4 Functions
This following sections describes the OHCWebservices functions with their required parameters and return values.
ActivateCreditCard
This function activates the credit card of the guest.
Input Parameters
psFunction=“DeactivateCreditCard.” – below is the list of psParam or poParam.
Table 4-1 psParam
Parameter Type Description Required
pnCrdID
Integer
Unique Credit Card ID.
Yes
pbAssignInvoice1
Boolean
Assign the Credit Card to Invoice 1.
Yes
pbAssignInvoice2
Boolean
Assign the Credit Card to Invoice 2.
Yes
pbAssignInvoice3
Boolean
Assign the Credit Card to Invoice 3.
Yes
pbAssignInvoice4
Boolean
Assign the Credit Card to Invoice 4.
Yes
Return Values
CResponseXml.bSuccess = False when Update failed.
CResponseXml.bSuccess = True when Update successful.
Example:
oResponse = goWS.FidelioSPMSWSXML("ActivateCreditCard", "SessionID", New Object() {12345, True, True, True, True})
AddHKTask
This function adds a new housekeeping task created externally into the SPMS database.
Note: Not supported when it is connected to an offline QCI Sync database.
Input Parameters
psFunction=“AddHKTask” — below is the list of psParam or poParam
Table 4-2 psParam
pdTaskDate
Date
Housekeeping Task Date.
Yes
psCabin
String
Cabin Number.
Yes
psLocation
String
Location
Yes
pnStatus
Integer
0-Pending, 1-Started, 2-Completed.
Yes
pnCrewID
Integer
Task assigned to this Crew ID.
Yes
pnTaskID
Integer
Housekeeping Task ID.
Yes
pnPortID
Integer
Port ID.
Yes
psComment
String
Task Comments.
Return Values
CResponseXml.bSuccess = False when AddHKTask has failed.
CResponseXml.bSuccess = True when AddHKTask is successful.
For Example:
oResponse = goWS.FidelioSPMSWSXML("AddHKTask", "Session ID", New Object() {DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified), <Cabin>, <Location>, 0, 123, 2, 123, <Comments>})
AddRouting
This function allows you to add routing.
Please take note that we support both: all department route from passenger A to passenger B, and specific department route from passenger A to passenger C.
The individual department routing always take priority
For JSON, the array of string will be a string separated by comman (“,”). Each string must start and end with a double quotation mark (“).
For example:
“A,”””,”B,” = 2 Element
Element 1 = A,”
Element 2 = B,
Input Parameters
psFunction=“AddRouting” — below is the list of psParam or poParam.
Table 4-3 psParam
pnBuyer
Integer
Unique Buyer Account ID.
Yes
pnPayer
Integer
Unique Payer Account ID.
Yes
pnWindow
Integer
Invoice Window (0 to 3) only.
Yes
psNote
String(40)
Reason of the routing.
Yes
psDept
Array of String(10)
Array of department.
Yes
Below are the descriptions of the parameters.
pnBuyer
pnPayer
pnWindow
Invoice Window. Valid value 0 to 3 and the default is 0. If the buyer and payer are the same, then the valid value is 1 to 3.
psNote
Reason of the routing. The field can be empty.
psDept
An array of department. If the routing is all department, please pass in nothing or an empty array. Please note that if the department passed in does not exist, it will skip and returns no error.
Return Values
CResponseXml.bSuccess = False when Add Routing failed.
CResponseXml.bSuccess = True when Add Routing successful.
Example:
oResponse = goWS.FidelioSPMSWSXML("AddRouting", "SessionID", New Object() {12345,12346,0,"Testing",New String() {"9011","9012"}})
AdvanceGuestSearch
This function searches for a guest with various criteria from the SPMS system
Input Parameters
psFunction=“AdvanceGuestSearch”— below is the list of psParam or poParam.
Table 4-4 psParam
psCabCategory
String
Cabin Category.
Yes
psNationalty
String
Nationality.
Yes
psVipStatus
String
Guest Classification.
Yes
psPosDiscountLevel
String
Loyalty Discount Level.
Yes
pnGrpID
Integer
Group ID.
Yes
peGuestType
GuestType
Guest Type Enumerator.
Yes
peReservationType
ReservationType
Reservation Type Enumerator.
Yes
pdDate
Date
Embarkation Date.
Yes
Pnscdid
Integer
Current port ID.
Optional
Peonboardstatus
OnboardStatus
0 – all.
1 – onboard.
2 – shoreside.
Optional
psCabCategory
Search guests with specified cabin category. Enter a blank to skip this criteria.
psNationality
Search guests with specified nationality. Enter a blank to skip this criteria..
psVipStatus
Search guests with specified classification. Enter a blank to skip this criteria.
psPosDiscountLevel
Search guests with specified POS Discount Level. Enter a blank to skip this criteria.
pnGrpID
Search guests with specified group. Enter 0 to skip this criteria.
peGuestType
(Enumerator)
Guest
0
Search guests matching search criteria
Crew
1
Search crews matching search criteria
Visitor
2
Search visitors matching search criteria
All
3
Search guests, crews, visitors matching search criteria
peReservationType
(Enumerator) Reserve = Search only passenger with reservation status. Note: Visitors remain at reservation status only.
Reserve
0
Reservation passenger
CheckIn
1
Search only passenger that had check-in
All
2
Search both check-in and reserve passenger
CheckOut
3
Search check-out passenger only
ReserveFCManagement
4
Reservation passenger, for shore viewer
CheckInFCManagement
5
Search only passenger that had check-in, for shore viewer
CheckOutFCManagement
6
Search check-out passenger only, for shore viewer
Cancelled
7
Canceled reservation passenger.
pdDate
Embarkation date, if you want to search for all guest regardless of the embarkation date, pass in #12:00:00AM#
Return Values
CResponseXml.bSuccess = False when input values are invalid or no record found.
CResponseXml.bSuccess = True and CResponseXML.oTables(0) = ADO.NET data table when input values are valid. The data table will contain all fields in uxp and res table, see SPMS Data Dictionary for details of the data fields.
Example:
oResponse = goWS.FidelioSPMSWSXML("AdvanceGuestSearch", "SessionID", New Object() {"D04","","","",0,3,0, #01-01-2011#})
AmenityCompleted
This function updates the amenity status as “Completed.”
Input Parameters
psFunction=“AmenityCompleted” — below is the list of psParam or poParam.
Table 4-5 psParam
pnAmeID
Integer
Amenity Unique ID.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("AmenityCompleted", "SessionID", New Object() {12334})
ApproveCrewWorkedHoursDaily
This function approves the Crew Worked hours for a specified date.
Input Parameters
psFunction=“ApproveCrewWorkedHoursDaily” — below is the list of psParam or poParam.
Table 4-6 psParam
pnAccID
Integer
Unique Crew Account ID.
Yes
pdDayToApprove
Date
Date of the worked hours to be approved.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("ApproveCrewWorkedHoursDaily", "SessionID", New Object() {12345, DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified)})
ChangeBoardStatus
This function toggles the onboard/offboard status of the passenger.
Input Parameters
psFunction=“ChangeBoardStatus” — below is the list of psParam or poParam.
Table 4-7 psParam
pnAccID
Integer
Unique Account ID.
Yes
pbSwipe
Boolean
True, the information is captured using swipe card,
False, the information is manually entered.
Yes
pbResponseYes
Boolean
Default response to confirmation message.
Yes
pnAccID
Unique Account ID.
pbSwipe
True, the information is captured through a card swipe.
pbResponseYes
The default response to the confirmation message, including the Defined Security Action message prompt. For example,
  • Warning! Resident is NOT expected today. Are you sure you want to check in?
  • Do you want to Check-In <Guest Name>?
  • This person is on duty and ashore denied, do you want to override the onboard status?
  • This person is ashore denied, do you want to override the onboard status?
Return Values
CResponseXml.bSuccess = False when Status change failed.
CResponseXml.bSuccess = True when Status change successful.
In both instances, CResponse.oObj returns the guest onboard status 0 – Onboard, 1- Shore Side.
Example:
oResponse = goWS.FidelioSPMSWSXML("ChangeBoardStatus", "SessionID", New Object() {123456, True, True})
ChangePassword
This function changes the user password.
Input Parameters
psFunction=“ChangePassword” — below is the list of psParam or poParam.
Table 4-8 psParam
psOldPassword
String
Plain Text Password.
Yes
psNewPassword
String
New Password in plain text.
Yes
psOldPassword
Plain text password
psNewPassword
Plain text password
Return Values
CResponseXml.bSuccess = True when change password is successful.
CResponseXml.bSuccess = False when change password has failed.
CheckCabinAvailable
This function checks the cabin availability for the specific booking date.
Input Parameters
psFunction=“CheckCabinAvailable” — below is the list of psParam or poParam.
Table 4-9 psParam
psCabin
String
Cabin Number.
Yes
pdEmbDate
Date
Embarkation Date.
Yes
pdDisDate
Date
Disembarkation Date.
Yes
pnAccID
Array of Integer
Array of Unique Account ID.
Yes
Return Values
CResponseXml.bSuccess = False when Cabin is not available, the reason will be returned as an error message.
CResponseXml.bSuccess = True when Cabin is available.
Example:
oResponse = goWS.FidelioSPMSWSXML("CheckCabinAvailable", "", New Object() {"05002", DateTime.SpecifyKind(#1/1/2011#, DateTimeKind.Unspecified),_DateTime.SpecifyKind(#2/1/2011#, DateTimeKind.Unspecified),12334})
Checkin
This function checks in the expected guest into the SPMS system.
Input Parameters
psFunction=“CheckIn” — below is the list of psParam or poParam.
Table 4-10 psParam
pnAccID
Integer
Unique Guest ID.
Yes
pnAccID
This is the SPMS Guest Unique ID; this value can be retrieved using GuestSearch function. The field name is UXP_A_ID.
Return Values
CResponseXml.bSuccess = True when check-in is successful.
CResponseXml.bSuccess = False when check-in has failed.
Returns True when check-in is successful.
Returns False when check-in has failed.
The UpdateGuestInfo must be called before the CheckIn function. This is because the CheckIn function will also update the guest record and may overwrite any previous updates. If a CheckIn is called before UpdateGuestInfo, another call to GuestSearch must be made again before an update is allowed.
Example:
oResponse = goWS.FidelioSPMSWSXML("CheckIn", "SessionID", New Object() {12345})
CheckSag
This function allows the client to check for custom Gangway alert information.
Input Parameters
psFunction=“CheckSag” — below is the list of psParam or poParam.
Table 4-11 psParam
pnAccID
Integer
Unique Account ID.
Yes
pbShoreToShip
Boolean
True-From Shore to Ship,
False from Ship to Shore.
Yes
Return Values
CResponseXml.bSuccess = Always return True
CResponseXML.oObj(0)
0-Allow Pass
1-Allow Overwrite
2-Denied Pass
CResponseXML.oObj(1)
Message to show the guest.
Example:
oResponse = goWS.FidelioSPMSWSXML("CheckSag", "SessionID", New Object() {12345, True})
ClockInMobile
This function allows a clock-in transaction.
Input Parameters
psFunction=“ClockInMobile” — below is the list of psParam or poParam.
Table 4-12 psParam
pnAccID
Integer
Yes
pnWorkCodeId
Integer
Task Work Code ID. TARS_ID
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("ApproveCrewWorkedHours", "SessionID", New Object() {12345, 2})
ClockInOutGetStatus
This function retrieves the last clock-in/out transaction of the crew.
Input Parameters
psFunction=“ClockInOutGetStatus” — below is the list of psParam or poParam.
Table 4-13 psParam
psBoardCardNo
String
Crew boardcard number (RES_BOARDCC)
Either psBoardCardNo or pnAccID is required.
pnAccID
Integer
Return Values
CResponseXml.bSuccess = True when Update successful, CResponse.oDataset will have 1 Data Table.
Table 4-14 ADO.NET Data Table field structure for data table (“CLOCKINOUT_STATUS”)
Code Type Description
TARS_ID
Integer
Unique task work code ID.
TARS_CODE
String
Task work code.
TARS_NAME
String
Task work name.
TCLK_DATETIMESTAMP
Date
Clock-in/out datetime stamp.
TCLK_IN_OUT
String
‘I’ for clock-in, ‘O’ for clock-out.
CRW_NAME
String
Last Name.
CRW_FSTN
String
First Name.
CRW_DIV
String
Department.
CRW_STAFF_POS
String
Position.
RES_CAB
String
Cabin Number.
Example:
oResponse = goWS.FidelioSPMSWSXML("ClockInOutGetStatus", "SessionID", New Object() {“12345”, 0})
ClockOutMobile
This function allows a clock-out transaction.
Input Parameters
psFunction=“ClockOutMobile” — below is the list of psParam or poParam.
Table 4-15 psParam
pnAccID
Integer
Yes
pnWorkCodeId
Integer
Optional, if 0 then will use the last clock-in task work code ID.
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("ApproveCrewWorkedHours", "SessionID", New Object() {12345, 0})
This function deactivates the credit card for the guest.
Input Parameters
psFunction=“DeactivateCreditCard” — below is the list of psParam or poParam.
Table 4-16 psParam
pnCrdID
Integer
Optional
pnAccID
Integer
Unique Account ID.
Optional
Either pnCrdID or pnAccID must be pass in a valid value.
pnCrdID > 0 mean deactivate single credit card record.
pnAccID > 0 mean deactivate all credit card belong to the guest.
If both pnCrdID > 0 and pnAccID > 0, we will deactivate a single credit card record base on pnCrdID.
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("DeactivateCreditCard", "SessionID", New Object() {12345,0})
DeleteAmenity
This function deletes the guest amenity.
Input Parameters
psFunction= “DeleteAmenity” — below is the list of psParam or poParam.
Table 4-17 psParam
pnAmeID
Integer
Unique Amenity ID.
Yes
Return Values
CResponseXml.bSuccess = False when Delete failed.
CResponseXml.bSuccess = True when Delete successful.
Example:
oResponse = goWS.FidelioSPMSWSXML("DeleteAmenity", "SessionID", New Object() {12345})
DeleteComment
This function deletes the guest comment.
Input Parameters
psFunction= “DeleteComment” — below is the list of psParam or poParam.
Table 4-18 psParam
pnCplID
Integer
Unique Guest Comment ID.
Optional
pnCplLinkID
Integer
Guest Comment Link ID.
Optional
You must pass in either pnCplID or pnCplLinkID.
If pnCplLinkID > 0 mean it will delete all comments including the resolution for the same link ID.
If pnCplId > 0 then it will only delete the single comment (only the comment will be deleted)
Return Values
Example:
oResponse = FidelioWS("DeleteComment", New Object() {1234,0})
DeleteGuestMessage
This function deletes the guest message.
Input Parameters
psFunction= “DeleteGuestMessage” — below is the list of psParam or poParam.
Table 4-19 psParam
pnMsgID
Integer
Unique Message ID.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("DeleteGuestMessage", "SessionID", New Object() {12345})
This function removes the luggage link for the guest.
Input Parameters
psFunction= “UpdateRFIDEncoded” — below is the list of psParam or poParam.
Table 4-20 psParam
psRFIDUID
String(16)
Convert the value to HEX.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("DeleteLuggageLink", "SessionID", New Object() {”E01581A07C123B”})
DeleteResolution
Input Parameters
psFunction= “DeleteResolution” — below is the list of psParam or poParam.
Table 4-21 psParam
pnCplLinkID
Integer
Yes
Return Values
Example:
oResponse = FidelioWS("DeleteResolution", New Object() {1243})
DeleteRouting
This function deletes the routing, you can either delete all routing or delete individual department routing. Deleting all routing also deletes all individual department routing.
For JSON, the array of string will be a string separated by “,”, and each string must start and end with a double quotation mark (“).
For example,
Element 1 = A,”
Element 2 = B,
Input Parameters
psFunction= “DeleteRouting” — below is the list of psParam or poParam.
Table 4-22 psParam
psSearchStr
String
Unique Buyer Account ID or
Board Card or
PGID or
Pax ID depends on the peSearchType.
Yes
psDept
Array of String(10)
Yes
peSearchType
Enum
InternalID = 0 'res_acc
PGID = 1 'res_pgid
BoardCard = 2 'res_boardcc
PaxID = 3 'res_referenz
Optional
psSearchString
Board Card or
PGID or
psDept
An array of department, if the routing is all departments, please pass in nothing or an empty array. Please note that if the department pass in does not exist, it will just skip; no error will be returned.
peSearchType
InternalID = 0 ‘res_acc’
PGID = 1 ‘res_pgid’
BoardCard = 2 ‘res_boardcc’
PaxID = 3 ‘res_referenz’
Return Values
CResponseXml.bSuccess = False when Delete Routing failed.
CResponseXml.bSuccess = True when Delete Routing successful.
Example:
oResponse = goWS.FidelioSPMSWSXML("DeleteRouting", "SessionID", New Object() {12345,2,New String() {"9011","9012"}})
DeleteSpecialRequest
Input Parameters
psFunction= “DeleteSpecialRequest” — below is the list of psParam or poParam.
Table 4-23 psParam
pnSrtID
Integer
Unique Special Request ID.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("DeleteSpecialRequest", "SessionID", New Object() {12345})
DeleteTravelDoc
This function deletes the travel document record.
Input Parameters
psFunction= “DeleteTravelDoc” — below is the list of psParam or poParam.
Table 4-24 psParam
pnVisID
Integer
Unique Travel Document ID.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("DeleteTravelDoc", "SessionID", New Object() {12345})
DeleteWorkOrder
This function deletes the maintenance work order.
Input Parameters
psFunction= “DeleteWorkOrder” — below is the list of psParam or poParam.
Table 4-25 psParam
pnMwrID
Integer
Unique Work Order ID.
Yes
psReason
String(1000)
Reason to delete.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("DeleteWorkOrder", "SessionID", New Object() {12345, "Testing"})
DeleteWorkOrderAssignment
This function removes a person/group from the maintenance work order.
Input Parameters
psFunction= “DeleteWorkOrderAssignment” — below is the list of psParam or poParam.
Table 4-26 psParam
pnMwaID
Integer
Unique Work Order Assignment ID.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("DeleteWorkOrderAssignment", "SessionID", New Object() {12345})
DeleteWorkOrderImage
This function deletes the maintenance work order image.
Input Parameters
psFunction= “DeleteWorkOrderImage” — below is the list of psParam or poParam.
Table 4-27 psParam
pnMwpID
Integer
Unique Work Order Image ID.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("DeleteWorkOrderImage", "SessionID", New Object() {12345})
DeleteWorkOrderItem
This function deletes the maintenance work order item.
Input Parameters
psFunction= “DeleteWorkOrderItem” — below is the list of psParam or poParam.
Table 4-28 psParam
pnMwiID
Integer
Unique Work Order Item ID.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("DeleteWorkOrderItem", "SessionID", New Object() {12345})
EvtBooking
This function creates an event booking in SPMS.
Input Parameters
psFunction= “EvtBooking” — below is the list of psParam or poParam.
Table 4-29 psParam
pnAccID
Integer
Unique Guest ID.
Yes
psUniqID
String(30)
Unique Event Booking ID.
Yes
pnEvtID
Integer
Event ID.
Yes
psPriceCategory
String(6)
Price Category Code.
Yes
psPersonGroup
String(6)
Person Group Code.
Yes
pnTicket
Integer
Number of Tickets.
Yes
psNotes
String(50)
Notes (Default Empty).
Optional
psPin
String(4)
Pin Code (Default Empty).
Optional
psSource
String(100)
Booking Source (Default Empty).
Optional
pbForceBooking
Boolean
True = Allow posting even the guest does not have credit limit or posting is disabled, False – Normal posting.
Yes
pbIsFixedSeating
Boolean
True-Fixed Seating assignment booking, False – regular free seating booking.
Optional
pnSeatID
Integer
Seat ID.
Optional
pnPriceID
Integer
Price ID.
Optional
pnAccID
Unique Guest ID, return from SearchPassenger.
psUniqID
The field identifies the booking unique ID within the entire external system. The field is used as a cross-reference to obtain detailed information about all the transactions recorded on a booking.
pnEvtID
The field identifies the unique event ID. This ID can be obtained through GetEvent WebMethod. The field is an internal, unique event number.
psPriceCategory
The field identifies the Price Category. This Price Category can be obtained through GetEvent WebMethod message. This field is an internal, unique price category code.
psPersonGroup
The field identifies the Person Group. This Person Group can be obtained through GetEvent WebMethod message. This field is an internal, unique person group code.
pnTicket
The field identifies the number of tickets to book.
psNotes
The field identifies the additional information send by third-party.
psPin
The field identifies the telephone PIN code of the reservation account. The valid character is 0,1,2,3,4,5,6,7,8,9. Leading zero support depends on SPMS Parameter setting.
psSource
The field identifies the source of the booking. For example, Workstation ID, Kiosk ID, etc. or any other details describing the location where the booking was made.
pbForceBooking
True = Allow posting even the guest do not have a credit limit or posting is disabled. This is applicable to check-in guest only.
False = Normal posting
pbIsFixedSeating
pnSeatID
The field identifies the unique seat identification number. This ID can be obtained through GetSeatingZoneAvailability WebMethod. The field is an internal, unique seat number.
pnPriceID
The field identifies the unique pricing setup identification number. This ID can be obtained through GetEvent WebMethod. The field is an internal, unique pricing setup number.
Return Values
Table 4-30 ADO.NET Data Table field structure for data table xxx
Code
Type
Description.
AccID
Integer
Account Posted.
Balance
Double
Account Balance.
CruiseID
Integer
Posted Cruise ID.
AccID
The account posted can be different from the pnAccID pass in if the pbForceBooking is set to True and the said account does not exist and not allow to do posting the return value will be internal system error account ID.
Balance
The field identifies the balance after the posting is applied. This field can return positive (account is to be invoiced) or negative (account prepaid) values.
CruiseID
The field identifies the posted cruise ID.
Example:
oResponse = goWS.FidelioSPMSWSXML("EvtBooking", "SESSIONID", New Object() {12345, 37464, 245457, "123", "A", 1, "", "", "", False})
For fixed seating assignment bookings:
oResponse = goWS.FidelioSPMSWSXML("EvtBooking", "SESSIONID", New Object() {12345, 37464, 245457, "123", "A", 1, "", "", "", False, True, 802, 762})
ExcBooking
This function creates an excursion booking in SPMS.
Input Parameters
psFunction= “ExcBooking” — below is the list of psParam or poParam.
Table 4-31 psParam
pnAccID
Integer
Unique Guest ID.
Yes
psUniqID
String(30)
Unique Excursion Booking ID.
Yes
pnExcID
Integer
Excursion ID.
Yes
pnAdultTicket
Integer
Number of Adult Tickets.
Yes
pnChildTicket
Integer
Number of Child Tickets.
Yes
pnAdultPromoID
Integer
Adult Promotion ID (Default = 0).
Optional
pnChildPromotID
Integer
Child Promotion ID (Default = 0).
Optional
psLanguage
String(2)
ISO Language Code (Default Empty).
Optional
psNotes
String(200)
Optional
psPin
String(4)
Optional
psSource
String(100)
Optional
pbForceBooking
Boolean
True = Allow posting even the guest who does not have credit limit or posting is disabled. False – Normal posting.
Yes
pbKiosk
Boolean
Kiosk Flag.
Optional
pbySigImage
Array of Byte
Signature Byte Array.
Optional
pbPercentageDiscount
Boolean
True = Percentage Discount, False = Value Discount
Optional
pnDiscount
Decimal
Discount Percentage Rate or Discount Value depends on pbPercentageDiscount.
Optional
pnOvewriteSalesPrice
Decimal
User define price.
Optional
pnWeight
Decimal
Weight, 0 if overweight is not used, > 0 it will charge overweight depend on the setup.
Optional
pnHeight
Decimal
Height, for information only.
Optional
pbAllowWaitList
Boolean
True = Allow Wait List when shore excursion is fully booked,
False = Return error when shore excursion is fully booked.
Optional
pnParticipant
Integer
Unique Guest ID for the person who will take part in the excursion.
Optional
pnAccID
psUniqID
pnExcID
The field identifies the unique excursion identification number. This ID can be obtained through GetExcursion WebMethod. The field is an internal, unique excursion number.
pnAdultTicket
The field identifies the number of adult priced tickets to book.
pnChildTicket
The field identifies the number of child priced tickets to book.
pnAdultPromoID
The field identifies the adult promotion ID. If this field is ignored, the guest is still entitled to the promotion price if available, or else, the normal price is applied. If the promotion ID is sent and the promotion price no longer available, an error message is returned.
For example, if a promotion price is valid for only one seat, and the guest tries to book two seats:
  • With pnAdultPromoID send.
    An error message will return indicating only one seat is available.
  • Without pnAdultPromoID send.
