Preface
The Mustering application is a front-end application that radically cuts emergency passenger-handling time with the use of electronic hand-held devices. This new application enables cruise operators to manage the emergency mustering process by tracking each individual passenger and crew member, whilst simultaneously keeping officers on the bridge fully informed of the progress.
This application not only reduces human error on manual passenger/crews’ registration at the designated mustering station, it also speeds up the process by 50%. The software uses the Radio Frequency Identification (RFID) scanning technology to scan the crew, visitor, or passenger’s board card.
This enables the mustering process to be tracked in real time, reporting to the bridge progressively throughout the procedure. Both routine and emergency modes are available and crew in charge of the muster stations can readily identify if any of the passenger is missing and instinctively search for them at other muster stations.
Audience
This document is intended for application specialist, IT Officers and end-users of Oracle Hospitality Cruise Shipboard Property Management System.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
October 2023 |
Initial publication. |
March 2024 |
Added topic Resumed Network Connection/Download File. |
