15 Guardian
Manual Search: Search for a guardian profile manually by entering the First Name, Last Name, and other relevant information. The search criteria fields can be watermarked from the Check-In – Search Template setup.
Scanning RFID Card: Search for guardians using their RFID cards. See section Search by Scanning RFID Cards
Travel With: Retrieves all guest profiles that have the same booking or stateroom number.
Figure 15-1 Search and Add Guardian Page
To add a guardian, select the guardian profile using the +Add button from the returned result page or scan the guardian RFID card. See section Search by Scanning RFID Cards
Figure 15-2 Assigned Guardian List
To remove a guardian, in the Guardian section, select the guardian profile and then click the X of the selected profile.
Once you have confirmed the Guardian Information, click Next to complete the Guardian page.