    Booking is made with one seat at the promotion price and one seat at the normal price.
pnChildPromoID
The field identifies he child promotion ID. If this field is ignored, the guest is still entitled to the promotion price if available, or else, the normal price is applied. If the promotion ID is sent and the promotion price no longer available, an error message returned.
psLanguage
The field identifies the language ID of the tour.
psNotes
psPin
The field identifies the telephone PIN code of the reservation account. The valid characters are 0,1,2,3,4,5,6,7,8,9. Leading zero support depends on SPMS Parameter setting.
psSource
The field identifies the source of the booking. For example, Workstation ID, Kiosk ID, and so on, or any other details describing the location where the booking was made.
pbForceBooking
True = Allow posting even the guest who does not have a credit limit or posting is disabled. This is only applicable to checked-in guest only.
pbKiosk
For future use, currently no effect.
pbySignature
This is the signature image in byte array format.
True = Percentage discount: False = dollar value discount.
pnDiscount
If pbPercentageDiscount = True, this is the discount percentage, or else this is the discount value.
If this is > 0, this price is used to post instead of the price defined in the DB. Use it with care.
pnWeight
Pass is 0 if overweight is not used. If more than 0, it will charge overweight depending on the setup.
pnHeight
For information only.
pbAllowWaitList
True = Allow Wait List when shore excursion is fully booked.
False = Return error when shore excursion is fully booked. (Default value).
If the booking is posted to the waitlist, CResponseXml.oObj(0) returns the Wait List Number. This only happens when pbAllowWaitList = True and the booking is fully booked.
pnParticipant
0-pnAccID is the participant.
>0 - Must be a valid unique guest ID, the guest who will participate in the excursion, no validation on the ID.
Return Values
CResponseXml.bSuccess = True and CResponseXML.oTables(0) = ADO.NET data table when input values are valid. CResponse.Xml.oObj(0) will be > 0 if the booking is posted to a wait list.
Table 4-32 ADO.NET Data Table field structure. It will always return one record when the input is valid
Code
Type
Description.
AccID
Integer
Account Posted.
Balance
Double
Account Balance.
CruiseID
Integer
Posted Cruise ID.
AccID
The account posted can be different from the pnAccID pass in if the pbForceBooking is set to True and the said account does not exist and is not allowed to do posting. The return value will be internal system error account ID.
Balance
The field identifies the balance after the posting is applied. This field can return positive (account is to be invoiced) or negative (account prepaid) value.
CruiseID
Example:
oResponse = goWS.FidelioSPMSWSXML("ExcBooking", "SESSIONID", New Object() {12345, 37464, 245457, 1, 0, 0, 0, "", "", "", "", False})
ExcBookingPackage
This function creates an excursion package booking in SPMS.
Input Parameters
psFunction=“ExcBookingPackage” — below is the list of psParam or poParam.
Table 4-33 psParam
pnAccID
Integer
Unique Guest ID.
Yes
psUniqID
String(30)
Unique Excursion Package Booking ID.
Yes
pnExcPkgID
Integer
Excursion Package ID.
Yes
pnAdultTicket
Integer
Yes
pnChildTicket
Integer
Yes
pnAdultPromoID
Integer
Optional
pnChildPromotID
Integer
Optional
psLanguage
String(2)
Optional
psNotes
String(200)
Optional
psPin
String(4)
Optional
psSource
String(100)
Optional
pbForceBooking
Boolean
Yes
pbKiosk
Boolean
Kiosk Flag.
Optional
pbySigImage
Array of Byte
Optional
pnWeight
Decimal
Optional
pnHeight
Decimal
Optional
pbAllowWaitList
Boolean
Optional
pnParticipant
Integer
A Unique Guest ID for the person who takes part in the excursion.
Optional
pnAccID
psUniqID
The field identifies the booking unique ID within the entire external system. The field is used as a cross-reference to obtain detailed information about all of the transactions recorded on a booking.
pnExcPkgID
The field identifies the unique excursion package ID. This ID can be obtained through GetExcPackage WebMethod. The field is an internal, unique excursion number.
pnAdultTicket
pnChildTicket
pnAdultPromoID
The field identifies the adult promotion ID. If this field is ignored, the guest is still entitled to the promotion price, if available, or else the normal price is applied. If the promotion ID is sent and the promotion price is no longer available, an error message is returned.
For example, the promotion price is valid for one seat, and the guest tries to book two seats.
    An error message is returned indicating only one seat is available.
  • Without pnAdultPromoID send:
pnChildPromoID
The field identifies the child promotion ID. If this field is ignored, the guest is entitled to promotion price, if available, or else the normal price is applied. If promotion ID is sent and promotion price no longer available, an error message is returned.
psLanguage
psNotes
The field identifies the additional information sent by a third-party.
psPin
The field identifies the telephone PIN code of the reservation account. The valid characters are 0,1,2,3,4,5,6,7,8,9. Leading zero support depends on SPMS parameter setting.
psSource
The field identifies the source of the booking. For example, Workstation ID, Kiosk ID, and so on or any other details describing the location where the booking was made.
pbForceBooking
True = Allow posting even if the guest does not have a credit limit or the posting is disabled. This only applies to checked-in guests.
False = Normal posting.
pbKiosk
For future use, current no effect.
pbySignature
True = Percentage discount.
False = Dollar value discount.
pnDiscount
If pbPercentageDiscount = True, this is the discount percentage or else this is the discount value.
If this is > 0, we will use this price to post instead of the price defined in the database. Use with care.
pnWeight
Pass in 0 if overweight is not used. If > 0, it will charge overweight depending on the setup.
pnHeight
pbAllowWaitList
If the booking is posted to the waitlist, CResponseXml.oObj(0) will return the Wait List Number. This only happens when pbAllowWaitList = True and the booking is fully booked.
pnParticipant
When the pnParticipant is set to 0 - the guest pnAccID is the participant of this excursion.
When the pnParticipant is not 0 - the pnAccID book the excursion for a participant.
For example, if there are two people joining the excursion, there will be two requests sent to the server and the pnAccID will be the person who pays the bill.
Return Values
CResponseXml.bSuccess = True and CResponseXML.oTables(0) = ADO.NET data table when input values are valid. CResponse.Xml.oObj(0) will be > 0 if the booking is posted to wait list.
Table 4-34 ADO.NET Data Table field structure. Return one record when input is valid
Balance
Double
Account Balance.
CruiseID
Integer
Posted Cruise ID.
Balance
CruiseID
Example:
oResponse = goWS.FidelioSPMSWSXML("ExcBookingPackage", "SESSIONID", New Object() {12345, 37464, 245457, 1, 0, 0, 0, "", "", "", "", False})
FCUIFolio
This function returns the guest posting list.
Input Parameters
psFunction= “FCUIFolio” — below is the list of psParam or poParam.
Table 4-35 psParam
pnAccID
Integer
Unique Account ID.
Yes
psPin
String
Pin Code (Can be blank).
Yes
pbIncludePackage
Boolean
Include Package.
Yes
Return Values
CResponseXml.bSuccess = False when failed.
CResponseXml.bSuccess = True when success, CResponse.oDataset will have 1 Data Table.
Table 4-36 ADO.NET Data Table field structure for data table
DEP_MAINID
String
Main Department ID.
DEM_COMMENT
String
Main Department Description.
POSDATE
Date
Posting System Date.
POSDEMFLAG
String
P-Package,C-Credit,D-Debit.
POS_PPP_ID
Integer
Unique Package ID.
POSDEBIT
Decimal
Debit Total.
POSCREDIT
Decimal
Credit Total.
POSCLOSED
String
Always = No.
POSNOPRINT
String
Yes Or No.
POS_WIN
Integer
Invoice Windows.
POS_POSNOTE_I
String
Posting Remark
POS_MIB_BILL_NO
String
Check No.
POS_TRANS_ID
Internal
Internal Transaction ID.
Example:
oResponse = goWS.FidelioSPMSWSXML("FCUIFolio", "SessionID", New Object() {12345, "", True})
FCUIGuestInquiry
This function queries the list of guest from SPMS based on the input parameter. The function is compatible with the FCUI Inquire message.
Input Parameters
psFunction=“ FCUIGuestInquiry” — below is the list of psParam or poParam.
Table 4-37 psParam
psSearchStr
String
Search String.
Yes
peSearchType
Integer
Search String type.
Yes
peAccountStatus
Integer
Account Status.
Yes
peAccountType
Integer
Account Type.
Yes
pbIncludePicture
Boolean
Include Guest Picture in Return Result.
Yes
psSearchStr
Entered by the external system operator (manually or through a magnetic card reader) and generally contains any information necessary to identify the account. The field can be an account number, card number, cabin number or person name.
peSearchType
The field identifies the type of entry in the Account ID field. The following Account ID Entry Types are defined:
0
Card identification number (RES_BOARDCC)
1
Cabin number or System account (RES_CAB/UXP_A_SYS_ACC)
2
Name of a person or company account(UXP_A_NAME_N)
3
Internal identification number (UXP_A_ID)
4
Group ID number (RES_GRP)
5
External identification number (RES_BOOKNR)
6
Phone trunk number (CAB_TEL or CAB_TEL2)
7
e-mail ID (UXP_H_EMAIL or RES_EMAIL_SHIP)
8
Internal ID number(UXP_C_INTERNALID)
9
Guest Category(GCT_CODE)
10
RFID UID (RFID_ID)
11
Manning Number/Safety Number
12
Loyalty Number (UXP_A_FRQ_CARDNO)
13
Pre-generated Random Number (RES_PGID)
14
External ID (UXP_C_EXTERNALID)
peAccountStatus
The field identifies the account current reservation status. The following status values are defined:
0
Reservations
1
Checked-In
2
Active (Reservations and Checked-in)
3
Disembarked
4
Disembarked Residents (Owners – Valid only for ResidenSea)
5
Checked-In and all Reservation for the current cruise
peAccountType
The field identifies the account type. The following account types are defined:
If this field is ignored or blank then it will return all types.
0
All
1
Passenger (Guest)
2
Resident (Guest)
3
Crew member
4
Group
5
Visitor
6
System account
7
Staff
8
Gift Card
pbIncludeIncludePicture
To include a guest picture in the return result, true will cause the query to take a longer time to return, you can expect a large amount of data to return.
Return Values
Returns True when a search is successful.
Returns False when nothing is found.
Return of GuestInfo When success
CResponse.oGuest
This is the search result.
When single record is returned, the result will in JSON object format {}.
When there are multiple record returned, it is an Array of GuestInfo class.
Please refer details in GuestInfo Class Details.
Table 4-38 GuestInfo Class
Code Type Description Required SPMS Data Field Reference
gnAccID
Integer
Account ID.
Yes
RES_ACC
geAccountType
Integer
Account Type.
Yes
RES_TAG
gbAllowPosting
Boolean
Account Enabled.
Yes
UXP_A_POSTING
gsName
String
Salutation, Forename and Surname
Yes
UXP_A_SALUT, UXP_A_FSTN, UXP_A_NAME
gsCabin
String
Cabin Number.
Optional
RES_CAB
gdEmbDate
Date
Embarkation Date.
Yes
RES_EMB_E for expected accounts, RES_EMB_A for checked in accounts.
gdDisDate
Date
Yes
RES_DIS_E for expected & checked in accounts, RES_DIS_A for checked out accounts.
gdBirthDate
Date
Date of birth.
Optional
UXP_H_BIRTHD
gsEMail
String
E-mail address.
Optional
UXP_H_EMAIL
gnBalance
Decimal
Balance
Yes
(UXP_A_POS_DEBIT –UXP_A_POS_CREDIT)
gsFirstName
String
First Name.
Yes
UXP_A_FSTN
gsLastName
String
Last Name.
Yes
UXP_A_NAME
gsSalutation
String
Salutations
Yes
UXP_A_SALUT
gsTitle
String
Title
Yes
UXP_A_TITEL
gsGender
String
Gender
Yes
UXP_H_SEX
geAgeGroup
Integer
Minor
Yes
Parameter “Adult Min Age” compared to Birthdate.
gsLanguage
String
Language.
Yes
UXP_H_LANG
gsResStatus
String
Reservation Status.
Yes
RES_STATUS translated to E/C/D.
gsGroup
String
Group ID & Description [ID–Description]
Optional
RES_GRP + UXP_A_NAME
gsGroupShoreID
String
Group ID.
Optional
RES_SHOREID (refer to Group)
gsCategory
String
Category ID & Description [ID–Description; ID–Description].
Optional
GCT_CODE + TYP_GCT.TYP_COMMENT
gsAddress
String
Address.
Optional
UXP_A_STREET
gsStreet
String
Street.
Optional
UXP_A_STREET2
gsCity
String
City.
Optional
UXP_A_CITY
gsZip
String
ZIP Code.
Optional
UXP_A_ZIP
gsState
String
State.
Optional
UXP_A_STATE
gsCountry
String
Country Code.
Optional
UXP_A_COUNTRY
gsTel
String
Telephone Number.
Optional
UXP_H_TELNO
gnCreditLimit
Decimal
Credit Limit.
Optional
Credit limit as per assigned credit department code, unless individual credit limit is assigned in UXP_A_CRELIM
gsShipEMail
String
Ship’s e-Mail ID.
Optional
RES_EMAIL_SHIP
gsPin
String
PIN Code
Optional
RES_PIN_CODE
gsAuthKey
String
Authorization Key.
Optional
Refer to PAR Value for PAR- Interfaces-“AuthKey Criteria”.
gsBookNo
String
Booking ID.
Optional
RES_BOOKNR
gsShoreID
String
Shore ID.
Optional
RES_SHOREID
gsVGuestID
String
Unique Guest ID.
Optional
RES_V_GUESTID
gsAward
String
Award Level.
Optional
RES_AWARD_LEVEL
gsBoardCard
String
Onboard Cabin Card.
Optional
RES_BOARDCC
gnRoutedAcc
Integer
Routed Account ID.
Optional
RES_QROUTE_ACC
gbRoutedEnable
Boolean
Routed Account Enable.
Optional
UXP_A_POSTING(refer to the payer)
gnRouteCreditLimit
Decimal
Routed Account Credit Limit.
Optional
Routed Account Credit limit per assigned credit department code, unless individual credit limit is assigned in UXP_A_CRELIM
gsPassportCountry
String
Passport Nationality.
Optional
UXP_H_PASSPI_COUNTRY
gbyPicture
Byte Array
Guest Picture (Unlimited Length).
Optional
SEC_IMAGE
gsCabinStewardName
String
Cabin Steward Name.
Optional
RES_ACC (linked to CAB_KEEPER)
gsHandicap
String
Handicap Description Separate by ASCII 28.
Yes
RES_HANDICAPCODE
gsHandicapRemark
String
Handicap Remarks.
Yes
RES_HANDIREMARKS
gsMusterStation
String
Muster Station Description.
Yes
MST_NAME
gbOnboard
Boolean
Onboard/Shoreside status.
Yes
RES_OFFBOARD
gsSafetyNo
String
Safety Number.
Optional
UXP_C_POS
goSafetyMusterStation
Class
Muster Station Class.
Optional
ORG_ASSEMBLY(linked to MST_ID), MST_NAME
goEmergencyMusterStation
Array of Class
Muster Station Class 0 to 5.
Optional
ORG_E_MST1 to ORG_E_MST6(linked to MST_ID), MST_NA<E
gbNoSafetyDrill
Boolean
Excuse From Safety Drill (Yes/No).
Optional
UXP_C_NODRILL
gePicture
Integer
Picture Source.
Yes
SEC_SOURCE
gdLastPictureDate
Date
Picture Last Modified Date Time.
Optional
SEC_MODDATE
gsFreqCardNo
String
Frequent Traveller Card Number.
Yes
UXP_A_FRQ_CARDNO
gsPriceCategory
String
Price Category.
Yes
RES_PCATEGORY
gsCabinType
String
Cabin Type.
Yes
CAB_TYPE
gnNoneRefundableCredit
Decimal
None Refundable Credit Balance.
Optional
UXP_A_NR_BAL
gnCurrentCruiseID
Integer
Current Cruise ID.
Optional
SCR_ID
gsPassportNo
String
Passport Number.
Optional
UXP_H_PASSNO
gsPaymentDep
String
Default Payment Type.
Optional
RES_DEP_PAY
gsClaasification
String
Reservation Classification/Vip Flag.
Optional
RES_CLASSFICATION
gdSysdate
Date
SPMS System Date.
Yes
sys_date
gdCurrentCruiseStartDate
Date
Current Cruise Start Date.
Yes
scr_a_date of current cruise
gnPGID
Integer
Pregenerated Random ID.
Yes
RES_PGID
gsCruiseItnID
String
Cruise external system identifier.
Yes
SCR_ITN_ID
gsResRefrence
String
External reservation ID.
Yes
RES_REFERENZ
gsDeck
String
Cabin deck code.
Optional
CAB_DECK
gsExternalID
String
External Crew ID.
Yes
UXP_C_EXTERNALID
Table 4-39 MusterStation Class
gsCode
String
Code
Yes
MST_ID
gsName
String
Name
Yes
MST_NAME
gnAccID
The field identifies the unique account (person) ID. The field is an internal, unique account (person) number (I type).
geAccountType
1
Passenger (Guest)
2
Resident (Guest)
3
Crew member
4
Group
5
Visitor
6
System account
7
Staff
8
Gift Card
gbAllowPosting
The field identifies the information if an account is enabled (True) or disabled (False).
gsName
The field identifies the salutation, forename, and surname fields (separated with space) of an account (person).
gsCabin
The field identifies the cabin number that the account (person) occupies. If the account number is returned (not a person), the cabin number field is omitted.
gdEmbDate
The field identifies the date and the time the account (person) is expected or embarked.
gdDisDate
The field identifies the date and the time the account (person) is expected to disembark.
gdBirthDate
The field identifies the person date of birth. If the account number is returned (not a person) or date of birth is not present, the field is omitted.
gsEMail
The field identifies the person’s e-mail address. If the account number is returned (not a person) or e-mail is not present, the field is omitted.
gnBalance
The field identifies the account (person) current balance. This field can return positive (account is to be invoiced) or negative (account prepaid) value.
gsFirstName
The field identifies the forename of an account (person).
gsLastName
The field identifies the surname of an account (person).
gsSalutation
The field identifies the salutation of an account (person).
gsTitle
The field identifies the title of an account (person).
gsGender
The field identifies the gender of an account (person).
geAgeGroup
0 - Adult
1 - YoungAdult
2 - Minor
gsLanguage
The field returns the language of an account (person).
gsResStatus
The field identifies the reservation status [E–Expected, C–Checked-In, D-Departed] of an account (person).
gsGroup
The field identifies the group ID & the name of the group if a passenger is assigned to a group.
gsGroupShoreID
The field identifies the group shore ID of the group if a passenger is assigned to a group.
gsCategory
The field identifies the category IDs and the names of the categories if a passenger is assigned any categories.
gsAddress
The field identifies the address (Line 1).
gsStreet
The field identifies the street (Line 2).
gsCity
The field identifies the city.
gsZip
The field identifies the zip code.
gsState
The field identifies the state.
gsCountry
The field identifies the country code.
gsTel
The field identifies the telephone number.
gnCreditLimit
The field identifies the credit limit set for the person(s).
gsShipEMail
The field identifies the Ship’s e-Mail ID for the person(s).
gsPin
The field identifies the telephone PIN code for the person(s). The valid characters are 0,1,2,3,4,5,6,7,8,9. Leading zero support depends on SPMS Parameter setting.
gsAuthKey
The field identifies the authorization key for the person(s).
gsBookNo
The field identifies the booking ID.
gsShoreID
The field identifies the shore ID.
gsVGuestID
The field identifies the unique guest ID.
gsAward
The field identifies the guest award level.
gsBoardCard
It contains Track 2 field 1 value of the onboard cabin card excluding start sentinel and end sentinel.
For example, The value encode in track 2 is ;9910000657580701=20060810?, we will only send 9910000657580701
gnRoutedAcc
The field identifies the routed account ID (payer account ID).
gbRoutedEnable
The field identifies the information if the routed account is enabled (1) or disabled (0).
gnRouteCreditLimit
The field identifies the credit limit set for the routed person(s) (payer account).
gsPassportCountry
The field identifies the guest passport nationality
gbyPicture
The field identifies the guest pictures.
gsCabinStewardName
The field identifies the housekeeper assign to this cabin
gsHandicap
If the guest has handicap, it will be shown. For a non-handicapped guest it will be blank. For example, Wheel Chair Require<FS>Deaf .
gsHandicapRemark
This is special remark for the handicapped guest.
gsMusterStation
The master station associate with the guest.
gbOnboard
True-Onboard, False = Shoreside.
gsSafetyNo
Safety Number (only apply to crew).
Return MusterStation Class with Safety Muster Station Code and Description (only apply to crew).
goEmergencyMusterStation(5)
Return MusterStation Class with Emergency Muster Station Code and Description (The emergency type is user define) (only apply to crew).
gbNoSafetyDrill
Excuse From Safety Drill (only apply to crew).
gePicture
Picture Source
-1 = No Picture
0 = Unknown
1 = Web Cam
2 = RFID Passport
3 = Scan Passport Image
4 = Guest History
gdLastPictureDate
Picture Last Modified Date, due to the size of the picture, it is not efficient to return the picture in FCUIGuestInquiry message, you must compare the last modified date of the picture store in your DB and if the picture had been updated, send WSFunction with GuestPicture and gnAccID as parameter message to get the picture in a separate call.
gsFreqCardNo
gsPriceCategory
Booking Price Category (res_pcategory).
gsCabinType
Cabin Type.
None Refundable Credit, there is an option set in Web.Config to indicate do not return None Refundable credit if the guest search is x number of more. This is for performance purpose. Default is five.
gnCurrentCruiseID
Current Cruise ID.
gsPassportNo
Passport Number.
gsPaymentDep
Default payment department ID.
gsClaasification
This field identified the reservation classification/VIP Flag.
gdSysdate
Current SPMS System Date.
Current cruise start date.
gnPGID
Pregenerated Random Number.
gsCruiseItnID
gsResRefrence
gsDeck
Cabin Deck code.
gsExternalID
External Crew ID.
Example:
This is to search all checked-in guest/crew stay in cabin 05002 and include the picture in the response message.
oResponse = goWS.FidelioSPMSWSXML("FCUIGuestInquiry", "SESSIONID", New Object() { "05002", 1, 1, 0, True})
FCUIPayment
This function posts the payment to the SPMS account based on the input parameter. This is mainly for generic usage and is compatible with FCUI Payment.
Input Parameters
psFunction= “FCUIPayment” — below is the list of psParam or poParam.
Table 4-40 psParam
psSearchStr
String
Search String.
Yes
peSearchType
Integer
Search String type.
Yes
peAccountStatus
Integer
Account Status.
Yes
peAccountType
Integer
Account Type.
Yes
pbIncludePicture
Boolean
Yes
psUniquePostingID
String(20)
Unique Posting ID.
Yes
psOutletID
String(13)
Outlet ID.
Yes
pnValue
Decimal
Posting Total.
Yes
psNote
String
Notes.
Yes
pnInvoiceWin
Integer
Invoice Windows (0 – 3).
Yes
psSearchStr
Entered by the external system operator manually or through a magnetic card reader and generally contains any information necessary to identify the account. The field can be an account number, card number, cabin number or person name.
peSearchType
0
1
2
3
4
5
6
7
8
9
10
RFID UID (RFID_ID)
11
12
13
peAccountStatus
The field identifies the current account reservation status. The following status values were defined:
0
Reservations
1
Checked-In
2
3
Disembarked
4
5
peAccountType
If this field is ignored of blank then it will return all type.
0
All
1
Passenger (Guest)
2
Resident (Guest)
3
Crew member
4
Group
5
Visitor
6
System account
7
Staff
8
Gift Card
To include a guest picture in the return result, true will cause the query to take a longer time to return and expect a huge amount of data to return.
psUniquePostingID
The field identifies the guest check uniquely within the whole external system. The field is used as a cross-reference to obtain detailed information about all the transactions recorded on a check.
psOutletID
The field identifies the revenue center of the outlet from which the charge originated. The SPMS description equivalent to the Outlet ID will be displayed or printed on a customer invoice.
pnValue
The field identifies the payment amount, for forex this is the forex amount receive.
psNote
The field identifies the additional information send by a third-party system.
pnInvoiceWin
The invoice windows, a valid value is from 0 to 3, any invalid value will default to 0.
Return Values
CResponseXml.oObj(0) Returns 0 when update is successful
CResponseXml.oObj(0) Returns 1 when update has failed
CResponseXml.oObj(0) Returns 2 when the search string return more than 1 persons, it is recommend to use Unique Account ID to make sure it is unique.
FCUIPosting
This function will post to an SPMS account based on the input parameter, this is mainly for generic usage and is compatible with FCUI Posting.
Input Parameters
psFunction= “FCUIPosting” — below is the list of psParam or poParam.
Table 4-41 psParam
psSearchStr
String
Search String.
Yes
peSearchType
Integer
Search String type.
Yes
peAccountStatus
Integer
Account Status.
Yes
peAccountType
Integer
Account Type.
Yes
pbIncludePicture
Boolean
Yes
poPosting
PostingDetails Class
The is the Posting Data.
