Preface
The Mustering application is a front-end application that radically transform emergency passenger-handling time by leveraging cutting edge electronic hand-held devices.
With the ability to track passengers and crew member in real-time, it empowers cruise operators to manage the emergency process more efficiently while keeping officer on the bridge fully updated on the process. This powerful application reduces manual errors in passenger and crew registration, speeding the process by 50% with the use of Radio Frequency Identification (RFID) to scan the boardcard.
Audience
This document is intended for application specialist, IT Officers and end-users of Oracle Hospitality Cruise Shipboard Property Management System.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
October 2024 |
Initial publication. |
April 2025 |
May 2025 |
G12860-03 - No changes, republication for Search utility |
July 2025 |
Restructure topic hierarchy, update styles and formatting |
