1 Parameters
This section describes the Parameters available to Service Charge module.
Table 1-1 PAR_Group Hotel Bar Svc Chg
PAR Name | Value | Description |
BSC Special Positions |
<Operational Position> |
Specify the positions that needs to be included for daily minimum guarantee deduction. Value is linked to OPO_ID. |
BSC Special Positions - Pool 1 to Deduct From |
<Integer> |
Specify the first Pool ID and Percentage to deduct daily guaranteed for Beverage Management. For example: Value is 89.00. This means 89% for the Special Positions is deducted from the Service Charge Pool. |
BSC Special Positions - Pool 2 to Deduct From |
<Integer> |
Specify the second Pool ID and Percentage to deduct daily guaranteed for Beverage Management. For example: Value is 11.00. This means 11% for the Special Positions is deducted from the Service Charge Pool |
Mid Cruise Breakage |
2.0 |
Mid Cruise Breakage in percentage, for example 2.0. |
Pool to Deduct Premiums |
<Pool Name> |
Name of the Service Charge Pool to deduct the premiums. This is normally use for Hotel Service Charge Pool. |
Service Charge Eligible End Date |
-1 |
Number of days with reference to crew repatriation date. 0 - if the service charge entitlement is up to and includes the repatriation date; -1 - if entitlement is until the day before the repatriation date. For example: Update crew expected debarkation date = 11/11/2011
Table 1-2 PAR_Group Promo
MICROS Server Name |
MICROS Database Service Name |
MICROS Server Type |
0 |
0 - Oracle, 1 - Microsoft SQL Server |
MICROS User Name |
MICROS User Name |
Table 1-3 PAR_Group General
Use Payroll |
0, 1 |
0 - Service Charge module not dependent on Payroll module. This parameter enables the Paid/Not Paid button in Service Charge module. 1 - Service Charge module is dependent on Payroll module. |