Yes
psSearchStr
peSearchType
0
1
2
3
4
5
6
7
8
9
10
RFID UID (RFID_ID)
11
12
13
peAccountStatus
The field identifies the account current reservation status. The following status values were defined:
0
Reservations
1
Checked-In
2
3
Disembarked
4
5
peAccountType
0
All
1
Passenger (Guest)
2
Resident (Guest)
3
Crew member
4
Group
5
Visitor
6
System account
7
Staff
8
Gift Card
To include a guest picture in the return result, “True” will cause the query to take a longer time to return and expect a huge amount of data to return.
poPosting
Information of the transactions to be posted.
Please refer to PostingDetails Class for more detail.
Return Values
CResponseXml.oObj(0) Returns 0 when update is successful.
CResponseXml.oObj(0) Returns 1 when update has failed.
CResponseXml.oObj(0) Returns 2 when the search string return more than 1 person, it is recommend to use Unique Account ID to make sure it is unique.
CResponse.oGuest
This is the search result; it is an Array of GuestInfo class.
It will have 1 record if return result is 0.
It will have 0 or 1 record if return result is 1 depend on fail reason.
It will more than 1 record if return result is 2.
Please refer detail in GuestInfo Class Details.
CResponse.oObj(1) = Pos Transactions ID, only valid when CResponse.oObj(0) = 0
Posting Class
Table 4-42 PostingDetails Class
gbCallPosting
Boolean
Indicate this is call posting.
Yes
gsPin
String
PIN Code.
Yes
gsUniquePostingID
String(20)
Unique Posting ID.
Yes
gsCheckImage
String
Receipt image.
Yes
gbyCheckImage
Byte Array
Receipt image including signature in JPG format.
Yes
gsPosInfo
String
Notes.
Yes
gsItemDetail
String(x)
Refer Item Detail for.
Yes
gbForcePosting
Boolean
True = Allow posting even when the guest has reached his credit limit or posting is disabled. False = Normal posting.
Yes
goPosting
Array of PostingTotal Class
Refer to PostingTotal Class.
Yes
gbCallPosting
If this is a call posting the behavior will be the same as gbForcePosting with the exception that for a call posting when the guest is not found it will then post to system error account. It will use a different data in the goPosting.
For normal posting, it will return 2 when more than 1 guest found but for call posting, it will post to the first guest.
gsPin
The field identifies the telephone code of the reservation account. The valid characters are 0,1,2,3,4,5,6,7,8,9. Leading zero support depends on SPMS Parameter setting.
Pass in an empty string if not in use.
gsUniquePostingID
The field identifies the bill (check) uniquely within the whole external system. The field is used as a cross-reference to obtain detailed information about all the transactions recorded on a check.
gsCheckImage
The field identifies the receipt image that shows the same data as printed on the customer receipt. This should be plain text with CR & LF characters separating each line of the text. It should be formatted to be displayed using non-proportional fonts. Pass in an empty string if not in use.
gbyCheckImage
This is the customer receipt which include a digital signature.
You can use the below VB .NET sample code to merge the text base check image with JPG digital signature. Pass in nothing if not in use
oImage = MergeCheckAndSignatureImage(TextToImage(gsCheckImage), oSignature)
Private Function MergeCheckAndSignatureImage(ByVal poCheckImage As Image, ByVal poSignatureImage As System.Drawing.Image) As Image
    MergeCheckAndSignatureImage = Nothing
    Try
      'check Width of check and signature image
      'width
      If Not poCheckImage.Width = poSignatureImage.Width Then
        Dim oNewImage As Image = ResizeImage(poCheckImage, poSignatureImage)
        poSignatureImage.Dispose()
        poSignatureImage = oNewImage
      End If
      Dim oImage As New Bitmap(Math.Max(poCheckImage.Width, poSignatureImage.Width), poCheckImage.Height + poSignatureImage.Height)
      Dim gGraphic As Graphics = Graphics.FromImage(oImage)
      gGraphic.DrawImage(poCheckImage, New Point(0, 0))
      gGraphic.DrawImage(poSignatureImage, New Point(0, poCheckImage.Height))
      gGraphic.Dispose()
      gGraphic = Nothing
      poCheckImage.Dispose()
      Return oImage
    Catch ex As Exception
    End Try
  End Function
  'Resize image if check width is larger than signature width ,if the signature image not same width as check image, the picture seems a bit out of place (please see, signature.jpg)
  Private Function ResizeImage(ByVal poRefenceImage As Image, ByRef poTargetImage As Image) As Image
    Dim oCurrentImage As New Bitmap(poTargetImage)
    Dim oNewImage As New Bitmap(poRefenceImage.Width, poTargetImage.Height)
    Dim oGraphic As Graphics = Graphics.FromImage(oNewImage)
    oGraphic.InterpolationMode = Drawing2D.InterpolationMode.HighQualityBicubic
    oGraphic.DrawImage(oCurrentImage, New Rectangle(0, 0, poRefenceImage.Width, poTargetImage.Height), _
                       New Rectangle(0, 0, oCurrentImage.Width, oNewImage.Height), GraphicsUnit.Pixel)
    oGraphic.Dispose()
    oCurrentImage.Dispose()
    Return oNewImage
  End Function
  Private Function TextToImage(ByVal psText As String) As Image
    Dim oGra As Graphics
    Dim sStr() As String
    Dim oImage As Image
    sStr = Split(psText, vbNewLine)
    oImage = New Bitmap(32 * 7, sStr.Length * 12.2 + 18, PixelFormat.Format32bppArgb)
    oGra = Graphics.FromImage(oImage)
    oGra.FillRectangle(Brushes.White, 0, 0, CSng(32 * 7), CSng(sStr.Length * 12.2 + 18))
    oGra.DrawString(psText, New Font("Courier New", 8), Brushes.Black, 0, 30)
    oGra.DrawImage(oImage, New PointF(0, 0))
    TextToImage = oImage
  End Function
gsPosInfo
gsItemDetail
In order to maintain compatibility with FCUI, the class object will not be used.
This field identify the items order on the external system. The field contains many sub-field, with each field separated with <FS>. If the external systems do not have the particular field, just pass in the default value indicated in bracket.
Table 4-43 Item Identifier
Field Type Description
1
Integer
Employee Number (Default 0).
2
String(30)
Employee Name (Default Blank).
3
Integer
Guest Count (Default 0).
4
Integer
Table Number (Default 0).
5
String(60)
Outlet Name.
6
String
Variable Length field. Each record will have 6 fields and separate by pipe “|”, each field will be separated by comma “,”
Field 1: Item Number (9).
Field 2: Item Name X(50).
Field 3: Quantity (9).
Field 4: Sales Total (9.9).
Field 5: 1-Voided, 0-Normal.
Field 6: 1-Refunded, 0-Normal.
7
String (12)
Posting Server Information.
For example, Guest A order 1 T-Shirt for 10.00 and 2 Key Chain for 2.50 each
1234<FS>Cashier 1<FS>1<FS>0<FS>Gift Shop<FS>205789412,T-Shift,1,10.00,0,0|205789123,Key Chain,2,5.00,0,0
gbForcePosting
True = Allow posting even the guest who has reached his/her credit limit or posting is disabled. This only applies to check-in guest and the posting will fail if the guest not found.
PostingTotal Class
True = Allow posting even the guest who has reached his credit limit or posting is disabled. This only applies to check-in guest and the posting will fail if the guest not found.
Table 4-44 PostingTotal Class
gnServingPeriod
Integer
Serving Period
Yes
gnPostingTotal
Decimal
Posting Total
Yes
gnPostingDiscount
Decimal
Discount Total
Yes
gnPostingServiceCharge
Decimal
Service Charge Total
Yes
gnPostingTip
Decimal
Tip Total
Yes
gnPostingTax
Decimal
Tax Total
Yes
gnInvoiceWin
Integer
Yes
gsOutletID
String(13)
Outlet ID
Yes
gdCallStart
Date
Call Start Date or Time (For Call Accounting Posting)
Yes
gsCallNoDialed
String
Dialed Number (For Call Accounting Posting)
Yes
gnCallDuration
Integer
Call Duration (For Call Accounting Posting)
Yes
gsCallType
String
Call Type (For Call Accounting Posting)
Yes
gnServingPeriod
The field identifies the serving period number that is active when the charge is posted.
Pass in 0 if not in use.
gnPostingTotal
The field identifies the actual amount (gross) is posted. This value represents value in full (including discount, service charge and tip). This field can have positive (account is debited) or negative (void) value.
gnPostingDiscount
The field identifies the total amount of discounts taken against the transaction total amount. This field can have positive (account is debited) or negative (void) value.
The field identifies the total amount of any automatic percentage add-on amounts to the transaction total. This field can have positive (account is debited) or negative (void) value.
gnPostingTip
The field identifies the total amount of any add-on amounts to the transaction total such as tips, cover charges etc. This value is typically entered manually per customer specification. This field can have positive (account is debited) or negative (void) value.
gnPostingTax
The field identifies the total amount of any tax to the transaction total. This field can have positive (account is debited) or negative (void) value.
gnInvoiceWin
gsOutletID
The field identifies the revenue center of the outlet from which the charge originated. The FCSPMS description equivalent of the Outlet ID will be displayed or printed on a customer invoice.
gdCallStart
The field identifies the date and the time when the phone call started. Full date and time format is required.
gsCallNoDialed
The field identifies the phone number called.
gnCallDuration
The field identifies the phone call duration in seconds.
gsCallType
The field identifies the phone call type. The following types are defined:
VL
Line Voice Call
VC
Cellular Voice Call
VS
Satellite Voice Call
VN
Non-chargeable Voice Call
FL
Line Fax
FC
Cellular Fax
FS
Satellite Fax
FN
Non-chargeable Fax
DL
Line Data Call
DC
Cellular Data Call
DS
Satellite Data Call
DN
Non-chargeable Data Call
Example:
For example, Posting using unique account ID, exclude picture from response message
Dim oPosting As New FidelioSPMSWS.PostingDetils
With oPosting
  .gbCallPosting = False
  .gbForcePosting = False
  If File.Exists("c:\jpg.jpg") Then
    .gbyCheckImage = File.ReadAllBytes("c:\jpg.jpg")
  End If
 .gsCheckImage = <Check Image>
 .gsItemDetail = "1234<FS>Cashier <FS>1<FS>0<FS>Gift Shop<FS>2xxxxxxxxx|T-Shift|1|100.00"
 .gsPin = ""
 .gsPosInfo = "Remark"
 .gsUniquePostingID = "<POSTINGID>" 'You have to generate you own unique number
End With
ReDim oPosting.goPosting(0)
oPosting.goPosting(0) = New FidelioSPMSWS.PostingTotal
With oPosting.goPosting(0)
  .gnInvoiceWin = 0
  .gnPostingDiscount = 0.00 'No Discount
  .gnPostingServiceCharge = 10.00 '10% Service Charge
  .gnPostingTax = 5.00 '5% Tax
  .gnPostingTip = 0.00
  .gnPostingTotal = 115.00
  .gnServingPeriod = 0
  .gnCallDuration = 0
  .gsCallNoDialed = ""
  .gsCallType = ""
  .gsOutletID = "123" 'This value need to setup in SPMS dep mapping
  .gdCallStart = Now()'This is only use for call posting
 End With
oResponse = goWS.FidelioSPMSWSXML("FCUIPosting", "SESSIONID", New Object() { 2358, 3, 1, 0, False, oPosting})
Sample JSON Http Post
For JSON you must serialize the object to string first.
Figure 4-1 Sample JSON String
This figure shows the Sample JSON string
POST /OHCWebServices/OHCWebServices.asmx/FidelioSPMSWSJsonPost HTTP/1.0
Host: localhost
Content-Length: 1771
{callback:"Testing",psSessionID:"ad765829-3fb7-4f1b-9754-587d43a879ab",psFunction:"FCUIPosting",psParam:["2440167",3,1,0,true,"{\"gbCallPosting\":false,\"gsPin\":\"\",\"gsUniquePostingID\":\"1234\",\"gsCheckImage\":\"INVOICE – EXAMPLE COMPANY  \\r\\n          RESTAURANT           \\r\\n1 CASHIER 1\\r\\n--------------------------------\\r\\n1/1          1234   GST 1\\r\\n        JUN12'07  6:44PM        \\r\\n--------------------------------\\r\\n  1 FRIED RICE    12.34\\r\\n    DISCOUNT\\t\\t 2.10- \\r\\n    SERVICE CHARGE       0.12 \\r\\n    TIP                  1.00 \\r\\n    TOTAL PAID          11.36 \\r\\n    05000\\r\\n    XXXN070612184500\\r\\n    MANUAL ENTRY\\r\\n    Cabin/Acc:05000\\r\\n    <LAST/FIRST NAME>\\r\\n    CABIN CHARGE        00.00 \\r\\n---1168 CLOSED JUN12  6:45PM----\\r\\n               .                \\r\\nSIGN:...........................\\r\\n               .                \\r\\nAll Amounts in US Dollars (USD$)\",\"gbyCheckImage\":null,\"gsPosInfo\":\"\",\"gsItemDetail\":\"1234?Cashier 1?1?0?Gift Shop?205789412|T-Shift|1|12.34\",\"gbForcePosting\":false,\"goPosting\":[{\"gnServingPeriod\":0,\"gnPostingTotal\":10.01,\"gnPostingDiscount\":1.01,\"gnPostingServiceCharge\":1.02,\"gnPostingTip\":1.03,\"gnPostingTax\":1.04,\"gnInvoiceWin\":0,\"gsOutletID\":\"264\",\"gdCallStart\":\"20130620100105\",\"gsCallNoDialed\":\"12345678\",\"gnCallDuration\":159,\"gsCallType\":\"Sat\"},{\"gnServingPeriod\":0,\"gnPostingTotal\":11.0,\"gnPostingDiscount\":1.01,\"gnPostingServiceCharge\":1.02,\"gnPostingTip\":1.03,\"gnPostingTax\":1.04,\"gnInvoiceWin\":0,\"gsOutletID\":\"262\",\"gdCallStart\":\"20130620100105\",\"gsCallNoDialed\":\"12345678\",\"gnCallDuration\":259,\"gsCallType\":\"Sat\"}]}"]}
FCUIUDFUpdate
This function updates the guest custom information.
Note: Not supported when it is connected to an offline QCI Sync database.
Input Parameters
psFunction= “FCUIUDFUpdate” — below is the list of psParam or poParam.
Table 4-45 psParam
Parameter Type Description Required
pnAccID
Integer
Unique Account ID.
Yes
psUDFID
Array of String
Array of UDF_ID.
Yes
psValue
Array of String
Max length 1000 for each value.
Yes
Return Values
CResponseXml.bSuccess = True when success.
Example:
oResponse = goWS.FidelioSPMSWSXML("FCUIFolio", "SessionID", New Object() {12345, New String() {"1","1"}, New String() {"6411", "0123"}})
FCUIUpdatePin
This function updates the guest pin code.
Input Parameters
psFunction=“FCUIUpdatePin” — below is the list of psParam or poParam.
Table 4-46 psParam
pnAccID
Integer
Unique Account ID.
Yes
psCabin
String
Cabin Number.
Yes
psAuthKey
String
4 Digits authentication code to prevent unauthorize update.
Yes
psPin
String
Pin Code.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("FCUIFolio", "SessionID", New Object() {12345, "678", "6411", "0123"})
GangwayGuestSearch
This function is used to search the guest by Gangway movement.
Input Parameters
psFunction= “GangwayGuestSearch” — below is the list of psParam or poParam.
Table 4-47 psParam
pbAshore
Boolean
True=Guest at shoreside, False=Guest Onboard.
Yes
peGuestType
Integer
0-All.
1-Guest Only.
2-Resident Only.
3-Crew Only.
4-Visitor Only.
5-Check-Out but onboard.
Yes
pbShowCurrentPortOnly
Boolean
For ferry operator only, true=only return guest which disembark at the current port only.
Yes
pnExcludeOvernightTour
Boolean
True=Exclude guest stay at shoreside for overnight tour.
Yes
Return Values
Table 4-48 ADO.NET Data Table field structure
Res_status
String
Reservation Status.
Tname
String
Guest Name.
Res_cab
String
Cabin Number.
Res_owner
Integer
0-Normal Guest, 1-Owner.
Nationality
String
Nationality Code
Res_id
Integer
Unique Reservation ID.
Res_emb_a
Date
Actual Embarkation Date.
Res_signonport
String
Port where the guest embark.
Res_dis_e
Date
Expected Disembarkation Date.
Res_signoffport
String
Port where the guest disembark.
Uxp_a_name
String
Last Name.
Uxp_a_fstn
String
First Name.
Uxp_a_as_crw
Integer
Guest show in crew manifest.
Uxp_c_as_pax
Integer
Crew show in pax manifest.
Res_acc
Integer
Unique Guest ID.
SwitchAcc
Integer
1-Switch Manifest.
ManingNumber
String
Crew Safety Number.
Example:
oResponse = goWS.FidelioSPMSWSXML("GangwayGuestSearch", "SESSIONID", New Object() {False, 0, False, False})
GetAccBalance
This function gets the account outstanding balance.
Input Parameters
psFunction= “GetAccBalance” — below is the list of psParam or poParam.
Table 4-49 psParam
pnAccID
Integer
Unique Guest ID.
Yes
pbPreBill
Boolean
True – Get the Pre-Cruise Balance, False – Get the account balance.
Yes
Below are the descriptions of the parameters.
pnAccID
Unique Guest ID, return from GuestSearch.
pbPreBill
Return Values
CResponseXml.bSuccess = True when GetAccBalance is successful, CResponse.oObj returns an Array with 2 value, the first value is the Pre-Cruise Balance or Account Balance depending on pbPreBill and the second value is Non-Refundable Credit Pre-Cruise Balance or Non-Refundable Credit Balance.
CResponseXml.bSuccess = False when GetAccBalance has failed
Example:
oResponse = goWS.FidelioSPMSWSXML("GetAccBalance", "", New Object() {12345, False})
GetAdvanceLoyaltyDiscount
This function gets the guest loyalty discount eligibility from SPMS.
Input Parameters
psFunction=“ GetAdvanceLoyaltyDiscount” — below is the list of psParam or poParam.
Table 4-50 psParam
pnAccID
Integer
Unique Account ID.
Yes
pnRvc
Integer
MICROS POS Revenue Center Number.
Yes
Return Values
CResponseXml.bSuccess = False when GetAdvanceLoyaltyDiscount failed
CResponseXml.bSuccess = True when GetAdvanceLoyaltyDiscount is successful and return Class CAdvanceLoyaltyDiscount
Table 4-51 CAdvanceLoyaltyDiscount Class
gnDiscNo
Integer
MICROS POS Discount Number.
Yes
gnDiscLimit
Decimal
Maximum Discount Allow Per Check.
Yes
goEligibility
Array of CDiscRate
Discount eligibility.
Yes
Table 4-52 CAdvanceLoyaltyDiscount Class
gsType
String
M-Menu Item ,G-Major Group, F-Family Group.
Yes
gnNumber
Integer
Object Number.
Yes
gnRate
Decimal
Discount Percentage.
Yes
GetCheckImage
This function gets the check image from SPMS.
Input Parameters
psFunction= “GetCheckImage” — below is the list of psParam or poParam.
Table 4-53 psParam
pnMibID
Integer
SPMS Unique Check Image ID.
Yes
pnMibID
SPMS Unique Check Image ID, return from GetInvoiceTotal.
Return Values
CResponseXml.bSuccess = True when GetCheckImage is successful
This is the check image from MICROS POS with signature. This is the preferred image to display if both pbyImage and psCheckImage exists.
This is the text image of a guest check.
CResponseXml.bSuccess = False when GetCheckImage has failed or no record found
Example:
oResponse = goWS.FidelioSPMSWSXML("GetCheckImage", "SESSIONID", New Object() {12345678})
GetCreditCardInfo
This function gets the list of register credit card assign to the passenger.
Input Parameters
psFunction= “GetCreditCardInfo” — below is the list of psParam or poParam.
Table 4-54 psParam
pnAccID
Integer
Unique Guest ID.
Yes
pnAccID
Return Values
CResponseXml.bSuccess = False when GetCreditCardInfo has failed
CResponseXml.bSuccess = True when GetCreditCardnfo is successful, CResponse.oDataset will have 2 Data Tables.
Table 4-55 ADO.NET Data Table field structure for FIRST DATA Credit Card Information
CRD_NO
String
Credit Card No, the card number will always mask to XX**********XXXX
CRD_EXP
String
Expiry Date in MMYY format.
CRD_NAME
String
Credit Card owner name.
CRD_ACTIVE
String
Yes or No.
CRD_LIMITS
String
‘No Limit’ or the credit limit amount.
CRD_ID
Integer
Unique ID.
CRD_INVOICE
String
‘All’ or the individual invoice separated by ‘,’
CRD_DCC
String
Y or N for Dynamic Currency Exchange.
CRD_PARCELADO
String
Y or N special Parcelado flag, currently not is use.
CRD_SIG_ID
String
Yes or No, indicate the signature image exists.
DCC_EXRATE
Double
Exchange Rate.
CRD_CUR
String
Currency code.
SIGN_ID
Integer
Signature Unique ID.
Table 4-56 ADO.NET Data Table field structure for second data table
CRD_NO
String
CRD_EXP
String
CRD_NAME
String
CRD_ID
Integer
Unique ID.
CRD_ACTIVE
String
Yes or No.
CRD_REWARDS
Integer
1 - Reward Card, 2 - Gift Card.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetCreditCardInfo", "", New Object() {12345})
GetEvent
This function search and list the available ticket events in SPMS.
Input Parameters
psFunction=“GetEvent” — below is the list of psParam or poParam.
Table 4-57 psParam
pnAccID
Integer
Unique Guest ID.
Yes
pdSDate
Date
Event start date.
Yes
pdEDate
Date
Event end date.
Yes
peCodeType
EvtCodeType
Code Type.
Yes
psCode
String
Code.
Optional
pnAccID
pdSDate
The field identifies the minimum date the event can start from.
pdEDate
The field identifies the maximum date the event must be completed.
peCodeType
(Enumerator)
The field identifies the type of the code being passed for querying events.
None
0
No Code will be used
LocationID
1
Event Location ID, you can get the value from WSFunction, GetLocationInfo, LOC_ID.
EventNo
2
Event No (EvtNo)
UniqueID
3
Event Unique ID (EvtID)
psCode
The code for the Events to run the query on. It can be either the location code, The Event No (EvtNo), the Unique ID (EvtID).
Return Values
CResponseXml.bSuccess = False when input values are invalid or no record found.
Table 4-58 ADO.NET Data Table field structure
EvtID
Integer
Event ID.
EvtNo
String(20)
Event Number.
EvtName
String(50)
Event Name.
EvtBegDate
Date
Starting Date and Time.
EvtEngDate
Date
Ending Date and Time .
EvtLastCall
Date
Last Call Time.
EvtStatus
String(1)
Booking Status.
EvtPriceCategory
String(6)
EvtPriceDesc
String(50)
Price Category Description.
EvtPersonCode
String(6)
Person Group Code.
EvtPersonDesc
String(50)
Person Group Description.
EvtIsFixedSeatingEvent
Boolean
True-Fixed Seating Event, False = regular Free Seating Event.
EvtIsLevelHybrid
Boolean
True-Level Hybrid mode.
EvtHybridLevelOpenSeatingCapacity
Integer
Open Seating max capacity for Hybrid Levels.
EvtLayoutLevelCode
String(20)
Layout Level Code.
EvtLayoutLevelDesc
String(50)
Layout Level Description.
EvtSeatingZoneCode
String(20)
Seating Zone Code.
EvtSeatingZoneDesc
String(50)
Seating Zone Description.
EvtIsFixedSeatingPrice
Boolean
True- Fixed Seating Price Setup, False = regular Free Seating Price.
EvtPrice
Double
Price.
EvtDesc
String(200)
Event Description.
EvtShowInKiosk
Boolean
Show in Kiosk [External Booking System].
EvtBookInKiosk
Boolean
Book in Kiosk [External Booking System].
EvtMaxSeat
Integer
Maximum Seats.
EvtBooked
Integer
Seats Currently Booked.
EvtLocation
String(50)
Location Name.
EvtShowInITV
Boolean
Show in Internet TV (ITV) - [External Booking System].
EvtBookInITV
Boolean
Book in ITV [External Booking System].
EvtLongDesc
X(1000)
Event Long Description.
EvtPriceID
Integer
Price ID.
EvtLayoutLevelID
Integer
Layout Level ID.
EvtSeatingZoneID
Integer
Seating Zone ID.
EvtID
The field identifies the unique event identifier. This ID can be used for event booking. The field is an internal, unique event number.
EvtNo
The field identifies the custom, users entered, a number that identifies the event.
EvtName
The field identifies the event name.
EvtBegDate
The field identifies the event starting date and time.
EvtEndDate
The field identifies the event ending date and time.
EvtLastCall
The field identifies the last call time, please ignore the date part.
EvtStatus
The field identifies the event booking status. The following status identifiers values are defined:
A
Available
F
Fully booked
O
Overbooked
For Fixed Seating Events, the Booking status applies to the Seating Zone.
EvtPriceCategory
The field identifies the event price category code, this field is required during booking.
