then the Movement History sub-menu.
On the Movement History page, search the record by name (either first name, middle name, or last name) and/or stateroom.
Enter the value in the search box.
Select the Search button.
Movement History Advanced Search Page
On the Movement History page, select Go to Advanced Search. See the available fields below.
On the Advanced Search page, search using the manual entry or select from the list the values in the Search box.
Click the Search button.
Location: The gate location that the passenger used to come aboard or go ashore.
Direction: Indicates the gate direction used by the passenger (onboard, ashore).
Start Date-Time: Date and time the passenger embarked or disembarked from the ship through the gateway.
End Date-Time: Date and time the passenger embarked or disembarked from the ship through the gateway.
Profile Type: Profile Type to be searched: guest, crew, and so on.
Name: The first name, middle name, and last name of the passenger.
Stateroom: The Stateroom number of the passenger.
Tender Boat: Tender boat code of the passenger used to come aboard or go ashore.