For example, Gold Class, Silver Class
EvtPriceDesc
The field identifies the event price category description.
EvtPersonCode
The field identifies the person group code, this field is required during booking. For example, Adult, Child or Senior
EvtPersonDesc
The field identifies the person group description
True = Fixed Seating Event, False = regular Free Seating Event
EvtIsLevelHybrid
True = Level Hybrid mode (Fixed Seating plus Open Seating Capacity), False = Level is only Fixed Seating
The field identifies the layout level description for fixed seating assignment bookings.
EvtHybridLevelOpenSeatingCapacity Open Seating max attendees capacity for Hybrid Levels
EvtLayoutLevelCode The field identifies the layout level code for fixed seating assignment bookings.
EvtLayoutLevelDesc
EvtSeatingZoneCode
The field identifies the seating zone code for fixed seating assignment bookings.
EvtSeatingZoneDesc
The field identifies the seating zone description for fixed seating assignment bookings.
True = Fixed Seating Price Setup, False = regular Free Seating Price
EvtPrice The field identifies the event selling price.
EvtDesc The field identifies the additional information about the event.
EvtShowInKiosk
The flag to denote if the event can be shown on the external system.
EvtBookInKiosk
The flag to denote if the event can be booked on the external system.
EvtMaxSeat
Total seats available on the event.
Note: For the same event ID the same seat could be sold at a different price depending on the price category and person group. The total seats appear on different price category and person group is representation of the same seats as shown in below example.
Below table means the event ID=1 only have 50 seats available, for the same EID will always have the same MAX value.
EID PCT PGT MAX
1 Gold Adult 50
1 Silver Adult 50
1 Gold Child 50
1 Silver Child 50
For Fixed Seating Events, the total seat count applies to the Seating Zone.
EvtBooked
The field indicates the total event seat booked.
For Fixed Seating Events, the total seats booked count applies to the Seating Zone.
EvtLocation
The field identifies the location name of the event.
EvtShowInITV
The flag to denote if the event can be shown on ITV the external system.
EvtBookInITV
The flag to denote if the event can be booked on the ITV external system, the field returns ‘Yes’ or ‘No’ only.
EvtLongDesc
The field indicates the Event Long Description intended for ITV usage.
EvtPriceID
The field identifies the unique pricing setup identification number. This ID must be used for event fixed seating booking. The field is an internal, unique pricing setup number.
EvtLayoutLevelID
The field identifies the unique Layout Level identification number. This ID must be used for event fixed seating booking. The field is an internal, unique layout level number.
EvtSeatingZoneID
The field identifies the unique Seating Zone identification number. This ID must be used for event fixed seating booking. The field is an internal, unique seating zone number.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetEvent", "SESSIONID", New Object() {12345, #1/1/2011#, #1/12/2011#, 0, ""})
GetEvtFolio
This function is used to request a list of event booked on a specific account in SPMS.
Input Parameters
psFunction= “GetEvtFolio” — below is the list of psParam or poParam.
Table 4-59 psParam
pnAccID
Integer
Unique Guest ID.
Yes
pnAccID
Return Values
Table 4-60 ADO.NET Data Table field structure
EvtID
Integer
Event ID.
EvtNo
String(20)
Event Number.
EvtName
String(50)
Event Name.
EvtBegDate
Date
EvtEngDate
Date
Ending Date and Time.
EvtStatus
String(1)
Booking Status.
EvtBookDate
Date
Booking Date and Time.
EvtPriceCategory
String(6)
EvtPriceDesc
String(50)
EvtPersonCode
String(6)
Person Group Code.
EvtPersonDesc
String(50)
EvtLayoutLevelCode
String(20)
Layout Level Code.
EvtLayoutLevelDesc
String(50)
EvtSeatingZoneCode
String(20)
Seating Zone Code.
EvtSeatingZoneDesc
String(50)
EvtSeatCode
String(20)
Seat Code.
EvtLocation
String(50)
Location Name.
EvtQty
Integer
Number of Tickets Booked.
EvtTotal
Double
Booking Value.
EvtNotes
String(200)
Notes.
EvtPrint
Integer
Ticket Printed Count.
EvtDiscount
Double
Discount Amount.
EvtControl
Integer
Internal Booking Number.
EvtPrepaid
Boolean
Prepaid.
EvtID
EvtNo
EvtName
The field identifies the event name description.
EvtBegDate
EvtEndDate
EvtStatus
A
Available
F
Fully booked
O
Overbooked
EvtBookDate
The field identifies the excursion booking date and time (real date and time).
EvtPriceCategory
The field identifies the event price category code; this field is required during booking. For example, Gold Class or Silver Class
EvtPriceDesc
EvtPersonCode
EvtPersonDesc
The field identifies the person group description.
EvtLayoutLevelCode
EvtLayoutLevelDesc
EvtSeatingZoneCode
EvtSeatingZoneDesc
EvtSeatCode
The field identifies the seat ID, For example, B15 for fixed seating assignment bookings.
EvtLocation
EvtQty
The field identifies the number of tickets booked.
EvtTotal
The field identifies the total value of the bookings for the returned excursions.
EvtNotes
EvtPrint
The field identifies how many times the tickets had been printed.
EvtDiscount
Discount Amount.
EvtControl
EvtPrepaid
True – Prepaid at shore side, False – Book onboard.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetEvtFolio", "SESSIONID", New Object() {12345})
GetExcFolio
This function is used to request a list of excursions booked on a specific account in SPMS.
Input Parameters
psFunction= “GetExcFolio” — below is the list of psParam or poParam.
Table 4-61 psParam
pnAccID
Integer
Unique Guest ID.
Yes
pnAccID
Unique Guest Id, return from SearchPassenger.
Return Values
Table 4-62 ADO.NET Data Table field structure
ExcID
Integer
Excursion ID.
ExcNo
String(10)
Excursion Number.
ExcName
String(50)
Excursion Name.
ExcBegDate
Date
ExcEndDate
Date
ExcStatus
String(1)
Excursion Status.
ExcBookDate
Date
ExcQty
Integer
ExcTotal
Double
Booking Value.
ExcMeetDate
Date
Meeting Date and Time.
ExcMeetPlace
String(100)
Meeting Point.
ExcClothes
String(100)
Recommended Clothes.
ExcNotes
String(200)
Notes.
ExcTag
String(1)
TAG.
ExcPrint
Integer
ExcDiscount
Double
Discount Amount.
ExcControl
Integer
ExcLanguage
String(250)
Language.
ExcPrepaid
Boolean
Prepaid.
ExcCategory
String(500)
ExcID
The field identifies the unique excursion identifier. This ID can be use to link the excursion with items retrieved from Excursions message. The field is an internal, unique excursion number.
ExcNo
The field identifies the custom, users entered, a number that identifies excursion.
ExcName
The field identifies the excursion name (description).
ExcBegDate
The field identifies the excursion starting date and time.
ExcEndDate
The field identifies the excursion ending date and time.
ExcStatus
The field identifies the excursion booking status. The following status identifiers values are defined:
A
Available
F
Fully Booked
O
Overbooked
ExcBookDate
ExcQty
ExcTotal
ExcMeetDate
The field identifies the excursion participants meeting date and time.
ExcMeetPlace
The field identifies the excursion participants meeting place.
ExcClothes
The field identifies the recommended clothes for excursions participants.
ExcNotes
The field identifies the additional information about the excursion.
ExcTag
The field identifies the adult or children indicator.
A
Adult
C
Children
ExcPrint
ExcDiscount
Discount Amount.
ExcControl
ExcLanguage
Language use. For example, English.
ExcPrepaid
ExcCategory
The field identifies the categories for the excursion.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetExcFolio", "SESSIONID", New Object() {12345})
GetExcPackage
This function searches the list of excursion package available in SPMS.
The message is usually used to display a list of excursion packages that fall within the start and end date criteria. The following is the description of the fields in the message data block. A package usually contains more than one excursion; all tours within the package must fall within the start date and end date. If either date is ignored, it will return all the package belongs to current cruise.
Input Parameters
psFunction= “GetExcPackage” — below is the list of psParam or poParam.
Table 4-63 psParam
pnAccID
Integer
Unique Guest ID.
Yes
pdSDate
Date
Excursion start date.
Yes
pdEDate
Date
Excursion end date.
Yes
pnAccID
Unique Guest IdD, return from SearchPassenger.
pdSDate
The field identifies the minimum date the excursions package can start from. Enter 30-Dec-1899 to return all package belong to current cruise.
pdEDate
The field identifies the maximum date the excursions package must be completed. Enter 30-Dec-1899 to return all packages belong to current cruise.
psErrMsg
It will return an error message, For example, DB connection is down.
Return Values
Table 4-64 ADO.NET Data Table field structure for data table xxx. Return one record when input is valid
ExcPkgID
Integer
Package ID.
ExcPkgNo
String(10)
Package Number.
ExcPkgName
String(50)
Package Name.
ExcAdultPrice
Double
Package Adult Price.
ExcChildPrice
Double
Package Child Price.
ExcShowInKiosk
Boolean
ExcBookInKiosk
Boolean
ExcMaxSeat
Integer
Maximum Package or Maximum Adult Package
ExcBooked
Integer
Package or Adult Package Currently Booked
ExcAdultStatus
String(1)
Booking or Adult Booking Status.
ExcAdultAv
Integer
Package or Adult package available.
ExcMaxChildSeat
Integer
Maximum Childs Package.
ExcChildBooked
Integer
Child Package Booked.
ExcChildStatus
String(1)
Child Booking Status.
ExcChildAv
Integer
Child package available.
ExcProAdultPrice
Integer
Promotion Adult Price.
ExcProAdultAv
Integer
Promotion Adult Availability.
ExcProAdultID
Integer
Adult Promotion ID.
ExcProChildPrice
Integer
Promotion Child Price.
ExcProChildAv
Integer
Promotion Child Availability.
ExcProChildID
Integer
Child Promotion ID.
ExcID
Integer
Excursion ID.
ExcNo
String(10)
Excursion Number.
ExcName
String(50)
Excursion Name.
ExcBegDate
Date
ExcEndDate
Date
ExcMeetDate
Date
ExcMeetPlace
String (100)
Meeting Point.
ExcClothes
String (100)
ExcNotes
String (200)
Notes.
ExcPort
String (50)
Port Name.
ExcCategory
String(500)
ExcLang
String(500)
Language ID + “-“ + Language Description
With “,” as field separator.
ExcLongDesc
String(1000)
Tour Long Description.
ExcPkgID
The field identifies the unique excursion identifier. This ID can be used for excursion package booking. The field is an internal, unique excursion number.
ExcPkgNo
ExcPkgName
ExcAdultPrice
The field identifies the excursion adult price.
ExcChildPrice
The field identifies the excursion child price.
ExcShowInKiosk
The flag to denote if the excursion can be shown on the external system.
ExcBookInKiosk
The flag to denote if the excursion can be booked on the external system.
ExcMaxSeat
If PAR ‘Use Adult/Child Max Counts’ is Enabled, this is the maximum adult packages available, if the PAR is Disabled this is the total packages available.
ExcBooked
If PAR ‘Use Adult/Child Max Counts’ is Enabled, this is the adult packages currently booked on the excursion, if the PAR is Disabled this is the total packages booked.
ExcAdultStatus
The field identifies the excursion booking status. If PAR ‘Use Adult/Child Max Counts’ is Enabled, this is the adult booking status, if the PAR is Disabled this is the general booking status.
A
Available
F
Fully booked
O
Overbooked
ExcAdultAv
If PAR ‘Use Adult/Child Max Counts’ is Enabled, this is the current adult package available on the excursion, if the PAR is Disabled this is the total package available.
ExcMaxChildSeat
The field identifies the maximum child packages available. This field only valid when PAR ‘Use Adult/Child Max Counts’ is Enabled.
ExcChildBooked
The field identifies the child packages currently booked. This field only valid when PAR ‘Use Adult/Child Max Counts’ is Enabled.
ExcChildStatus
The field identifies the excursion booking status. If PAR ‘Use Adult/Child Max Counts’ is Enabled. This field only valid when PAR ‘Use Adult/Child Max Counts’ is Enabled.
A
Available
F
Fully booked
O
Overbooked
ExcChildAv
If PAR ‘Use Adult/Child Max Counts’ is Enabled, this is the current child package available. This field only valid when PAR ‘Use Adult/Child Max Counts’ is Enabled.
ExcProAdultPrice
This is the adult promotion price.
ExcProAdultAv
This is the number of packages available for adult promotion price.
ExcProAdultID
This is the adult promotion ID, it can be used during ‘ExcPackageBooking’. Please refer to pnAdultPromoID in ExcPackageBooking message type for more details.
ExcProChildPrice
This is the child promotion price.
ExcProChildAv
This is the number of packages available for child promotion price.
ExcProChildID
This is the child promotion ID, it can be used during Booking. Please refer to pnChildPromoID in ExPackageBooking message type for more details
ExcID
The field identifies the unique excursion identifier. This ID can be used for excursion booking. The field is an internal, unique excursion number.
ExcNo
ExcName
The field identifies the excursion name description.
ExcBegDate
ExcEndDate
ExcMeetDate
ExcMeetPlace
ExcClothes
ExcNotes
ExcPort
The field identifies the port for the excursion.
ExcCategory
ExcLang
The field identifies the Language ID (2 digits) + “-“ + Language Description, + “,” as the field separator. In one tour there could be more than 1 language available
For example,
EN – English
DE – German
The field will be “EN-English, DE-German”
ExcLongDesc
Tour long Description intended for ITV usage.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetExcPackage", "SESSIONID", New Object() {12345, #1/1/2011#, #1/12/2011#})
GetExcursion
This function searches and list the available excursion in SPMS.
Input Parameters
psFunction= “GetExcursion” — below is the list of psParam or poParam.
Table 4-65 psParam
pnAccID
Integer
Unique Guest ID.
Yes
pdSDate
Date
Yes
pdEDate
Date
Excursion end date.
Yes
peCodeType
ExcCodeType
Code Type.
Yes
psCode
String
Code.
Optional
pnAccID
Unique Guest ID, return from SearchPassenger.
pdSDate
The field identifies the minimum date the excursions can start from.
pdEDate
The field identifies the maximum date the excursions must be completed.
peCodeType
(Enumerator)
The field identifies the type of the code being passed for querying excursions.
None
0
PortName
1
Excursion Port Name
ExcursionNo
2
Excursion No (ExcNo)
UniqueID
3
Excursion Unique ID (ExcID)
Category
4
Excursion Category Code
psCode
The code used to query the excursions. It can be either the Port name, The Excursion No (ExcNo), the Unique ID (ExcID) or the Excursion Category Code.
Return Values
Table 4-66 ADO.NET Data Table field structure
ExcID
Integer
Excursion ID.
ExcNo
String (10)
Excursion Number.
ExcName
String (50)
Excursion Name.
ExcBegDate
Date
ExcEndDate
Date
ExcAdultStatus
String (1)
ExcAdultPrice
Double
Adult Price.
ExcChildPrice
Double
Child Price.
ExcMeetDate
Date
ExcMeetPlace
String (100)
Meeting Point.
ExcClothes
String (100)
ExcNotes
String (200)
Notes.
ExcShowInKiosk
Boolean
ExcBookInKiosk
Boolean
ExcMaxSeat
Integer
Maximum Seats or Maximum Adult Seats.
ExcBooked
Integer
Seats or Adult Seats Currently Booked.
ExcPort
String (50)
Port Name.
ExcCategory
String (500)
ExcLang
String (500)
ExcShowInITV
Boolean
Show in ITV [External Booking System].
ExcBookInITV
Boolean
ExcBookChildInITV
Boolean
Book Child Ticket in ITV [External Booking System].
ExcMaxChildSeat
Integer
Maximum Childs Seats.
ExcChildBooked
Integer
Child Seats Booked.
ExcChildStatus
String(1)
ExcProAdultPrice
Integer
ExcProAdultAv
Integer
ExcProAdultID
Integer
Adult Promotion ID.
ExcProChildPrice
Integer
ExcProChildAv
Integer
ExcProChildID
Integer
Child Promotion ID.
ExcLongDesc
String(1000)
ExcNo2
String
Excursion Brochure Number.
ExcMinSeat
Integer
Excursion minimum capacity.
ExcWeight
Integer
Total weight allow for the excursion.
ExcWeightPerGuest
Boolean
True the weight is per guest, False the weight is per tour.
ExcExternalID
String
External ID.
ExcID
The field identifies the unique excursion identifier. This ID can be used for excursion booking and is an internal, unique excursion number.
ExcNo
ExcName
ExcBegDate
ExcEndDate
ExcAdultStatus
The field identifies the excursion booking status. If PAR ‘Use Adult/Child Max Counts’ is ‘Enabled’, this is the adult booking status. If the PAR is ‘Disabled’ this is the general booking status.
A
Available
F
Fully booked
O
Overbooked
ExcAdultPrice
ExcChildPrice
ExcMeetDate
ExcMeetPlace
ExcClothes
ExcNotes
ExcShowInKiosk
ExcBookInKiosk
ExcMaxSeat
If PAR ‘Use Adult/Child Max Counts’ is Enabled, this is the maximum adult seats available on the excursion, if the PAR is Disabled this is the total seats available on the excursion.
ExcBooked
If PAR ‘Use Adult/Child Max Counts’ is Enabled, this is the adult seats currently booked on the excursion, if the PAR is Disabled this is the total seats booked on the excursion.
ExcPort
ExcCategory
ExcLang
For example,
EN – English
DE – German
The field then becomes “EN-English, DE-German”
ExcShowInITV
The flag to denote if the excursion can be shown on ITV the external system.
ExcBookInITV
The flag to denote if the excursion can be booked on the ITV external system.
ExcBookChildInITV
The flag to denote if the excursion child ticket can be booked on the ITV external system.
ExcMaxChildSeat
The field identifies the maximum child seats available on the excursion. This field only exists when PAR ‘Use Adult/Child Max Counts’ is Enabled.
ExcChildBooked
The field identifies the child seats currently booked on the excursion. This field only exists when PAR ‘Use Adult/Child Max Counts’ is Enabled.
ExcChildStatus
The field identifies the excursion booking status. If PAR ‘Use Adult/Child Max Counts’ is Enabled, this is the child booking status. This field does not exist if the PAR is Disabled.
A
Available
F
Fully booked
O
Overbooked
ExcProAdultPrice
ExcProAdultAv
This is the number of seats available for adult promotion price.
ExcProAdultID
This is the adult promotion ID, it can be used during Booking. Please refer to pnAdultPromoID in ExcBooking message type for more details.
ExcProChildPrice
ExcProChildAv
This is the number of seats available for child promotion price.
ExcProChildID
This is the child promotion ID, it can be used during Booking. Please refer to pnChildPromoID in ExcBooking message type for more details.
ExcLongDesc
Tour long description intended for ITV usage.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetExcursion", "SESSIONID", New Object() {12345, #1/1/2011#, #1/12/2011#, 0, ""})
GetFreeCabin
This function gets the available cabin for booking.
Input Parameters
psFunction= “GetFreeCabin” — below is the list of psParam or poParam.
Table 4-67 psParam
psCabinType
String
Cabin Type, “P” – Passenger, “C” - Crew.
Yes
pdEmbDate
Date
Embarkation Date.
Yes
pdDisDate
Date
Yes
pdFromDoneDate
Date
Work Order Completed From Date.
Optional
pdToDoneDate
Date
Work Order Completed To Date.
Optional
psWorkOrderDone
String
Completed Work Order Task Code, link to TYP_MWT.TYP_ART, default value XXX.
Optional
psWorkOrderNotDone
String
Unfinish Work Order Task Code, link to TYP_MWT.TYP_ART, default value XXX.
Optional
psCabinCategory
String
Cabin Category.
Optional
psFeature
String
Cabin Feature
Optional
psPartialCabin
String
First few digit of partial cabin number.
Optional
psDeck
String
Cabin Deck.
Optional
psSpecialNeed
Enum
0-All.
1-With Special Need.
2-Without Special Need.
Optional
Return Values
CResponseXml.bSuccess = False when GetFreeCabin has failed
CResponseXml.bSuccess = True when GetFreeCabin is successful, CResponse.oDataset will have 1 Data Tables.
Table 4-68 ADO.NET Data Table field structure for data table
CAB_ID
String
Cabin Number.
TYP_COMMENT
String
Cabin Category Description.
CAB_DECK
String
Cabin Deck Code.
CAB_STATUS
String
Cabin Status.
CAB_BEDS
Integer
Number of bed in this cabin.
CAB_TYPE
String
Cabin Category Code.
CAB_DECK
String
Cabin Deck.
CAB_CONNECTED
String
Connected Cabin Number.
CAB_FEATURE
String
List of Cabin Feature separated by “,”.
CAB_AVAILABLE
Integer
Available Berth.
CAB_SORT
Integer
Sort Priority.
CAB_SPECIALNEED
Integer
0-Normal Cabin, 1-cabin with special needs feature.
CAB_DECK_NAME
String
Cabin Deck Description.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetFreeCabin", "", New Object() {"P", DateTime.SpecifyKind(#1/1/2011#, DateTimeKind.Unspecified), _ DateTime.SpecifyKind(#2/1/2011#, DateTimeKind.Unspecified)})
GetHouseKeepingSections
This function returns a list of ALL housekeeping section codes and names based on the criteria below.
Input Parameters
psFunction=“GetHouseKeepingSections” — below is the list of poParam.
For Array field, pass in an empty array or “Nothing” to skip this checking.
For JSON, the array of string will be a string separated by “,”, each string must start and end with a double quotation mark (“).
For example,
“A,”””,”B,” = 2 Element
Element 1 = A,
Element 2 = B,
Table 4-69 psParam
psCrewIds
Array of String
List of unique crew Account IDs. If this is not passed in, then all HouseKeeping sections are returned.
Yes
psCabin
Array of String
List of Cabins.
Yes
psLocations
Array of String
List of Locations.
Yes
psDeck
Array of String
List of Deck.
Yes
psCabinCategory
Array of String
List of Cabin Categories.
Yes
psCabinType
Array of String
List of Cabin Types.
Yes
psCabinVerticalZone
Array of String
List of Cabin Vertical Zones.
Yes
Return Values
CResponseXml.bSuccess = False when SearchHouseKeepingSections has failed
CResponseXml.bSuccess = True when SearchHouseKeepingSections is successful, CResponse.oDataset will have 1 Data Table.
Table 4-70 ADO.NET Data Table field structure
HSC_NAME
String
Housekeeping Section Code.
HSC_COMMENT
String
Housekeeping Section Name.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetHouseKeepingSections", "Session ID", New Object() { Nothing , Nothing , Nothing , Nothing , Nothing , Nothing , Nothing })
GetILOViolations
This function retrieves all the ILO violations on a specified date for a crew.
Input Parameters
psFunction= “GetILOViolations” — below is the list of psParam or poParam.
Table 4-71 psParam
pnAccID
Integer
Unique Crew Account ID.
Either psBoardCardNo or pnAccID is required.
Yes
pdDayRequested
Date
Date of the ILO Violations.
Yes
Return Values
CResponseXml.bSuccess = False when Update failed.
CResponseXml.bSuccess = True when Update successful, CResponse.oDataset will have 1 Data Table
Table 4-72 ADO.NET Data Table field structure for data table TALG
TALG_ID
Integer
Unique ID of the record.
TALG_TCLK_ID
Integer
Unique ID of the TCLK record. Linked to TCLK.TCLK_ID.
TALG_MODDATE
Date
Last modified date.
TALG_ILO_NOTES
String
ILO Violation Notes.
TALG_MGR_NOTES
String
Manager approval notes.
TALG_ILO_7DAYS
Integer
1=violation for ILO for 7 days (exceeded max worked hours for the last 7 days).
TALG_ILO_24HRS
Integer
1=violation for ILO 24hrs (exceeded max worked hours for the last 24hrs).
TALG_ILO_MINRESTBLOCK
Integer
1=violation for ILO minimum rest hr block.
TALG_ILO_MINREST_7DAYS
Integer
1=violation for ILO minimum rest hours in 7 days.
TALG_ILO_MINREST_24HRS
Integer
1=violation for ILO minimum rest hours for the last 24hrs.
GetLuggageInfo
This function retrieves the luggage movement of the guest.
Input Parameters
psFunction= “GetLuggageInfo” — below is the list of psParam or poParam.
Table 4-73 psParam
peSearchType
Enum
InternalID = 0 'res_acc.
PGID = 1 'res_pgid.
BoardCard = 2 'res_boardcc.
PaxID = 3 'res_referenz.
Cabin = 4 'res_cab.
Yes
psSearchStr
String
Unique Payer Account ID or
Board Card or
PGID or
Pax ID depends on the peSearchType.
Yes
peSearchLevel
Enum(Byte)
0 – By Passenger.
1 – By Cabin.
2 – By Booking No.
Yes
peSearchStatus
Enum(Byte)
0 – All Location (All Status).
1 – Latest Location (Current Status).
Yes
Return Values
CResponseXml.bSuccess = False when nothing is found or invalid input parameters.
CResponseXml.bSuccess = True when successful. CResponse.oDataset will have 1 Data Tables.
The Data Tables will be different depending on peSearchStatus input parameter.
Table 4-74 ADO.NET Data Table field structure for data table for peSearchStatus = 0
Code Type Description
LUG_ACC_ID
Integer
Unique Account ID.
UXP_A_FSTN
String(40)
Guest First Name.
UXP_A_NAME
String(40)
Guest Last Name.
LUM_RFID
String(20)
RFID Tag.
LUM_ZONE
String(20)
Zone ID.
LUM_TYPE
String(20)
RFID Type – as send from Strategic.
PAIRING_TIME
Date
The time the tag is associated with the guest
LUM_MOVEMENT
Date
The scan time of the tag.
TIME_REMAINING
Integer
Number of minutes before delivery to room/pier (From the last movement time).
LUZ_LOCATION
String(50)
Actual Location.
DIRECTION
String(8)
Inbound or Outbound.
GUEST_LOCATION
String(50)
Guest Friendly Location Description.
DELIVERED
Integer
1-Delivery to guest room, 0-Not yet delivery.
QUARANTINE
Integer
Y-In quarantine zone, N-In normal zone.
PERCENT_COMPLETE
Double
Percentage complete for delivery.
Table 4-75 ADO.NET Data Table field structure for data table for peSearchStatus = 1
LUG_ACC_ID
Integer
Unique Account ID.
UXP_A_FSTN
String(40)
Guest First Name.
UXP_A_NAME
String(40)
Guest Last Name.
LUM_RFID
String(20)
RFID Tag.
LUM_ZONE
String(20)
Zone ID.
LUM_TYPE
String(20)
PAIRING_TIME
Date
FIRSTSCAN_TIME
Date
The time the tag first scan, For example,on X-Ray machine
LUM_MOVEMENT
Date
Last movement time of the bag.
DELIVERY_TIME
Date
Expected delivery time.
TIME_REMAINING
Integer
Number of minutes before delivery to room/pier from current time.
LUZ_LOCATION
String(50)
Actual Location.
DIRECTION
String(8)
GUEST_LOCATION
String(50)
DELIVERED
Integer
QUARANTINE
Integer
PERCENT_COMPLETE
Double
Example:
oResponse = goWS.FidelioSPMSWSXML("GetLuggageInfo", "SessionID", New Object() {0,12345,0,1})
GetMicrosAdvanceDiscount
This function gets the list of eligible advance MICROS discount list.
Input Parameters
psFunction= “GetMicrosAdvanceDiscount” — below is the list of psParam or poParam.
Table 4-76 psParam
pnAccID
Integer
Unique Guest ID.
Yes
pnAccID
Return Values
CResponseXml.bSuccess = True when GetMicrosAdvanceDiscount is successful, CResponse.oObj returns list of discount in a string separated by ASCII 10, it mainly for display purpose only.
CResponseXml.bSuccess = False when GetMicrosAdvanceDiscount has failed.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetMicrosAdvanceDiscount", "", New Object() {12345})
GetPackageInfo
This function gets the list of Package Plan assigned to the passenger.
Input Parameters
psFunction=“GetPackageInfo” — below is the list of psParam or poParam.
Table 4-77 psParam
pnAccID
Integer
Unique Guest ID.
Yes
pbIncludeDisablePackage
Boolean
True=Include Disable Package.
False=Just return active package.
Optional
pnAccID
Return Values
CResponseXml.bSuccess = False when GetPackageInfo has failed
CResponseXml.bSuccess = True when GetPackageInfo is successful, CResponse.oDataset will have 2 Data Tables.
Table 4-78 ADO.NET Data Table field structure for first data table
PPN_NAME
String
Name of the Package Plan.
PPN_DAY_CREDIT
Double
Package Total.
PPP_DEBIT
Double
Package Used.
PPP_BOOKMARK
Integer
A point to the record position of the second data table.
PPP_SELECTED
Integer
Record filtering, when 0 should hide the record from the second data table. However, the implementation is up to the client.
PPN_USE_DEP_TOTAL
Integer
1 - Different Department Total has it own limit
PPP_ID
Integer
Unique Package ID.
PPN_FLEX_PACKAGE
Integer
Flexible Package Flag, the guest will need to choose the available department from the setup.
AvailableBalance
Double
Available Balance = PPN_DAY_CREDIT – PPP_DEBIT
Table 4-79 ADO.NET Data Table field structure for second data table
DEP_PPP_ID
Integer
Unique Package ID = PPP_ID of the first data table.
DEP_ID
String
Department ID or Main Department ID.
DEP_NAME
String
Department Name or Main Department Name.
DEP_TOTAL
Double
This will be the individual department total when PPN_USE_DEP_TOTAL = 1.
DEP_MAIN
Boolean
Indicate this record is the Department or Main Department.
DEP_DISC
Double
Discount Percentage that the posting amount will go to package plan.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetPackageInfo", "", New Object() {12345})
GetPeopleCount
This function gets the onboard/shoreside count per the WPF Security module.
Input Parameters
psFunction= “GetPeopleCount”, no parameter.
psParam
None.
Return Values
CResponseXml.bSuccess = False when not connection to the DB.
CResponseXml.bSuccess = True and CResponseXML.PeopleCoun
Table 4-80 PeopleCount field structure
nPaxTotal
Integer
Total Passenger.
nPaxShoreside
Integer
Total Passenger shore side.
nPaxOnboard
Integer
Total Passenger on board.
nPaxOvernight
Integer
Total Passenger shore side with overnight tour.
nPaxExpected
Integer
Total expected passenger to check-in today.
nPaxDisembaraked
Integer
Total passenger disembark today.
nResTotal
Integer
Total Resident.
nResShoreside
Integer
Total Resident shore side.
nResOnboard
Integer
Total Resident on board.
nResOvernight
Integer
Total Resident shore side with overnight tour.
nResExpected
Integer
Total expected resident to check-in today.
nResDisembaraked
Integer
Total resident disembark today.
nCrwTotal
Integer
Total Crew.
nCrwShoreside
Integer
Total Crew shore side.
nCrwOvernight
Integer
Total Crew on board.
nCrwOnboard
Integer
Total Crew shore side with overnight tour.
nCrwExpected
Integer
Total expected crew to check-in today.
nCrwDisembaraked
Integer
Total crew disembark today.
nTotal
Integer
Total.
nTotalOnboard
Integer
Total shore side.
nTotalShoreside
Integer
Total on board.
nTotalOvernight
Integer
Total shore side with overnight tour.
nTotalExpected
Integer
Total expected to check-in today.
nTotalDisembaraked
Integer
Total disembark today.
nVisTotal
Integer
Total visitor on board.
nPaxNotPassImmigration
Integer
Total passenger not yet pass immigration gate.
nCrewNotPassImmigration
Integer
Total crew not yet pass immigration gate.
nResNotPassImmigration
Integer
Total resident not yet pass immigration gate.
nPaxExcludeImmigration
Integer
Total passenger no need to pass immigration gate.
nCrewExcludeImmigration
Integer
Total crew no need to pass immigration gate.
nResExcludeImmigration
Integer
Total resident no need to pass immigration gate.
sPortName
String
Port Description.
oVisitor
Array or CVisitorDetailCount
This only applies to HRG only.
Table 4-81 CVisitorDetailCount
Code
String
Visitor Category Code.
Description
String
Visitor Category Description.
Count
Integer
Total Visitor on board.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetPeopleCount", "SESSIONID", New Object() {})
GetPreviousClockInOutActivities
This function retrieves the previous days’ clock-in/out transactions.
Input Parameters
psFunction= “GetPreviousClockInOutActivities” — below is the list of psParam or poParam.
Table 4-82 psParam
pnAccID
Integer
Yes
pnDays
Integer
Optional. The number of previous days to get. If 0 then will default to days defined in parameter ‘Display Previous X Days Clock-In/Out at terminal.’
Return Values
CResponseXml.bSuccess = True when Update successful, CResponse.oDataset will have 1 Data Table.
Table 4-83 ADO.NET Data Table field structure for data table TCLK
TCLK_DATETIMESTAMP
Date
Date time stamp of the clock-in/out transaction.
TCLK_IN_OUT
String
‘I’ for clock-in, ‘O’ for clock-out.
TCLK_ENTRYTYPE
String
‘A’ for auto, ‘M’ for manual.
TARS_CODE
String
Task work code.
TARS_NAME
String
Task work name.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetPreviousClockInOutActivities", "SessionID", New Object() {12345, 0})
GetRFIDEncodingData
This function retrieves the Ving door lock information and charge card information from SPMS.
Input Parameters
psFunction= “GetRFIDEncodingData” — below is the list of psParam or poParam.
Table 4-84 psParam
peSearchType
Enum
0 = Internal ID.
1 = PGID.
2 = BoardCard.
3 = Pax ID.
Yes
psSearchStr
String
Board Card or
PGID or
Yes
psRFIDUID
String(16)
Convert the value to HEX.
Yes
Return Values
CResponseXml.bSuccess = False when failed.
Table 4-85 ADO.NET Data Table field structure for data table
TRACK1
String(76)
Track 1 – Custom Information.
TRACK2
String(37)
Track 2 – SPMS Charge Card information.
TRACK2_BIN
Byte(7)
Numeric Track 2 In Binary Format (Excluding Expiry).
TRACK3
String(200)
Track 3 - Ving encoding string format.
ENCODED
Boolean
True=Previously Encoded, False=New RFID.
ACCID
Integer
Unique Guest ID.
TRACK1_CUSTOM
STRING(168)
84-byte Hex String representing ASCII track 1 - including 00s at the end For example, 32363534323735315E4C5E4F415E43335E32303134303530335E4A6F686E5E536D6974685E416E74686F6E7900000000000000000000000000000000000000000000000000000000000000000000000000000000.
TRACK2_CUSTOM
STRING(24)
Custom Track 2 - 8-byte Hex String representing numerical RES_BOARDCC concatenated with 4 byte- Hex String representing numerical DEBARK_DATE) For example, 8126E86056F62200E5513301.
TRACK3_CUSTOM
STRING(96)
48-byte HexString representation of the VING String including any 00s at the end. For example, B824935021D7B0C2A81573C63456F85AB3B15D2DFA7E91F0000000000000000000000000000000000000000000000000.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetRFIDEncodingData", "SessionID", New Object() {0,12345,”E01581A07C123B”})
GetSeatingZoneAvailability
This function requests for all available Seats of a given Event, Layout Level and Seating Zone from the SPMS.
Input Parameters
psFunction= “GetSeatingZoneAvailability” — below is the list of psParam or poParam.
Table 4-86 psParam
pnEvtID
Integer
Event ID.
Yes
EvtLayoutLevelID
Integer
Layout Level ID.
Yes
EvtSeatingZoneID
Integer
Seating Zone ID.
Yes
pnEvtID
The field identifies the unique event ID. This ID can be obtained through GetEvent WebMethod. The field is an internal, unique event number.
EvtLayoutLevelID
The field identifies the unique Layout Level identification number. This ID can be obtained through GetEvent WebMethod. The field is an internal, unique layout level number.
EvtSeatingZoneID
The field identifies the unique Seating Zone identification number. This ID can be obtained through GetEvent WebMethod. The field is an internal, unique seating zone number.
Return Values
CResponseXml.bSuccess = True and CResponseXML.oTables(0) = ADO.NET data table when input values are valid.
Table 4-87 ADO.NET Data Table field structure for data table
TKSD_ID
Integer
TKSD_CODE
String(20)
Seat ID.
TKSD_ID
The field returns the unique ID for each Seat.
TKSD_CODE
The field returns the Seat ID.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetSeatingZoneAvailability", "SESSIONID", New Object() {62, 82, 24})
GetTreatmentGroupsForLocation
This function is used to request for all Treatment Groups assigned to each Location from the SPMS.
Input Parameters
psFunction= “GetTreatmentGroupsForLocation” — below is the list of psParam or poParam.
Table 4-88 psParam
psSPATreatmentGroups
String
All Default Treatment Groups assigned to a Location, separated by commas.
Yes
All Default Treatment Groups assigned to a Location, separated by commas as returned by WSF function, GetSPALocation in field spl_treatment_groups.
Return Values
Table 4-89 ADO.NET Data Table field structure
typ_art
String
Treatment Group Code.
typ_comment
String
Treatment Group Description.
TYP_ART
The field returns the Treatment Group Code.
TYP_COMMENT
The field returns the Treatment Group Description.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetTreatmentGroupsForLocation", "SESSIONID", New Object() {"BODY,FACE,"})
GuestSearch
This function searches for guests with various criteria from the SPMS.
Input Parameters
psFunction= “GuestSearch” — below is the list of psParam or poParam.
Table 4-90 psParam
psSearchStr
String
Search Criteria.
Yes
pdDate
Date
Embarkation Date.
Yes
peGuestType
GuestType
Guest Type Enumerator.
Yes
peReservationType
ReservationType
Reservation Type Enumerator.
Yes
pbUseSearchType
Boolean
True-Use specific search type
False = Use only Search Criteria.
Yes
peSearchType
SearchType
SearchType Enumerator.
Yes
pnScdID
Integer
Current Port ID.
Optional
peOnboardStatus
OnboardStatus
– All.
– Onboard.
– Shoreside.
Optional
psSearchStr
This is the search criteria, supported values as shown below:
  • Cabin number
  • Guest Name
  • Board Card Track 2 and must include “;” and “?” in the string. For example, “;9841000241243900?”
  • Credit Card Track Data and must include the start and end sentinel in the search string. For example “;” and “?”)
  • Cabin List, separate by “,”. For example,”05002,05000”.
  • Passport Number
  • Name List (Last Name separate by “,”)
  • Booking Number
pdDate
Embarkation date, if you want to search for all guest regardless of the embarkation date, pass in #12:00:00AM#
peGuestType
(Enumerator)
Guest
0
Search guest matching search criteria
Crew
1
Search crew matching search criteria
Visitor
2
Search visitor matching search criteria
All
3
Search guest,crew,visitor matching search criteria
peReservationType
(Enumerator)
Reserve = Search only passenger with reservation status only (Note visitor always have reservation status only)
Reserve
0
Reservation passenger
CheckIn
1
Searches only passenger that had check-in
All
2
Search both check-in and reserve passenger
CheckOut
3
Search check-out passenger only
ReserveFCManagement
4
Reservation passenger, for shore viewer
CheckInFCManagement
5
Searches only passenger that had check-in, for shore viewer
CheckOutFCManagement
6
Search check-out passenger only, for shore viewer
Cancelled
7
Canceled reservation passenger.
AQCIWizardCheckIn
8
Use by AQCI Wizard Only
AQCIWizardRegister
9
ReserveExcludeNoShow
10
Reservation passenger excluding No Show
NoShow
11
No Show Passenger only
pbUseSearchType
True = Use specific search type. The search type is normally used to return the same group of guest. For example,
  • Search using passport number; function will return list of guests staying in the same cabin
  • Search using credit card number; function will return a list of guests staying in the same cabin.
  • Want to return a specific guest using UXP_A_ID (SPMS unique key) value.
Below is anincorrect use of search type:-
Search by name;
In general, there could be more than one guest with the same name, if this happens then the function will search for the first guest in SPMS database that matches the name criteria and returns the list of guests staying in that same cabin. Since this is based on the first found record and returns the list of names based on that, this may not be accurate.
peSearchType
(Enumerator)
SamePartialName = 0
  1. This only works when search criteria psSearchStr passed in is the last name, board card track 2 or credit card track data.
  2. The psSearchStr is the partial last name, it will search for guest with matching the partial last name.
  3. The psSearchStr is board card track 2 or credit card track data, it will search using the supplied information. When there are records found, it will take the first record last name and search again for all guest with the same partial last name.
  4. If the search criteria are other than three of the above, it will only return the first record matching the search criteria.
SameSurname = 1
  1. It will search using the supplied information. When there are records found, it will take the first record last name and search again for all guest with the same last name.
  2. However, if the first record last name is blank, it will only return the first record.
NameList = 2
  1. If the search criteria passed in is a list of last names separate by “,”, it will search for guests matching the partial last names in the list.
  2. If the psSearchStr is a partial last name, it will search for guest matching the partial last name
  3. If the psSearchStr is board card track 2 or credit card track data, it will search using the supplied information. When there are records found, it will take the first record last name and search again for all guests with the same partial last name.
  4. For other search criteria, it will search using the supplied information.
SameCabin = 3
  1. It will search using the supplied information. When there are records found, it will take the first record cabin number and search again for all guests with the same cabin number.
  2. However, if the first record cabin number is blank, it will only return the first record.
SameCabinList = 4
  1. If the search criteria passed in is a list of cabin numbers separate by “,”, it will search for all guests matching the cabin number in the list.
  2. The psSearchStr is cabin number, it will search for all guests matching the cabin number
  3. For other search criteria, it will search using the supplied information.
SameBookingNo = 5
  1. t will search using the supplied information. When there are records found, it will take the first record booking number and search again for all guest with the same booking number.
  2. However, if the first record booking number is blank, it will only return the first record.
SameGroupNo = 6
  1. It will search using the supplied information. When there are records found, it takes the first record group number and searches again for all guests with the same group number.
  2. However, if the first record group number is blank, it only returns the first record.
SameRouting = 7
  1. It will search using the supplied information. When the first record is found, it will check if this account has routings to another account. If yes, then the list of records returned would include the first record found and all other accounts that share the same routing as the first account.
  2. However, if the first record found does not have routings to another account, then it will search for all accounts that have routings to the first record found.
AccountID = 8
This is an SPMS internal account ID, so the parameter psSearchStr passed in should be a valid ID (UXP_A_ID). All other parameters (pdDate, peGuestType, peReservationType) passed in will be ignored.
Return Values
  • CResponseXml.bSuccess = True and CResponseXML.oTables(0) = ADO.NET data table when input values are valid. The data table contains
  • all fields in uxp table, all fields in res table,
  • uxp_a_name field or uxp_a_othname field,
  • uxp_a_fstn field or uxp_a_othfstn field, and
  • org_assembly field or res_station field or cab_station field or par_value from par table.
See SPMS Data Dictionary for details of the data fields.
Note
In all the above statements when we mention “first record found” and the function returns more than one record and the list of records returned does not have any specific sort order, we cannot predict which record will be the first to display.
Example:
oResponse = goWS.FidelioSPMSWSXML("GuestSearch", "SessionID", New Object() {"05002",#01-01-2011#,3,0,True,3})
GetPackageTreatmentAvailability
This function requests the SPA Package Treatment Availability by time slot from the SPMS.
Input Parameters
psFunction= “GetPackageTreatmentAvailability” — below is the list of psParam or poParam.
Table 4-91 psParam
pnAccID
Integer
Account ID.
Yes
pnSPATreatmentItem
Integer
Treatment Item ID.
Yes
pnSPAPackageID
Integer
Package ID.
Yes
pdDateFrom
Date
Starting Date period.
Optional
pdDateTo
Date
Ending Date period.
Optional
pnAccID
pnSPATreatmentItem
The field identifies the unique Package treatment item identification. The field is an internal, unique code. This field is retrieve from GetSPAPackageItems or GetSPAPackageItemsForPeriod WebMethods.
pnSPAPackageID
The field identifies the unique Package ID. The field is an internal, unique code. This value is retrieved from GetSPAPackages WebMethod.
pdDateFrom
The fields identify the optional Starting and Ending Dates period for which the system will return availability time slots when pnAccID is set to 0.
pdDateTo
Return Values
Table 4-92 ADO.NET Data Table field structure
spa_date
Date
Date and Time.
spa_price
Double
Treatment Price.
SPA_DATE
The field returns the date which the treatment is available.
SPA_PRICE
The field identifies the Package treatment item price.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetPackageTreatmentAvailability", "SESSIONID", New Object() {12345, 12, 15})
oResponse = goWS.FidelioSPMSWSXML("GetPackageTreatmentAvailability", "SESSIONID", New Object() {0, 12, 15, #1/1/2011#, #1/12/2011#})
GetTreatmentAvailability
This function requests the SPA Treatment Availability by time slot from the SPMS.
Input Parameters
psFunction= “GetTreatmentAvailability”, — below is the list of psParam or poParam.
Table 4-93 psParam
pnAccID
Integer
Account ID.
Yes
pnSPALocation
Integer
Location ID.
Yes
pnSPATreatmentItem
Integer
Treatment Item ID.
Yes
pdDateFrom
Date
Optional
pdDateTo
Date
Ending Date period.
Optional
pnAccID
pnSPALocation
The field identifies the unique location ID. The field is an internal, unique code. This value is retrieved from GetSPALocation WebMethod.
pnSPATreatmentItem
The field identifies the unique treatment item identification. The field is an internal, unique code. This field is retrieve from GetSPATreatmentItem or GetSPATreatmentItemForPeriod WebMethods.
pdDateFrom
pdDateTo
Return Values
Table 4-94 ADO.NET Data Table field structure
spa_date
Date
Date and Time.
spa_price
Double
Treatment Price.
SPA_DATE
SPA_PRICE
The field identifies the treatment item price.
Example:
oResponse = goWS.FidelioSPMSWSXML("GetTreatmentAvailability", "SESSIONID", New Object() {12345, 123, 12})
oResponse = goWS.FidelioSPMSWSXML("GetTreatmentAvailability", "SESSIONID", New Object() {0, 123, 12, #1/1/2011#, #1/12/2011#})
Login
This function logged in the user into the system and return a session ID. You must use this session ID to subsequent function calls.
The Login function can only be called with JSON POST or WS XML. JSON GET is not supported for Login.
Input Parameters
psFunction= “Login” — below is the list of psParam or poParam.
Table 4-95 psParam
psLoginName
String
User Login Name.
Yes
psPassword
String
Plain Text Password.
Yes
pnRowsPerPage
Integer
Default 0 = Unlimited, Number of Rows Return per Page.
Optional
psPassword
Plain text password
Return Values
CResponseXml.bSuccess = True when Login is successful
CResponseXml.bSuccess = False when Login has failed
When login is successful
CResponseXML.oObj return array of string
Table 4-96 Return Values
oObj(0)
String
Session ID, you must use this ID when making a subsequence call.
Yes
oObj(1)
String(99000)
User Security Access, a string of “0” and “1”.
Yes
oObj(2)
Boolean
True = Is Administrator.
Yes
oObj(3)
String
User Full Name.
Yes
oObj(4)
Integer
User Crew ID if link.
Yes
oObj(5)
Boolean
Must change the password before proceeding. If you do not change the password, you are not allowed to call any other function.
Yes
oObj(6)
Boolean
Allow to change the password.
Yes
If oObj(5) and oObj(6) both is True mean you should not allow the user to login.
Example:
oResponse = goWS.FidelioSPMSWSXML("Login", "", New Object() {"admin", "23f9d46d769b154c511f80a016784059"})
Logout
This function logs out the user and the session ID will become invalid, you must call the “Login” function again in order to use the system.
Input Parameters
psFunction= “Logout” do not have any parameter
Return Values
CResponseXml.bSuccess always = True
Example:
oResponse = goWS.FidelioSPMSWSXML("Logout", "SessionID", Nothing)
MarkAsNoShow
This function marks the expected guest as no show.
Input Parameters
psFunction= “MarkAsNoShow” — below is the list of psParam or poParam.
Table 4-97 psParam
pnAccID
Integer
Unique Account ID.
Yes
Return Values
CResponseXml.bSuccess = True when Update successful.
Example:
oResponse = goWS.FidelioSPMSWSXML("MarkAsNoShow", "SessionID", New Object() {12345})
MarkAssignmentStatus
This function updates all housekeeping assignment task status for a particular cabin or location for a selected date and port.
Input Parameters
psFunction=“MarkAssignmentStatus” — below is the list of psParam or poParam.
Table 4-98 psParam
pnHASstatus
Integer
Housekeeping Assignment Task Status (0-Pending, 1-Started, 2-Completed)
Yes
pbIsCabin
Boolean
True – Cabin, False – Public Location.
Yes
psLocation
String
Cabin Number or Public Location Code.
Yes
pdAssignedDate
Date
Date of the Housekeeping Assignment Task.
Yes
pnPortID
Integer
Port ID. Linked to SCD.SCD_ID. A task that was created and linked to this port.
Yes
psHASComment
String
Assignment Comment.
Yes
Return Values
CResponseXml.bSuccess = True when Update is successful
CResponseXml.bSuccess = False when Update has failed
Example:
oResponse = goWS.FidelioSPMSWSXML("MarkAssignmentStatus", "SessionID", New Object() {2,True,1024,<AssignedDate>,123, "Comment"})
MarkSingleAssignmentStatus
This function updates a single housekeeping assignment task status for a particular housekeeping assignment record.
Input Parameters
psFunction=“MarkSingleAssignmentStatus” — below is the list of psParam or poParam
Table 4-99 psParam
pnHASID
Integer
Housekeeping Assignment Record ID
Yes
pnHASstatus
Integer
Yes
psHASComment
String
Assignment Comment. If there are no comment updates, pass in empty string
Yes
pnACCid
Integer
Crew Account ID, the crew who has been assigned to this task. If there are no updates to this field, pass in 0
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("MarkAssignmentStatus", "SessionID", New Object() {12345,2,",0})
MessageDelete
This function flag a message as deleted in SPMS database.
Input Parameters
psFunction= “MessageDelete” — below is the list of poParam.
Table 4-100 psParam
Code Type Description Required
pnMsgID
Integer
Unique Message ID.
Yes
Return Values
CResponseXml.bSuccess = False when MessageDelete has failed
CResponseXml.bSuccess = True when MessageDelete is successful
Example:
oResponse = goWS.FidelioSPMSWSXML("MessageDelete", "Session ID", New Object() {123)})
MessageRead
This function returns a list of messages from SPMS database.
Input Parameters
psFunction= “MessageRead” — below is the list of poParam.
For Date field pass in 30-Dec-1899 if not required.
Table 4-101 psParam
psMsgDirection
String
S - All sent messages from the user that logged in.
R – All received messages for the user that logged in.
Yes
pdMsgDateFrom
Date
Retrieve Messages from this date. Pass in DEFAULT_DATE if this is not required.
Yes
pdMsgDateTo
Date
Retrieve Messages until this date. Pass in DEFAULT_DATE if this is not required.
Yes
pnMsgProfileType
Integer
1=message to/from a guest.
2=message to/from another crew member (private messages).
3=Official ship messages including broadcasted alert messages.
Yes
pnMsgDeleted
Integer
Message deleted? (1-deleted, 0-not deleted yet).
Yes
psMsgModule
String
Messaging for which module (TA=TimeAttendance, HK=HouseKeeping, OTHER=for others).
Yes
Return Values
CResponseXml.bSuccess = False when MessageRead has failed
CResponseXml.bSuccess = True when MessageRead is successful, CResponse.oDataset will have 1 Data Table.
Table 4-102 ADO.NET Data Table field structure for data table ordered by field TAMS_MODDATE in descending order
TAMS_ID
Integer
Unique Message ID.
TAMS_CRW_ID
Integer
Message for this crew. Unique Crew identifier. Linked to RES.RES_ACC.
TAMS_FROM
Integer
Message from this crew. Unique user login identifier. Linked to USR.USR_ID
TAMS_SUBJECT
String
Message subject.
TAMS_MSG
String
Message Content.
TAMS_MSG_CREATED
Date
Message created date.
TAMS_READ
String
Message read? (1-read, 0-not read yet).
TAMS_READ_DATE
Date
Message read date.
TAMS_DELETED
String
TAMS_MSG_TYPE
Number
0-Individual message, 1-Broadcasted message.
TAMS_MODULE
String
Messaging for which component (TA=TimeAttendance, HK=HouseKeeping, CPL=Complaints, CHKIN=Upon Checkin, CABCHG=Cabin Change).
TAMS_PROFILE
Number
Type of Message (1-Passenger, 2-Crew, 3-Ship).
TAMS_LEVEL
Number
Message Level (1-Normal, 2-High).
TAMS_TO_USR_ID
Number
Message for this person. Linked to USR.USR_ID.
TAMS_FROM_ACCID
Number
Message from this person. Linked to RES.RES_ACC.
TAMS_MODDATE
Date
Last modified date.
CRWNAME
String
Crew Member’s Name.
CRW_ID
Number
Crew ID.
OPO_ID
String
Position ID.
OPO_POSITION
String
Position Name.
DEPTID
String
Department ID.
DEPTNAME
String
Department Name.
TAMS_EXTERNALID
Number
Linked to external record ID. (TAMS_MODULE='CPL',>>CPL_ID), (TAMS_MODULE='CHKIN',>>RES_ACC), (TAMS_MODULE='CABCHG',>>RES_ACC).
XDOC_FILE
Blob
Binary file contained inside the table that stored the document (Compressed).
XDOC_FILENAME
String
Name of the file.
XDOC_SIZE
Number
Size of file before compression.
Example:
oResponse = goWS.FidelioSPMSWSXML("MessageRead", "Session ID", New Object() {‘R’, DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified), DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified),2,0,’OTHER’})
MessageSend
This function adds new messages created externally into SPMS database.
Note: Not supported when it is connected to an offline QCI Sync database.
Input Parameters
psFunction= “MessageSend”, — below is the list of poParam.
Table 4-103 psParam
pnMsgID
Integer
Unique Message ID (TAMS_ID). Put 0 for adding new record.
Yes
pnFromUsrLogin
Long
Unique User ID of the crew that is sending the message. In SPMS, this is the USR.USR_ID value.
Yes
pnToUsrLogin
Long
Unique User ID of the crew that is receiving the message. In SPMS, this is the USR.USR_ID value.
Yes
psMsgSubject
String
Message subject.
Yes
psMsgContent
String
Message content.
Yes
pnProfileType
Integer
Message Profile Type. 1-Guest, 2-Crew, 3-Ship.
Yes
pnMsgLevel
Integer
Message Level. 1-Normal, 2-High.
Yes
pnMsgStatus
Integer
Message Status. 1-Sent, 2-Read, 3-Deleted.
Yes
pdMsgCreated
Date
Message created date & time.
Yes
psMsgModule
String
Yes
Return Values
CResponseXml.bSuccess = False when MessageSend has failed
CResponseXml.bSuccess = True when MessageSend is successful
CResponesXml.oObj = TAMS_ID when bSuccess = True
Example:
oResponse = goWS.FidelioSPMSWSXML("MessageSend", "Session ID", New Object() {123, 345, <Subject>, <MessageContent>, 2, 1, 2, DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified) ,’OTHER’})
MessageSetRead
This function flag a message as read in SPMS database.
Input Parameters
psFunction=“MessageSetRead” — below is the list of poParam.
Table 4-104 psParam
pnMsgID
Integer
Unique Message ID.
Yes
Return Values
CResponseXml.bSuccess = False when MessageSetRead has failed
CResponseXml.bSuccess = True when MessageSetRead is successful
Example:
oResponse = goWS.FidelioSPMSWSXML("MessageSetRead", "Session ID", New Object() {123)})
OHCCreditCardAddRouting
This function identifies a list of guests to be routed to the payer with a registered credit card.
Input Parameters
psFunction= “OHCCreditCardAddRouting” — below is the list of psParam or poParam.
Table 4-105 psParam
Parameter Type Description Required
TerminalId
Integer
POS Terminal Identifier.
Yes
paBuyer
Array of String
Unique Buyer Account Numbers.
Yes
pnPayer
Integer
Unique Payer Internal Account Number.
Yes
Return Values
CResponseXml.bSuccess = True and CResponseXML. CCreditCard when input values are valid.
Table 4-106 CCreditCard field structure
TerminalId
Integer
POS Terminal Identifier which sent the request.
Example:
oResponse = goWS.FidelioSPMSWSXML("OHCCreditCardAddRouting", "SESSIONID", New Object() {12345678, New String() {“1026604”,”1026605”,”1026606”} , 1026601})
OHCCreditCardGetAmount
This function obtains the guest card type (debit/credit) and the pre-authorization/payment amount.
Input Parameters
psFunction= “OHCCreditCardGetAmount” — below is the list of psParam or poParam.
Table 4-107 psParam
TerminalId
Integer
Yes
pnPayer
Integer
Yes
pnCardBin
Integer
First 6 digit (BIN) of the Payment Card Number (PAN).
Yes
TerminalMode
String
POS Mode: “UNATTENDED” or “ATTENDED”.
Yes
Return Values
Table 4-108 CCreditCard field structure
TerminalId
Integer
gnTransID
Integer
Unique Transaction Reference ID.
gsCardType
String
“DEBIT” or “CREDIT” or “COMBO”.
gsCurrency
String
Currency used onboard. Only “EUR” or “USD”.
If the currency is different from the one used by the POS, the POS will abort the current transaction. In that case, after the periodic function (TmlTweet) an automatic currency alignment procedure is performed by the POS (no need of any other FC action).
gnAmount1
Integer
PreAuthorization (only for Credit Card during registration) or Payment Amount.
The amount is expressed In cents. For example, 125000 = 1.250,00.
gnAmount2
Integer
Second Payment Amount (only for Debit/Combo card) (in cents).
gnAmount3
Integer
Third Payment Amount (only for Debit/Combo card) (in cents).
gnAmount4
Integer
Fourth Payment Amount (only for Debit/Combo card) (in cents).
gnAmount5
Integer
Fifth Payment Amount (only for Combo card) (in cents).
gbDebitRefund
Boolean
Indicate if there is refund amount on debit card
True – charge amount >= invoice balance.
False – charge amount < invoice balance.
POS in unattended mode: if <gbLastday> askfor a payment only if <gbDebitRefund> is false.
POS in unattended mode: if not <gbLastDay> doesn’t care about <gbDebitRefund>.
gsCruiseId
String
Cruise Identifier.
Example:
oResponse = goWS.FidelioSPMSWSXML("OHCCreditCardGetAmount", "SESSIONID", New Object() {12345678, 1026601, 411111, “UNATTENDED”})
OHCCreditCardGuestSearch
This function searches the guest account by cruise card.
Input Parameters
psFunction= “OHCCreditCardGuestSearch” — below is the list of psParam or poParam.
Table 4-109 psParam
TerminalId
Integer
Yes
psSearchStr
String
Swiped MSC Cruise Card PAN within ‘;’ and ‘?’. Example: 9841000099628100?
Yes
Return Values
CResponseXml.bSuccess = True and CResponseXML.CCreditCard when input values are valid.
Table 4-110 CCreditCard field structure
TerminalId
Integer
gnPayer
Integer
Unique Payer Account Number. It matches with one record (usually the first) in goAccount array (see below).
gsCabin
String
Guest Cabin Number.
gdEmbDate
Date
Guest Embarkation Date (DD/MM/YYYY).
gdDebDate
Date
Guest Debarkation Date (DD/MM/YYYY).
gbCardRegistration
Boolean
Identify if card registration is allowed.
gsCruiseId
String
Cruise Identifier.
gbRouting
Boolean
Identify if routing can be performed.
True – routing allowed.
False – routing not allowed (routing already done).
gbLastDay
Boolean
Indicate if today it’s the last day cruise for the guest.
goAccount
Array of CGuest
Array of CGuest.
Table 4-111 CGuest field structure
gnAccID
Integer
SPMS Internal Account Number.
gsFirstName
String
First Name.
gsLastName
String
Last Name.
Example:
oResponse = goWS.FidelioSPMSWSXML("OHCCreditCardGuestSearch", "SESSIONID", New Object() {12345678, “;9841000099628100”})
OHCCreditCardTmlTweet
This function is used to monitor the POS mode and provide POS information.
Input Parameters
psFunction= “OHCCreditCardTmlTweet” — below is the list of psParam or poParam.
Table 4-112 psParam
TerminalId
Integer
Yes
IpAddress
String
Ip address assigned to POS.
Yes
ReleaseSW
String
SW version loaded into the POS.
Yes
TerminalMode
String
POS Mode: “ATTENDED” or “UNATTENDED”.
Yes
Currency
String
Only “USD” or “EUR”.
Yes
PendingNumber
Integer
A number of pending transactions to be performed once the connection with Payment Server (GT) will be automatically established.
Return Values
CResponseXml.bSuccess = False when input values are invalid or no record found.
CResponseXml.bSuccess = True and CResponseXML.TerminalNotification when input values are valid.
Table 4-113 TerminalNotification field structure
TerminalId
Integer
Settings
TAG Settings
TAG Settings (see below).
Table 4-114 TAG Settings field structure
TerminalId
Integer
Settings
TAG Settings
Example:
oResponse = goWS.FidelioSPMSWSXML("OHCCreditCardTmlTweet", "SESSIONID", New Object() {12345678, “[IP ADDRESS]”, “01.10”, ”UNATTENDED”, ”EUR”, 0}})
OHCCreditCardUpdateCardInfo
This function sends the results of pre-authorization (credit card registration) or payment transaction to SPMS.
Input Parameters
psFunction= “OHCCreditCardUpdateCardInfo”, — below is the list of psParam or poParam.
Table 4-115 psParam
TerminalId
Integer
Yes
pnAccID
Integer
Unique Payer Internal Account Number (Equal to gnPayer of GuestSearchResponse).
Yes
pnTransID
Integer
Unique Transaction Reference ID (Equal to gnTransID of GetAmountResponse).
Yes
psCardExpMMYY
String
Card Expiry Date in MMYY.
pnCDebitIndicator
Integer
0=Credit Card; 1=Debit Card.
Yes
psCaptureMethod
String
‘I’= ICC (Chip); ‘A’=Swiped (ICCFallback); ‘M’=MoTo (pending executed).
Yes
psToken
String
Credit Card Token
First 6 and last 4 digits are the same as the credit card number (PAN)
If “pending transaction” is generated (psResult = “PENDING”) Token is temporary (pseudoToken):
For example, “41111199999999999999999999991111”
Yes
psSignature
String
Hex ASCII signature or Hex (jpg,bmp,png) format.
pnAmount
Integer
Amount being authorized/settled
The amount is expressed In cents. For example, 30000 = 300,00
Yes
psResult
String
Update Card Info Status:
“PENDING” = only for a credit card if, during a registration, the online connection to the Payment Server (GT) is not possible. psToken is temporary.
“APPROVE” = transaction (debit or credit, auth or direct sale) approved.
“DECLINE” = transaction (debit or credit, auth or direct sale) not approved/aborted.
Yes
psTransType
String
‘AUTH’=Pre-authorization (only credit card).
‘PAYMENT’=Direct sales for credit/debit card.
Yes
psAuthCode
String
Authorization Code.
pnSTAN
Integer
STAN of the transaction. Sequential Transaction Number in Payment Gateway (GT).
psReceipt
String
Transaction Receipt.
pnCardBin
Integer
First 6 digits (BIN) of Payment Card Number (PAN).
Yes
psCurrency
String
The currency used for the transaction. Only ‘USD’ or ‘EUR’
pnActionCode
Integer
Action Code.
psAcquirerName
String
Acquirer/Card name.
psDateTime
String
Transaction Date and Time in the following format: YYYY-MM-DDThh:mm:ssZ.
For example, “2014-11-28T15:17:46Z”
Note that the Date and Time are of the POS/GT, not the current ones (on the vessel).
Return Values
Table 4-116 CCreditCard field structure
TerminalId
Integer
Example:
oResponse = goWS.FidelioSPMSWSXML("OHCCreditCardUpdateCardInfo", "SESSIONID", New Object() {12345678, 1026604, 171859, “”, 0, “I”, “4111111EF6BBE22235E0AA0D7E43F1111“, “”, 25000, “APPROVE”, “AUTH”, “x12345”, 000002, “”, 411111})
PayCrewInvoice
This function searches for folio deduction for payrolls using various criteria from the SPMS system.
Input Parameters
psFunction= “PayCrewInvoice” — below is the ordered list of input parameters and its descriptions
Table 4-117 psParam
UXP_A_ID
Integer
Required input. Unique identifier of UXP record - UXP_A_ID.
Yes
BTD
String
Required input. Balance-to-date specifier. If TRUE, folio deduction will be based on up-to-date payroll balance. If FALSE, folio deduction will be based on total payroll end-balance supposedly available at the end of the month.
Yes
AmountPayable
Decimal
Required input. The amount of folio deduction.
Yes
Currency
String
Required input. Currency sign. Can use the currency sign return from previous ”QueryCrewInvoice” function call.
Yes
Return Values
CResponseXml.bSuccess = False when WS function did not execute successfully. For example, due to invalid input parameters.
CResponseXml.bSuccess = True when WS function executed successfully, and
CResponseXML.oDataSet = ADO.NET dataset. The dataset will contain table SSH and SPP of the payroll used in folio deduction. *
Remark:
See SPMS Data Dictionary for details of the fields.
Example:
oResponse = goWS.FidelioSPMSWSXML("PayCrewInvoice", "SessionID", New Object() {12345, True, 250.00, “USD”})
PurchasePackage
This function is used for Package Plan purchase. Please refer to FCWSFunction Technical Specification, GetPackagePurchase function on how to obtain a list of package preset for user selection.
Input Parameters
psFunction= “PurchasePackage” — below is the list of psParam or poParam.
Table 4-118 psParam
pnAccID
Integer
Unique Account ID.
Yes
pnPpnID
Integer
Unique Package Plan ID.
Yes
pnRvc
Integer
MICROS POS Revenue Center Number.
Yes
psRvcName
String(30)
MICROS POS Revenue Center Name.
Yes
pnEmpl
Long
MICROS POS Employee Number.
Yes
pnWSID
Long
MICROS POS Workstation ID.
Yes
pbyImage
Byte Array
Signature Image.
Optional
psTeam1
String(12)
Posting additional information - Server number 1
Optional
pnChkEmplNum
Long
Employee number on initial order
Optional
Return Values
CResponseXml.bSuccess = False when Purchase failed.
CResponseXml.bSuccess = True when Purchase successful. CResponseXml.oObj return the check image for printing
Example:
oResponse = goWS.FidelioSPMSWSXML("PurchasePackage", "SessionID", New Object() {12345,123457,1,"Restaurant",1234,1,<Signature Image byte array>)
Use WSFunction->GetPackagePurchase to get a list of available package to purchase
QueryCrewInvoice
This function returns crew member’s invoice information along with information about his/her available payroll credit for folio deduction.
Input Parameters
psFunction= “QueryCrewInvoice” — below is the ordered list of input parameters and its descriptions.
Table 4-119 psParam
UXP_A_ID
Integer
Yes
BTD
String
Required input. Balance-to-date specifier. If TRUE, will return up-to-date payroll balance available for folio deduction. If FALSE, will return total payroll end-balance supposedly available at the end of the month.
Yes
Return Values
CResponseXML.oDataSet = ADO.NET dataset. The dataset will contain table SSH and SPP of the payroll to be used for folio deduction. *
CResponseXML.oCrewInvoice(0) = information about available payroll credit for folio deduction.
  • Amount = uxp_a_pos_debit - uxp_a_pos_credit, total invoice amount in onboard currency.
  • AmountPayable = invoice amount, in wage currency, that can be settled via folio deduction.
  • Currency = onboard currency.
  • AvailPay = available payroll amount or credit.
  • WageCurrency = CTR_WAGE_CUR_TYP *CurrencyConvRate = onboard to wage currency conversion rate.
Remark:
Example:
oResponse = goWS.FidelioSPMSWSXML("QueryCrewInvoice", "SessionID", New Object() {12345, True})
RegisterRFIDBoardCard
This function associates a RFID board card to a guest for the purpose of door key encoding at door lock with Visionline System. This feature is applicable to cards encoded externally before embarkation day. The door key encoding will happen at the door lock only when the guest has checked in and the card is used at the lock.
The guest to be registered must have an expected reservation. Guests that are checked-in, checked-out or with a canceled reservation will be rejected. Also, guests already issued with a door-key encoded board card will be rejected as well.
In the event that the card belongs to another person, the function will also reject the registration. The only time such card can be re-registered under the new person is when the card has not been encoded with door key and the person is currently not checked-in.
When registration is successful, it will override the previously registered board card for the guest.
Note: The above validation is not applicable when connected to offline QCI Sync DB.
Input Parameters
psFunction= “RegisterRfidBoardCard” — below is the list of psParam or poParam.
Table 4-120 psParam
pnAccID
Long
Unique Payer Account ID.
Yes
psUID
String
UID of The RFID Board Card.
Yes
Return Values
This function supports enhanced error messaging:
CResponseXml.sErrorMsg: detailed long description of the error.
CResponseXml.sErrWord: short brief description of error title.
CResponseXml.sErrCode: 6-CHAR or less error code.
Example:
oResponse = goWS.FidelioSPMSWSXML("RegisterRfidBoardCard", "SessionID", New Object() {12345,”CD125E84”})
RegisterRFIDBoardCardQuery
This function queries SPMS on the passed in UID before “RegisterRfidBoardCard” is called to make sure “RegisterRfidBoardCard” will be successful.
Input Parameters
psFunction= “RegisterRfidBoardCardQuery” — below is the list of psParam or poParam.
Table 4-121 psParam
pnAccID
Long
Yes
psUID
String
Yes
Return Values
CResponseXml.sErrCode: 6-CHAR error code. (can be less than 6-char).
Example:
oResponse = goWS.FidelioSPMSWSXML("RegisterRfidBoardCardQuery", "SessionID", New Object() {12345,”CD125E84”})
RetrievePage
This function searches for a guest using various criteria from the SPMS system.
Input Parameters
Table 4-122 psParam
pnPage
Integer
Page Number.
Yes
psFunction
String
Last call function.
Yes
psWSFunction
String
Need to pass in when psFunction = ‘WSFunction.’
Optional
Return Values
CResponseXml.bSuccess = False when RetrievePage has failed.
CResponseXml.bSuccess = True when RetrievePage is successful.
Other value depend on the psFunction and psWSFunction, refer to the psFunction for detail.
SearchAmenity
This function is an advanced amenity search.
Input Parameters
psFunction= “SearchAmenity” — below is the list of poParam
Please take note some parameters are optional. However, the more parameters passed in, the fewer records it will return.
For JSON, the array of string will be a string separated by “,”, each string must start and end with a double quotation (“).
For example,
Element 1 = A,
Element 2 = B,
Table 4-123 psParam
peReservationType
Integer
ReserveAndCheckIn,
1 – Reserve,
2- CheckIn,
3- CheckOut.
pdExpDeliveryDateFrom
Date
Amenity Delivery Date (AME_DDATE)If nothing is passed in, then it will skip this criteria.
pdExpDeliveryDateTo
Date
pdDeliveredDateFrom
Date
Amenity Service Done Date (AME_DONE_DATE)If nothing is passed in, then it will skip this criteria.
pdDeliveredDateTo
Date
psGuestLastName
String
Guest Last Name (UXP_A_NAME)If nothing is passed in, then it will skip this criteria.
psGroupID
Array of String
Travel Group ID (UXP_A_ID)If nothing is passed in, then it will skip this criteria.
psCabinCategory
Array of String
Cabin Category (TYP_CAT.TYP_ART)If nothing is passed in, then it will skip this criteria.
psDeliveryLocation
Array of String
Amenity Delivery Location (AME_LOCATION)If nothing is passed in, then it will skip this criteria.
psDeck
Array of String
Cabin Deck (TYP_DEK.TYP_ART)If nothing is passed in, then it will skip this criteria.
psDeliveredBy
Array of String
Amenity Delivery By (USR.USR_ID)If nothing is passed in, then it will skip this criteria.
psCabin
Array of String
Unique Cabin IDs (CAB.CAB_ID)If nothing is passed in, then it will skip this criteria.
psAmenityCode
Array of String
Amenity Code (TYP_AMT.TYP_ART)If nothing is passed in, then it will skip this criteria.
psDepartment
Array of String
Amenity Delivery Division (AME_ODI_ID)If nothing is passed in, then it will skip this criteria.
psHKSection
Array of String
Housekeeping Section Name (HSC_NAME)If nothing is passed in, then it will skip this criteria.
Return Values
CResponseXml.bSuccess = False when SearchAmenity has failed
CResponseXml.bSuccess = True when SearchAmenity is successful, CResponse.oDataset will have 1 Data Table.
Table 4-124 ADO.NET Data Table field structure
AME_ID
Integer
Amenity ID (Unique ID).
AMECODE
String
Amenity Code. Linked to TYP_AMT.TYP_ART.
AMENAME
String
Port Name. Linked to TYP_AMT.TYP_COMMENT.
ACCID
Integer
Account ID.
NAME
String
Guest Name.
RESSTATUS
String
Reservation Status.
VIPCODE
String
VIP ID. Linked to TYP_VIP.TYP_ART.
VIPNAME
String
VIP Name. Linked to TYP_VIP.TYP_COMMENT.
PORTID
String
Embarkation Port ID.
PORTNAME
String
Embarkation Port Name. Linked to TYP_HRB.TYP_COMMENT.
GROUPID
Integer
Travel Group Reference ID.
GROUPNAME
String
Travel Group Name.
CABINID
String
Unique Cabin ID.
HSC_NAME
String
HSC_COMMENT
String
AME_LOCATION
String
Amenity Delivery Location.
AME_ODI_ID
String
Amenity Delivery Division ID. Linked to TYP_ODI.TYP_ART.
TYP_COMMENT
String
Amenity Delivery Division Name. Linked to TYP_ODI.TYP_COMMENT.
CAB_VZONE
String
Cabin vertical zone. Linked to TYP_VTZ.TYP_ART.
CAB_VZONE_NAME
String
Cabin vertical zone description. Linked to TYP_VTZ.TYP_COMMENT.
CAB_TYPE
String
Cabin Type ID. Linked to TYP_CAT.TYP_ART.
TYP_COMMENT1
String
Cabin Type Name. Linked to TYP_CAT.TYP_COMMENT.
CAB_DECK
String
Cabin Deck ID. Linked to TYP_DEK.TYP_ART.
TYP_COMMENT2
String
Cabin Deck Name. Linked to TYP_DEK.TYP_COMMENT.
AME_DDATE
Date
Amenity Delivery Date.
AME_DONE_DATE
Date
Amenity Service Done Date.
AME_DONE_USERID
Integer
Amenity Service done by the waiter. Linked to USR.USR_ID.
USR_LOGIN
String
User Login Name.
CAB_KEEPER
Integer
Housekeeper ID. Linked to RES.RES_ACC.
CAB_KEEPER_NAME
String
Housekeeper Name.
CAB_A_KEEPER
Integer
Assistant Housekeeper ID. Linked to RES.RES_ACC.
CAB_A_KEEPER_NAME
String
Assistant Housekeeper Name.
CAB_G_WAITER
Integer
Waiter ID. Linked to RES.RES_ACC.
CAB_G_WAITER_NAME
String
Waiter Name.
CAB_A_WAITER
Integer
Assistant Waiter. Linked to RES.RES_ACC.
CAB_A_WAITER_NAME
String
Assistant Waiter Name.
AME_AMOUNT
Double
Amenity Price.
AME_COMMENTS
String
Amenity Comments.
AME_COST
Integer
Amenity Cost.
AME_CREATED_BY
Integer
User Created Amenity Request.
AME_CREATED_DATE
Date
Amenity Created Date.
AME_CURR_ID
String
Amenity price currency.
Linked to TYP_CUR.TYP_ART.
AME_EXT_CODE
String
External Brochure Code.
AME_EXT_ID
String
External ID.
AME_FLG
String
Displayed as a flag in the Amenities section in guest billing screen. Not been referenced anywhere else.
AME_MESSAGE
String
Message From Sender.
AME_MODDATE
Date
Last Modified Date.
AME_NOTE
String
Amenity Description.
AME_OCCURRENCE
String
Amenity Deliver Occurrence.
AME_QUANTITY
Integer
Amenity Quantity.
AME_RESBOOKNR
String
External Reservation Booking Number.
Linked to RES.RES_BOOKNR.
AME_RESID
Integer
Reservation account ID.
Linked to RES.RES_ID.
AME_SENDER1
String
Amenity Sender.
AME_SENDER2
String
Amenity Sender 2 (Not been referenced).
AME_V_GUESTID
Integer
Reservation System account ID.
Linked to RES.RES_V_GUESTID.
AME_VID
String
Unique ID.
Example:
oResponse = goWS.FidelioSPMSWSXML("SearchAmenity", New Object() {<ReservationType>,<ExpDeliveryDateFrom>,<ExpDeliveryDateTo>,<DeliveryDateFrom>,<DeliveryDateTo>,<LastName>,<GroupID>,<CabinCategory>,<DeliveryLocation>,<Deck>,<DeliveryBy>,<CabinID>,<AmeCode>,<Department>,<HKSection>})
SearchCabin
This function performs an advanced search on cabins in SPMS. If a date is passed in, then only the list of crash cabins found for that date will be returned.
Input Parameters
psFunction= “SearchCabin — below is the list of poParam.
Please note that all the parameter is “Optional” and the more parameters pass in, the fewer records it will return.
For Date field pass in 30-Dec-1899 if it is not required.
For example,
Element 1 = A,
Element 2 = B,
Table 4-125 psParam
psCabin
Array of String
Unique Cabin IDs.
Yes
psCabinHKStatus
Array of String
Cabin Housekeeping Status (OD, OC, VD, VC).
Yes
psCabinAvlStatus
Array of String
Cabin Availability (OO, OV, BL, AV).
Yes
psHKSection
Array of String
Housekeeping section codes.
Yes
psDeck
Array of String
Cabin Deck (TYP_DEK.TYP_ART).
Yes
psCabinCategory
Array of String
Cabin Category (TYP_CAT.TYP_ART).
Yes
psCabinType
Array of String
‘P’ for Pax, ‘C’ for Crew.
Yes
psCabinVerticalZone
Array of String
Cabin Vertical Zone (TYP_VTZ.TYP_ART).
Yes
pdCrashCabinDate
Date
Date to check for crash cabins. If do not require to check for crash cabins please pass in 30-Dec-1899.
Yes
psCabinSpecialNeeds
Array of String
0-Normal Cabin,1-Cabin with special need feature.
Yes
psCabinFeatures
Array of String
Features available in the cabin. Linked to TYP_CAF.TYP_ART.
Yes
Return Values
CResponseXml.bSuccess = False when SearchCabin has failed.
CResponseXml.bSuccess = True when SearchCabin is successful, CResponse.oDataset will have 2 Data Table.
Table 4-126 ADO.NET Data Table field structure for data table (“CAB”). This lists the cabins and its details.
CAB_ID
String
Unique Cabin ID.
CAB_DESIGN
String
CAB_STATE
String
Cabin Availability Status (OO=Out of Order, OS=Out of Service, BL=Blocked, AV=Available).
CAB_BEDS
Number
No of beds/berths in the cabin.
CAB_BEDS_SETUP
String
Beds setup for each cabin. Format saved A,B,C,D,E or 1,2,3,4,5.
CAB_TEL
String
Cabin Telephone Number.
CAB_TEL2
String
Cabin Telephone Number 2.
CAB_BEG_BLOCK_D
Date
The cabin is pending repairs, this field stores the date for when this cabin is blocked from.This is the 'Block From' field in FC Admin Cabin setup.
CAB_REPAIR_D
Date
The cabin is pending repairs, this field stores the date for when this cabin is blocked until.This is the 'Block Until' field in FC Admin Cabin setup.
CAB_REPAIR_T
String
The cabin is pending repairs, this field stores the unavailability reason when CAB_STATE=OO or OS or BL. This is the 'Unavailability Reason' field in FC Admin Cabin setup.
CAB_LIFEBOAT
String
Lifeboat this cabin is assigned to. TYP_BOT.TYP_ART.
CAB_LIFEBOAT_NAME
String
Lifeboat this cabin is assigned to. TYP_BOT.TYP_COMMENT.
CAB_STATION
String
Muster Station this cabin is assigned to. Linked to MST.MST_ID.
CAB_STATION_NAME
String
Muster Station this cabin is assigned to. Linked to MST.MST_NAME.
CAB_LOCATION
Integer
Null-Undefine,1-Forward,2-Mid Ship.3-Aft
CAB_STARBOARD
Integer
0-Portside,1-Starboard.
CAB_CAT
String
Cabin Type. Linked to TYP_CAT.TYP_ART.
CAB_CAT_NAME
String
Cabin Type Description. Linked to TYP_CAT.TYP_COMMENT.
CAB_DECK
String
Cabin Deck. Linked to TYP_DEK.TYP_ART.
CAB_DECK_NAME
String
Cabin Deck Description. Linked to TYP_DEK.TYP_COMMENT.
CAB_HKSTATUS
String
Cabin Housekeeping status (OD, VD, OC, VC). Linked to TYP_CCS.TYP_ART.
CAB_HKSTATUS_NAME
String
Cabin Housekeeping status description. Linked to TYP_CCS.TYP_COMMENT.
CAB_VZONE
String
CAB_VZONE_NAME
String
CAB_CRW_POSITION
String
Assign default crew position to a cabin.
CAB_KEEPER
Integer
Unique Crew ID. Housekeeper assigned to this cabin for gratuity distribution. Linked to RES.RES_ACC. This is the 'Keeper' field in the FC Admin Cabin setup.
CAB_KEEPER_NAME
String
Keeper’s Crew Name.
CAB_A_KEEPER
Integer
Unique Crew ID. The assistant housekeeper that is assigned to this cabin for gratuity distribution. Linked to RES.RES_ACC. This is the 'Assistant Keeper' field in the FC Admin Cabin setup.
CAB_A_KEEPER_NAME
String
Assistant Keeper’s Crew Name.
CAB_H_WAITER
Integer
Unique Crew ID. Head Waiter that is assigned to this cabin for gratuity distribution. Linked to RES.RES_ACC. This is the Head Waiter' field in the FC Admin Cabin setup.
CAB_H_WAITER_NAME
String
Head Waiter’s Crew Name.
CAB_A_WAITER
Integer
Unique Crew ID. The assistant waiter that is assigned to this cabin for gratuity distribution. Linked to RES.RES_ACC. This is the 'Assistant Waiter' field in the FC Admin Cabin setup.
CAB_A_WAITER_NAME
String
Assistant Waiter’s Crew Name.
CAB_G_WAITER
Integer
Unique Crew ID. The waiter that is assigned to this cabin for gratuity distribution. Linked to RES.RES_ACC. This is the Waiter' field in the FC Admin Cabin setup.
CAB_G_WAITER_NAME
String
Waiter’s Crew Name.
HKSECTION_NAME
Integer
Housekeeping Section Name. Linked to HSC.HSC_NAME.
HKSECTION_COMMENT
String
Housekeeping Section Comment. Linked to HSC.HSC_COMMENT.
HSC_CRW
String
Housekeeping Crew ID. List of Housekeeping crew ID that can be assigned housekeeping tasks.
CAB_SPECIALNEED
Integer
CAB_FEATURE
String
SearchCntrAssgn
Input Parameters
psFunction= “SearchCntrAssgn” — below is the ordered list of input parameters and its descriptions.
Table 4-127 psParam
MemoryLifeSpan
Integer
Optional in seconds, default as zero. If set to non-zero, resultset will be kept in memory for reuse when a subsequent call is issued within the specified time interval with MemoryReuse = TRUE.
Optional
MemoryReuse
Boolean
Optional, default as FALSE. When set to TRUE, the search will not query DB but instead just return records from the previous result set.
Optional
RecordPerPage
Integer
Optional, default as zero. Specify the number of unique person records for which their contracts will be returned. If it is zero, it will return all records in the result set.
Optional
PageNum
Integer
Optional, default as zero for page 1. Specify the page to return in a multi-page result set.
Optional
UXP_A_IDs
String
Optional. Comma delimited UXP_A_ID.
Optional
SearchStr
String
Optional. If specified, will be used to search based on following fields. The order of following also determines the sequence in which the search is carried out until a match is received.
RES_BOARDCC (exact match),
RES_CC_NUMBER (exact match),
RES_CAB (exact match),
UXP_A_NAME_N (partial match), and
UXP_C_EXTERNALID or UXP_C_INTERNALID (exact match) depending on PAR “Display UXP_C_EXTERNALID As Crew ID”.
Optional
ORDER_BY
String
Optional. Only supports UXP, RES and CTR column ordering.
Optional
RES_STATUSs
String
Optional. Comma delimited RES_STATUS. *
Optional
EMB_DATE_01
Date
Optional. EMB_DATE_01 and EMB_DATE_02 specify the date range of NVL(res_emb_a,res_emb_e). Or CTR_BEG_DATE if NOB.
Optional
EMB_DATE_02
Date
Optional. EMB_DATE_01 and/or EMB_DATE_02 specify the date range of NVL(res_emb_a,res_emb_e). Or CTR_BEG_DATE if NOB.
Optional
DEB_DATE_01
Date
Optional. DEB_DATE_01 and/or DEB_DATE_02 specify the date range of NVL(res_dis_a,res_dis_e). Or CTR_END_DATE if NOB.
Optional
DEB_DATE_02
Date
Optional
CTR_STATUSs
String
Optional. Comma delimited CTR_STATUS. *
Optional
SGR_IDs
String
Optional. Comma delimited SGR_ID.
Optional
CTR_TYP_CTRs
String
Optional. Comma delimited CTR_TYP_CTR.
Optional
CTR_NOB_FLAG
String
Optional. “1” for NOB assignments. “0” for normal assignments.
Optional
CTR_PCY_IDs
String
Optional. Comma delimited CTR_PCY_ID.
Optional
CTR_XCET_IDs
String
Optional. Comma delimited CTR_XCET_ID.
Optional
UXP_H_NATIONs
String
Optional. Comma delimited UXP_H_NATION.
Optional
ENDING_PYRL
Boolean
Optional. If TRUE, will return assignment with pending final month payroll.
Optional
Return Values
CResponseXml.bSuccess = True when WS function executed successfully, along with
CResponseXML.oDataSet = Nothing, when no record is found. Otherwise,
CResponseXML.oDataSet = ADO.NET dataset, which will contain table ACC (UXP/RES), CTR, SPD, COH, PCY, SED, SPO and XCET. *
CResponseXML.nTotalPage = total number of pages in the resultset, when input parameter RecordPerPage is specified.
Remark:
See SPMS Data Dictionary table for details of the fields.
Example:
oResponse = goWS.FidelioSPMSWSXML("SearchCntrAssgn", "SessionID", New Object() {60, True, 10, 1, “”, “123”, “UXP_C_EXTERNALID”, “RR,RE,RX,RN,CC,CL,DD”, _
“”,“”,“”,“”, “A,C”, “”, “”, “”, “0”, “”, “”, “”,False})
SearchComment
This function searches for the guest comment.
Input Parameters
psFunction= “SearchComment” — below is the list of poParam.
For Array field, pass in an empty array or “Nothing” to skip this checking.
For JSON, the array of string will be a string separated by “,”, each string must start and end with a double quotation mark (“).
For example,
“A,”,“B,” = 2 Elements
Element 1 = A,
Element 2 = B,
Table 4-128 psParam
pdFrom
Date
From date range.
Yes
pdTo
Date
To date range.
Yes
psCabin
Array of String
List of Cabin.
Optional
pnUsrID
Array of Long
List of user who created the comment.
Optional
psComplaintCode
Array of String
List of Comment Description Code (TYP_CPL.TYP_ART).
Optional
psReportType
Array of String
List of Report Type Code (TYP_CPI,TYP_ART).
Optional
psCategory
Array of String
List of Comment Category (TYP_CMC.TYP_ART).
Optional
peDone
Integer
0 - All, 1 - Done, 2 - Not Done.
Optional
peUrgent
Integer
0 – All, 1 – Urgent, 2 – Not Urgent.
Yes
peSensitive
Integer
0 – All, 1 – Sensitive, 2 – Not Sensitive.
Yes
peGuestType
Integer
0 – All, 1 – Crew, 2 – Staff, 3 – Crew and Staff, 4 - Guest.
Yes
psDeptInvolved
Array of String
Department Involved code (TYP_CDI.TYP_ART).
Yes
psOperationPosition
Array of String
Operation Position (OPO_ID), operation position is link to department involved.
Optional
pbIncludePicture
Boolean
True = Will return the comment picture/document.
False = Will return nothing, this is for slow device, so it will need to look up the picture using WSF using the value CPL_XDOC_ID, default = True.
Optional
pnAccID
Array of Integer
List of Account ID.
Optional
Return Values
CResponseXml.bSuccess = False when SearchComment has failed.
CResponseXml.bSuccess = True when SearchComment is successful, CResponse.oDataset will have 1 Data Table if paging is not use 2 Data Table is paging is use (Login.pnRowsPerPage > 0), please take note all the same cpl_link_id will be return with the exception of psCabin and pnAccID.
Table 4-129 ADO.NET Data Table field structure for data table for table 1 when paging is in use
CPL_LINK_ID
Integer
Link ID between the parent comment and child comment and resolution and also link to multiple guest comment.
CPL_ACC_ID
Integer
CPL_RES_DONE
Integer
0 – Not Resolved, 1 - Resolved.
Table 4-130 ADO.NET Data Table field structure for table 1 - paging not in use, table 2 - paging in use.
CPL_ID
Integer
Unique ID.
CPL_LINK_ID
Integer
CPL_ACC_ID
Integer
Account ID.
CPL_USR_ID
Long
User who create the comments/resolution.
CPL_TYPE
String
C-Comment, R-Resolution.
CPL_DATE
Date
Date/Time the comment/resolution created.
CPL_EXT_ID
String
External Code.
CPL_DESCR_CODE
String
Resolution Description Code (TYP_RES.TYP_ART).
CPL_DESCR
String
Comment/Resolution Description.
CPL_COMMENT
String
Comment/Resolution Comment.
CPL_REQ_RES_DATE
Date
Requested Resolution Date.
CPL_RES_DONE
Integer
CPL_RES_BY
String
Person who done the resolution.
CPL_RES_DATE
Date
Resolution Resolved Date.
CPL_RES_COST
Decimal
Comment/Resolution Associate Cost.
CPL_REPORT_TYPE
String
Define Comment Reporting Method.
CPL_URGENT
Integer
0-Default;1-Urgent.
CPL_CRW_ID
Integer
The Crew link to the CPL_USR_ID.
CPL_SENSITIVE
Integer
0-Default, 1-Sensitive.
CPL_TYP_CMC
String
Comment Category Code (TYP_CMC.TYP_ART).
CPL_XDOC_ID
Integer
Scan Document/Picture, Link to xdoc_id.
CPL_VID
String
External Unique ID for use with import.
CPL_VEN_ID
Integer
Vendor ID, link to VEN.VEN_ID
CPL_INTERNAL
Integer
Internal Usage Flag
CPL_DEPARTMENT_INVOLVED
String
Comment Department Involved Codes. Separated by comma (,) (TYP_CDI.TYP_ART).
CRW_NAME
String
Crew Name who created the comment/resolution base on the crew link in user setup.
UXP_A_TAG
String
P-Pax, C-Crew or Staff.
NAME
String
Guest Name.
RES_CAB
String
Cabin Number.
CATEGORY
String
Comment Category Description.
REPORTTYPE
String
Comment Report Type Description.
DESCRCODE
String
Comment Description Code Description.
XDOC_FILE
Array of Byte
The doc/picture uploaded.
XDOC_FILENAME
String
The filename of the doc/picture, use the file extension to determine if it is a document or picture.
XDOC_ISPICTURE
Integer
1-This is a picture,0-This is a document, need to use the XDOC_FILENAME to determine the document type.
Example:
For example, this is to search all comment for cabin 05000 and 05002
oResponse = FidelioWS("SearchComment", New Object() {DateTime.SpecifyKind(<From Date>, DateTimeKind.Unspecified), _
DateTime.SpecifyKind(<To Date>, DateTimeKind.Unspecified), _
New String() {"05002", "05000"}, Nothing, Nothing, Nothing, _
Nothing, 0, 0, 0, 0, Nothing, Nothing, False, False, Nothing})
SearchCrashCabin
This function searches for ‘crash cabins’ in SPMS. Crash Cabin is defined as guests who checks in and checks out into the same cabin on the same day and port.
Input Parameters
psFunction= “SearchCrashCabin” — below is the list of poParam.
Table 4-131 psParam
pdDateSelected
Date
Date of check-in/check-out for searching crash cabins. If 30-Dec-1899 is passed in, then it will search based on SPMS system date.
Yes
psPortID
String
Port ID. Linked to SCD.SCD_PORT_ID. If an empty string is passed in, then it will search for all ports for pdDateSelected.
Yes
Return Values
CResponseXml.bSuccess = False when SearchCrashCabin has failed
CResponseXml.bSuccess = True when SearchCrashCabin is successful, CResponse.oDataset will have 1 Data Table.
Table 4-132 ADO.NET Data Table field structure for data table.
CABIN
String
Unique Cabin ID.
SCD_PORT_ID
String
Port Name.
Example:
oResponse = goWS.FidelioSPMSWSXML("SearchCrashCabin", "Session ID", New Object() {DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified),0})
SearchGangwaylog
This function gets the gangway activities from SPMS.
Input Parameters
psFunction= “SearchGangwaylog” — below is the list of psParam or poParam.
Table 4-133 psParam
pdFromDate
Date
From date & time.
Yes
pdToDate
Date
To date & time.
Yes
pnAccID
Integer
Unique Account ID.
Yes
psLocation
String
Gangway location.
Yes
psMovement
String
Movement.
Yes
psAccType
String
Account Type.
Yes
psCab
String
Cabin Number.
Yes
psName
String
Name.
Yes
peSortType
Integer
Sort Type.
Optional
Below are the descriptions of the parameters.
pdFromDate
From date and time.
pdToDate
To date and time.
pnAccID
Unique Account ID, this is optional, if you want to search all guest, pass in 0.
psLocation
This is the location where the guest pass through the gangway.
psMovement
Pass in blank for all movement. Below is the valid value:
IMMIGRATION UNCHECK
IMMIGRATION CHECK
Going Shore-side
Coming Onboard
psAccType
Account Type, pass in blank for all. Below is the valid value:
C
G
V
psCab
Cabin number
psName
Guest Name, if “,” exists, all text before “,” will be first name, all text after “,” will be the last name. If “,” does not exist we will search the last name only.
peSortType
0 – Sort by GLG_ID ASC
1 – Sort by GLG_ID DESC
2 – Sort by GLG_DATE ASC
3 – Sort by GLG_DATE DESC
Default = 0
Return Values
CResponseXml.bSuccess = False when SearchGangwaylog has failed
CResponseXml.bSuccess = True when SearchGangwaylog is successful, CResponse.oDataset will have 1 Data Tables.
Table 4-134 ADO.NET Data Table field structure for data table
GLG_DATE
Date
Movement Date and Time.
GLG_STATION
String
PC Name where the movement is done.
GLG_LOCATION
String
Location where the movement takes place.
GLG_MOVEMENT
String
Movement direction.
UXP_A_FSTN
Integer
First Name.
UXP_A_NAME
String
Last Name.
UXP_A_TAG
String
Account Type P-Passenger,C-Crew,V-Visitor.
RES_CAB
String
Cabin Number.
GLG_SHORE_DENIED
Integer
Flag overridden shore leave denied passenger.
GLG_SWIPE
String
Yes-Card is swipe, No-Manual Enter.
TYP_COMMENT
String
Port Name (Only exists in Ferry Mode).
RES_ACC
Integer
Unique Account ID.
Example:
oResponse = goWS.FidelioSPMSWSXML("SearchGangwaylog", "", New Object() { DateTime.SpecifyKind(#1/1/2011 1:00:00 pm#, DateTimeKind.Unspecified), _ DateTime.SpecifyKind(#2/1/2011 6:00:00 pm#, DateTimeKind.Unspecified),0, "", "", "", "", ""})
SearchHKForecast
This function returns a list of itinerary port days and list of guests’ reservations per cabin.
Input Parameters
psFunction= “SearchHKForecast” — below is the list of poParam.
For example,
“A,”””,”B,” = 2 Element
Element 1 = A,
Element 2 = B,
Table 4-135 psParam
pdItineraryFrom
Date
Port Itinerary From Day.
Yes
pdItineraryTo
Date
Port Itinerary To Day.
Yes
psCabinHKstatus
Array of String
Cabin Housekeeping Status.
Yes
psHKSection
Array of String
Housekeeping Section.
Yes
psDeck
Array of String
Cabin Deck.
Yes
psCabin
Array of String
Cabins.
Yes
psCabinAvlStatus
Array of String
Cabin Availability Status.
Yes
pdCrashCabinDate
Date
Date to search for Crash Cabins.
Yes
Return Values
CResponseXml.bSuccess = False when SearchHKForecast has failed.
CResponseXml.bSuccess = True when SearchHKForecast is successful, CResponse.oDataset will have 4 Data Table.
Table 4-136 ADO.NET Data Table 1(“ITIN”) - Master Table 1 lists all the itinerary port days
SCD_ID
Integer
Unique Port Day ID.
SCD_DATE
Date
Port Date.
PORTNAME
String
Port ID (SCD_PORT_ID).
PORTDESCR
String
Port Name.
SCD_DESCR
String
Port Description.
SCD_ARRIVE_TIME
Date
Port Arrival Time.
SCD_DEPART_TIME
Date
Port Departure Time.
Table 4-137 ADO.NET Data Table 2 (“CABINS”) – Master Table 2 lists all cabins
CAB_ID
Integer
Unique Cabin ID.
CAB_STATE
String
Cabin State (OO=Out of Order, OS=Out of Service, BL=Blocked, AV=Available).
CAB_CLEAN_STATE
String
Cabin Housekeeping status.
CAB_BEG_BLOCK_D
Date
Date of cabin blocked from.
CAB_REPAIR_D
Date
Date of cabin blocked until.
CAB_REPAIR_T
String
Unavailability Reason.
Table 4-138 ADO.NET Data Table 3 (“RESERV”) – linked to Data Table2 by cabin, lists all reservations grouped by booking number
RES_BOOKNR
String
TOTALGUEST
Integer
Number of Guests.
RES_CAB
String
Cabin.
RES_STATUS
String
Reservation status.
EMBARKDATE
Date
Embarkation Date (Arrival date & time) for expected guests.
DEBARKDATE
Date
Debarkation Date (Arrival date & time) for already onboard guests.
EMBARKPORT
String
Embarkation Port for expected guests.
DEBARKPORT
String
Debarkation Port for already onboard guests.
Table 4-139 ADO.NET Data Table 4 (“CRASH_CABINS”) – Master Table 4 lists all crash cabins and their reservations
CAB
String
Cabin.
EMBARK_RES_BOOKNR
String
Reservation Booking Number for the embarking guest.
EMBARK_STATUS
String
Reservation Status of the embarking guest.
EMBARK_PORT
String
Embarkation Port of the embarking guest.
DEBARK_RES_BOOKNR
String
Reservation Booking Number for the debarking guest.
DEBARK_STATUS
String
Reservation Status of the debarking guest.
DEBARK_PORT
String
Debarkation Port of the debarking guest.
Example:
oResponse = goWS.FidelioSPMSWSXML("SearchHKForecast", "Session ID", New Object() {DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified), DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified),Nothing, Nothing, Nothing, Nothing, Nothing, DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified)})
SearchHouseKeeping
This function performs an advanced search for housekeeping cabins and its tasks.
Input Parameters
psFunction= “SearchHousekeeping” — below is the list of poParam.
For example,
Element 1 = A,
Element 2 = B,
Table 4-140 psParam
pbIsCabin
Boolean
True – Cabin, False = Location.
Yes
pdTaskDateFrom
Date
Date From - task that has been created for the cabin/location.
Yes
pdTaskDateTo
Date
Date To - task that has been created for the cabin/location.
Yes
psPort
Array of String
Port ID (SCD.SCD_ID) - for Housekeeping Tasks only.
Yes
psCabin
Array of String
Unique Cabin IDs (CAB.CAB_ID).
Yes
psTaskStatus
Array of String
0 – Pending, 1 – Started, 2 - Completed.
Yes
psCabinHKStatus
Array of String
Yes
psCabinAvlStatus
Array of String
Yes
psHKSection
Array of String
Yes
psCrewID
Array of String
Crew Account IDs (RES.RES_ACC)
Yes
psTaskID
Array of String
Task IDs (CTK.CTK_ID).
Yes
psDeck
Array of String
Yes
psCabinCategory
Array of String
Yes
psCabinType
Array of String
Yes
psCabinVerticalZone
Array of String
Yes
psLinenChange
String
1 – Task requires linen change.
0 – Task does not require linen change.
pnAMESRTstatus
Integer
0 – Not Delivered.
1 – Delivered.
2 – Both Delivered and Not Delivered.
3 – Do not return any Amenities or Special Requests.
Yes
pnAMESRTportID
Integer
Embarkation Port ID (SCD.SCD_ID) - for Amenities and Special Requests only. This is only for expected guests embarking on this port only.
Yes
pdAMESRTembarkdate
Date
Embarkation Date – for Amenities and Special Requests Only. This is only for expected guests embarking on this date only.
Yes
psAMESRTdepts
Array of String
Amenity/Special Requests Delivery Department.
Yes
pdAMESRTdeliverydate
Date
Amenity/Special Requests Delivery Date.
Yes
pdChangeModDate
Date
Last Changed Date from the last refresh from iCrew.
Yes
pbSortByCabinsOnly
Boolean
TRUE – CABINS and TASKS output table to be sorted by cabin number.
FALSE – CABINS and TASKS output table to be sorted by port arrival time and cabin number.
Yes
pbShowAllInCompleteTasks
Boolean
TRUE - show all incomplete tasks regardless of created date.
FALSE - show incomplete tasks within date range based on par pdTaskDateFrom and pdTaskDateTo.
Yes
pbShowAllCompletedTasksToday
Boolean
TRUE - show all completed tasks today.
FALSE - show all completed tasks within date range based on par pdTaskDateFrom and pdTaskDateTo.
Yes
pbUseOldSorting
Boolean
TRUE - use the current method of sorting in .846 (ignores par pbShowAllInCompleteTasks and pbShowAllCompletedTasksToday). This is for backward compatibility.
FALSE - use the new method of sorting (uses par pbShowAllInCompleteTasks and pbShowAllCompletedTasksToday, ignores psTaskStatus).
Yes
Return Values
CResponseXml.bSuccess = False when SearchHousekeeping has failed.
CResponseXml.bSuccess = True when SearchHousekeeping is successful, CResponse.oDataset will have 11 Data Tables for cabins/locations.
Table 4-141 ADO.NET Data Table field structure for data table (“SERVERDATETIME”), current server date/time.
CURRENTDATETIME
Date
Server Date Time.
Table 4-142 ADO.NET Data Table field structure for data table (“STATS”), Overall Housekeeping Task Statistics and pending amenities/special requests for Cabins based on parameters passed in.
HK_PENDING_COUNT
Integer
Number of pending housekeeping tasks.
HK_STARTED_COUNT
Integer
Number of housekeeping tasks that have started.
HK_COMPLETED_COUNT
Integer
Number of completed housekeeping tasks.
AME_PENDING_COUNT
Integer
Number of amenities count based on pnAMESRTstatus passed in.
SRT_PENDING_COUNT
Integer
Number of special requests count based on pnAMESRTstatus passed in.
Table 4-143 ADO.NET Data Table field structure for data table (“CABINS”) - Cabin Details. It returns a list of cabins with or without housekeeping tasks AND pending amenities/special requests, sorted by SCD_ARRIVE_TIME, CAB
CAB
String
Unique Cabin ID/Location ID.
SCD_ARRIVE_TIME
Date
Port Arrival Time (linked to HAS_PORT_ID).
CAB_NAME
String
Cabin/Location Name.
CAB_DESIGN
String
‘P’ for Pax, ‘C’ for Crew. Does not apply to location.
CAB_STATE
String
Cabin Availability Status (OO=Out of Order, OS=Out of Service, BL=Blocked, AV=Available). Does not apply to location.
CAB_BEDS
Number
CAB_BEDS_SETUP
String
CAB_TEL
String
CAB_TEL2
String
CAB_BEG_BLOCK_D
Date
CAB_REPAIR_D
Date
CAB_REPAIR_T
String
CAB_LIFEBOAT
String
CAB_LIFEBOAT_NAME
String
CAB_STATION
String
CAB_STATION_NAME
String
CAB_LOCATION
Integer
Null-Undefine, 1-Forward, 2-Mid Ship, 3-Aft
CAB_STARBOARD
Integer
0-Portside, 1-Starboard.
CAB_CAT
String
Cabin Type. Linked to TYP_CAT.TYP_ART. Does not apply to location.
CAB_CAT_NAME
String
Cabin Type Description. Linked to TYP_CAT.TYP_COMMENT. Does not apply to location.
CAB_DECK
String
Cabin Deck. Linked to TYP_DEK.TYP_ART. Does not apply to location.
CAB_DECK_NAME
String
Cabin Deck Description. Linked to TYP_DEK.TYP_COMMENT. Does not apply to location.
CAB_HKSTATUS
String
Cabin Housekeeping status (OD, VD, OC, VC). Linked to TYP_CCS.TYP_ART. Does not apply to location.
CAB_HKSTATUS_NAME
String
Cabin Housekeeping status description. Linked to TYP_CCS.TYP_COMMENT. Does not apply to location.
CAB_VZONE
String
Cabin vertical zone. Linked to TYP_VTZ.TYP_ART. Does not apply to location.
CAB_VZONE_NAME
String
Cabin vertical zone description. Linked to TYP_VTZ.TYP_COMMENT. Does not apply to location.
HKSECTION_ID
Integer
Housekeeping Section ID (HSC_ID).
HKSECTION_NAME
String
Housekeeping Section Name (HSC_NAME).
Table 4-144 ADO.NET Data Table field structure for data table (“CRASH_CABINS”) - Crash Cabins
CAB
String
Cabin.
PORTNAME
String
Port Name.
PORTID
Integer
Port ID (SCD_ID).
PORTDATE
Date
Port Date (SCD_DATE).
Table 4-145 ADO.NET Data Table field structure for data table (“TASKS”) sort by SCD_ARRIVAL_TIME field - Cabin Task Assignments.
CTK_ID
Integer
Task ID (CTK.CTK_ID).
CTK_NAME
String
Task Name (CTK.CTK_NAME).
CTK_DESCRIPTIONS
String
Task Description .
CTK_DURATION
Integer
Duration of Task.
CTK_LINENRULE
Integer
1 – requires linen change, 0 – does not require linen change.
HAS_ID
Integer
Unique Housekeeping Task ID.
CAB
String
Unique Cabin/Location ID.
HAS_STATUS
Integer
HAS_ASSIGNDATE
Date
Task Created date.
HAS_COMMENT
String
Task Comments.
HAS_PORT_ID
Integer
SCD_PORT_ID
Integer
Port Name.
HAS_MODDATE
Date
Last modified date for the task.
HAS_COMPLETEDDATE
Date
Task Completed Date.
CRW_ID
Integer
Unique Crew ID.
CRW_NAME
String
Crew that has been assigned the task to.
SCD_ARRIVE_TIME
Date
Port Arrival Time.
Table 4-146 ADO.NET Data Table field structure for table “STATS_CABINS”, Housekeeping Task Statistics per Cabin based on parameters passed in.
CAB
String
Unique Cabin ID/Location.
HK_PENDING_COUNT
Integer
Number of pending tasks per cabin/location.
HK_STARTED_COUNT
Integer
Number of tasks that have started per cabin/location.
HK_COMPLETED_COUNT
Integer
Number of completed tasks per cabin/location.
Table 4-147 ADO.NET Data Table field structure for table “STATS_AME”, Pending Amenities per Cabin.
CAB
String
AME_PENDING_COUNT
Integer
Number of pending amenities per cabin/location.
Table 4-148 ADO.NET Data Table field structure for table “STATS_SRT”, Pending Special Requests per Cabin.
CAB
String
SRT_PENDING_COUNT
Integer
Number of pending special requests per cabin/location.
Table 4-149 ADO.NET Data Table field structure for table “EMB_PORTS”, Reservation Embark/Disembark Ports per Cabin
CAB
String
EMBARKPORT
String
Embarkation port for the checked-in guest for this cabin.
DEBARKPORT
String
Disembarkation port for the checked-in guest for this cabin.
Table 4-150 ADO.NET Data Table field structure for table “RUSH_CABINS”, Rush Cabins
CAB
String
EMBARKPORT
String
Embarkation port for the reservation that is embarking on pdTaskDate.
DEBARKPORT
String
Disembarkation port for the reservation that is disembarking on pdTaskDate.
EMBARKSTATUS
String
Embarkation status for the reservation that is embarking on pdTaskDate.
EMBARK_ARRIVEDATE
Date
Date and Time of the reservation that is embarking on pdTaskDate.
Table 4-151 ADO.NET Data Table field structure for table “COUT_CABINS”, Cabins with check-out tasks
CAB
String
HAS_PORT_ID
Integer
Port ID where the cabin has check-out tasks.
PORTNAME
String
Port name where the cabin has check-out tasks.
SCD_DATE
Date
Port Arrival Date.
Example:
oResponse = goWS.FidelioSPMSWSXML("SearchHouseKeeping", "Session ID", New Object() {True, DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified), Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, 1, 0, 12345, DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified), Nothing, DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified), DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified)})
SearchPassenger
This function searches for a guest using various criteria available in the SPMS system.
Input Parameters
psFunction= “SearchPassenger” — below is the list of psParam or poParam.
Table 4-152 psParam
psFirstName
String
First Name.
Optional
psLastName
String
Embarkation Date.
Optional
psPassportNum
String
Guest Type Enumerator.
Optional
pdBirthDate
Date
Guest Birth date.
Yes
psFirstName
Guest First Name, this field is optional, can pass in an empty string.
psLastName
Guest Last Name, this field is optional, can pass in an empty string.
psPassportNum
Guest Passport Number, this field is optional, can pass in an empty string.
Note: For psFirstName, psLastName and psPassportNum, must supply at least one information.
pdBirthdate
Guest Birth date
Return Values
CResponseXml.bSuccess = True and CResponseXML.CPassenger when input values are valid.
Table 4-153 CPassenger field structure
gnID
Integer
Unique Guest ID, this ID is used to perform in other search.
gsFirstName
String
First Name.
gsLastName
String
Last Name.
gsMiddleName
String
Middle Name.
gsTitle
String
Title.
gsSalutation
String
Salutation.
gdEmbDate
Date
Embarkation Date.
gdDisDate
Date
Disembarkation Date.
gsCabin
String
Cabin Number.
gsCabCategory
String
Cabin Category.
gsFreqCruiseNumber
String
Frequent Cruise Number.
gsFreqCruiseStatus
String
Frequent Cruise Status.
gsDeck
String
Cabin Deck.
gsMusterStation
String
Muster Station Name.
gsAward
String
Award Level.
gsLoyaltyCode
String
Loyalty Discount Code.
gsLoyaltyDesc
String
Loyalty Discount Description.
gsAccTag
String
Account TAG,P – Pax, C - Crew.
gsLanguage1
String
Language 1.
gsLanguage2
String
Language 2.
gsLanguage3
String
Language 3.
gnGrdID
Integer
Group ID
gsGrdName
String
Group Name
gsBookingNo
String
Reservation Booking No.
gsDiscount
String
Current not in use.
Example:
oResponse = goWS.FidelioSPMSWSXML("SearchPassenger", "SESSIONID", New Object() {<FIRST NAME>, <Last Name>, <Passport Number>, #1/1/1970#})
SearchPassengerByID
This function searches for a guest with a unique Guest ID from the SPMS system.
Input Parameters
psFunction= “SearchPassengerByID” — below is the list of psParam or poParam.
Table 4-154 psParam
pnAccID
Integer
SPMS Unique Guest ID.
Yes
pnAccID
Unique Guest ID.
Return Values
Table 4-155 CPassenger field structure
gnID
Integer
gsFirstName
String
First Name.
gsLastName
String
Last Name.
gsMiddleName
String
Middle Name.
gsTitle
String
Title.
gsSalutation
String
Salutation.
gdEmbDate
Date
Embarkation Date.
gdDisDate
Date
gsCabin
String
Cabin Number.
gsCabCategory
String
Cabin Category.
gsFreqCruiseNumber
String
gsFreqCruiseStatus
String
gsDeck
String
Cabin Deck.
gsMusterStation
String
gsAward
String
Award Level.
gsLoyaltyCode
String
gsLoyaltyDesc
String
gsAccTag
String
gsLanguage1
String
Language 1.
gsLanguage2
String
Language 2.
gsLanguage3
String
Language 3.
gnGrdID
Integer
Group ID.
gsGrdName
String
Group Name.
gsBookingNo
String
gsDiscount
String
Current not in use.
SearchPayrolls
This function returns payroll data based on various search criteria from the SPMS system.
Input Parameters
psFunction=“SearchPayrolls” — below is the ordered list of input parameters and its descriptions.
Table 4-156 psParam
MemoryLifeSpan
Integer
Optional in seconds, default as zero. If set to non-zero, result set will be kept in memory for reuse when a subsequent call is issued within the specified time interval with MemoryReuse = TRUE.
Optional
MemoryReuse
Boolean
Optional
RecordPerPage
Integer
Optional, default as zero. Specify the number of CTR records for which their payroll data will be returned. If zero, will return all CTR records in the result set.
Optional
PageNum
Integer
Optional
CTR_IDs
String
Optional. Comma delimited CTR_ID.
Optional
SPP_STATUSs
String
Optional. Comma delimited SPP_STATUS. *
Optional
SSH_STATUSs
String
Optional. Comma delimited SSH_STATUS. *
Optional
Return Values
CResponseXML.oDataSet = ADO.NET dataset, which will contain table SSH, PAY, SPP, SED, BEN and USR. *
Remark:
Example:
oResponse = goWS.FidelioSPMSWSXML("SearchPayrolls", "SessionID", New Object() {60, True, 10, 1, 46598,46599,46600, “O,A,C,F”, “A,P”})
SearchSpecialRequest
This function is an advanced search for special request.
Input Parameters
psFunction= “SearchSpecialRequest”— below is the list of poParam.
For example,
Element 1 = A,
Element 2 = B,
Table 4-157 psParam
peReservationType
Integer
Reserve and CheckIn.
1 – Reserve
2 - CheckIn
3 - CheckOut
Date
Special Request Delivery Date (SRT_DDATE) If nothing is passed in, then it will skip this criteria.
pdExpDeliveryDateTo
Date
Special Request Delivery Date (SRT_DDATE)If nothing is passed in, then it will skip this criteria.
pdDeliveredDateFrom
Date
Special Request Delivery Date (SRT_DONE_DATE)If nothing is passed in, then it will skip this criteria.
pdDeliveredDateTo
Date
psGuestLastName
String
psCode
Array of String
Special Request Code (TYP_SRT.TYP_ART)If nothing is passed in, then it will skip this criteria.
psExtCode
Array of String
Special Request Identifier Code.
psGroupID
Array of String
psCabinCategory
Array of String
psDeliveryLocation
Array of String
Delivery Location (SRT_LOCATION)If nothing is passed in, then it will skip this criteria.
psDeck
Array of String
psDeliveryBy
Array of String
Special Request Delivery By. Linked to USR.USR_ID.If nothing is passed in, then it will skip this criteria.
psCabin
Array of String
psDepartment
Array of String
Amenity Delivery Division (SRT_ODI_ID)If nothing is passed in, then it will skip this criteria.
psHKSection
Array of String
Return Values
CResponseXml.bSuccess = False when SearchSpecialRequest has failed.
CResponseXml.bSuccess = True when SearchSpecialRequest is successful, CResponse.oDataset will have 1 Data Table.
Table 4-158 ADO.NET Data Table field structure for data table
SRT_ID
Integer
Special Request ID (Unique ID).
SRTCODE
String
Special Request Code. Linked to TYP_SRT.TYP_ART.
SRTNAME
String
Port Name. Linked to TYP_SRT.TYP_COMMENT.
SRT_EXT_CODE
String
ACCID
String
Account ID.
Name
String
Guest Name.
RESSTATUS
String
Reservation Status.
VIPCODE
String
VIPNAME
String
PORTID
String
PORTNAME
Integer
GROUPID
String
GROUPNAME
String
Travel Group Name.
CABINID
String
Unique Cabin ID.
HSC_NAME
String
Housekeeping Section Code.
HSC_COMMENT
String
SRT_LOCATION
String
Delivery Location.
SRT_ODI_ID
String
TYP_COMMENT
String
CAB_VZONE
String
CAB_VZONE_NAME
String
CAB_TYPE
String
TYP_COMMENT1
string
CAB_DECK
String
TYP_COMMENT2
String
SRT_DDATE
Date
Special Request Delivery Date.
SRT_DONE_DATE
Date
Special Request Service Done Date.
SRT_DONE_BY
Integer
Special Request done by the waiter. Linked to USR.USR_ID.
USR_LOGIN
String
User Login Name.
CAB_KEEPER
Integer
CAB_KEEPER_NAME
String
Housekeeper Name.
CAB_A_KEEPER
Integer
CAB_A_KEEPER_NAME
String
CAB_G_WAITER
Integer
CAB_G_WAITER_NAME
String
Waiter Name
CAB_A_WAITER
Integer
CAB_A_WAITER_NAME
String
SRT_CREATED_BY
Number
The user that created this special request.
SRT_DATE_CREATED
Date
Special request actual creation date.
SRT_DESCR
String
Special Request Description.
SRT_EVENTDATE
Date
Event Date & Time.
SRT_EXT_ID
Number
Interface System Special Request ID.
SRT_MODDATE
Date
Last Modification Date.
SRT_QUANTITY
Number
Special Request Quantity.
SRT_RESID
Integer
Guest Account ID. Linked to RES.RES_ID.
SRT_VID
String
Unique ID (for import duplicate functionality).
Example:
oResponse = goWS.FidelioSPMSWSXML("SearchSpecialRequest", New Object() {<ReservationType>,<ExpDeliveryDateFrom>,<ExpDeliveryDateTo>,<DeliveryDateFrom>,<DeliveryDateTo>,<LastName>,<SRTCode>,<ExternalCode>,<GroupID>,<CabinCategory>,<DeliveryLocation>,<Deck>,<DeliveryBy>,<Department>,<HKSection>})
SearchWorkOrder
This function gets the maintenance work order from SPMS.
Input Parameters
psFunction= “SearchWorkOrder” — below is the list of psParam or poParam.
Please take note all the parameter are optional except pdFromDate and pdToDate, the more parameters you pass in, the fewer records it will return.
For example,
Element 1 = A,”
Element 2 = B,
Table 4-159 psParam
pdFromDate
Date
From date & time.
Yes
pdToDate
Date
To date & time.
Yes
pdCompleteFromDate
Date
Completion date & time from.
Yes
pdCompleteToDate
Date
Completion date & time to.
Yes
psWorkOrderTyp
Array of String
Work Order Type.
Yes
psCabin
Array of String
Cabin Location.
Yes
psPublicLocation
Array of String
Public Location.
Yes
psLocation
Array of String
Custom Location.
Yes
psTask
Array of String
Work Order Task.
Yes
psWorkGroup
Array of String
Work Order Assign Worker Group.
Yes
pnUsrCreate
Array of String
User ID which created the Work Order.
Although the data type is numeric, you must pass in as Array of String due to .NET limitation.
Yes
pnUsrAssign
Array of String
Work Order Assign to the Crew.
Yes
psPriority
Array of String
Priority.
Yes
pnMwrID
Array of String
Work Order Unique ID.
Yes
psMwrNo
Array of String
Work Order Number.
Yes
pnCompleteStatus
Array of String
Completion Status, Range 0,25,50,75,100.
Yes
pbIncludePicture
Boolean
True = Will return the work order picture.
False = Will return nothing, this is for slow device, so it will need to look up the picture using WSF using the value WSF_XDOC_ID, default = True.
Optional
pbSortModDateAsc
Boolean
True it will sort the records by last modify date ASC.
False it will sort the records by last modify date DESC.
Default = True.
Optional
Return Values
CResponseXml.bSuccess = False when SearchWorkOrder has failed.
CResponseXml.bSuccess = True when SearchWorkOrder is successful, CResponse.oDataset will have 4 Data Tables.
Table 4-160 ADO.NET Data Table field structure for first data table, Work Order
Code Type Description
MWR_CSTATUS
Integer
Completion Status Percentage 0,25,50,75 or 100.
MWR_DATE
Date
Date Time the order created.
MWR_LOCATION
String
Custom Location of the maintenance.
MWR_LOCATIONCABIN
String
Cabin Number.
MWR_LOCATIONPUBLIC
String
Public Location.
PRIORITY
String
Priority Description.
MWR_TASK
String
Task Code.
TSK_COMMENT
String
Task Name.
MWR_TASKDESCR
String
Task Description.
USR_LOGIN
String
User Login Name.
MWR_TYPE
String
Work Order Type.
WOT_NAME
String
Word Order Type Description.
MWR_ID
Integer
Unique Work Order ID.
MWR_WONUMBER
String
Work Order Number.
ARE_CATEGORY
String
Custom Location Category.
CAT_NAME
String
Custom Location Category Name.
STATUS
String
Useable Status.
XDOC_FILE
Byte Array
Picture of the work order.
MWR_TIME_NEEDED
Double
Time Needed in Days.
MWR_PICTUREFILE
String
File Name of the picture.
MWR_COMMENT
String
Comment.
MWR_CAB_ID
String
Report By Cabin Number.
ARE_NAME
String
Custom Location Name.
PUBLIC_NAME
String
Public Location Name.
MWR_COMPLETEDATE
Date
Completion Date.
MWR_PRINTED
Integer
Indicated how many time it printed.
MWR_REJECTED
Boolean
True – Rejected.
MWR_XDOC_ID
Long
The work order picture ID = xdoc_id.
Table 4-161 ADO.NET Data Table field structure for second data table, Work Order Assignment
MWA_ID
Integer
Unique Work Order Assignment ID.
MWA_MWRID
Integer
Work Order ID.
MWA_ASSIGNEDTOGROUP
String
Assign Group Code.
MWA_ASSIGNEDTOWORKER
Integer
Unique Crew ID.
MWA_ASSIGNEDWHEN
Date
Date and Time of assignment.
MWA_REMARKS
String
Remarks.
CRW_NAME
String
Crew Name.
MWR_GROUP
String
Group Description.
USR_LOGIN
String
User Login Name.
Table 4-162 ADO.NET Data Table field structure for the third data table, Work Order Assignment
MWI_ID
Integer
Unique Work Order Item ID.
MWI_MWRID
Integer
Work Order ID.
MWI_ITEMCODE
String
Item Code.
MWI_QUANTITY
Integer
Quantity Needed.
MWI_PRICE
Double
Price of the item.
MWI_REMARKS
String
Remarks.
MIT_DESC
String
Item Description.
MIT_GROUP
String
Item Group.
MIT_STOCK
Integer
Quantity On Hand.
TYP_COMMENT
String
Item Group Description.
Table 4-163 ADO.NET Data Table field structure for fourth data table, Work Order Additional Image
MWP_ID
Integer
Unique Work Order Image ID.
MWP_MWRID
Integer
Work Order ID.
MWP_COMMENT
String
User Comment.
MWP_FILENAME
String
Original Picture Filename, Information purpose.
MWP_IMAGE
Byte Array
Additional Picture of the work order.
Example:
oResponse = goWS.FidelioSPMSWSXML("SearchWorkOrder", "", New Object()
{DateTime.SpecifyKind(#1/1/2000#, DateTimeKind.Unspecified), _ DateTime.SpecifyKind(#1/1/2012#, DateTimeKind.Unspecified), _ DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified), _ DateTime.SpecifyKind(DEFAULT_DATE, DateTimeKind.Unspecified), _ Nothing, New String() {"05002", "00000"}, Nothing, Nothing, _ Nothing, New String() {"1"}, Nothing, Nothing, Nothing, _ Nothing, Nothing, Nothing, False, False})
SpaBooking
This function creates a single or Packaged Treatment Spa booking in SPMS.
Note: Not supported when it is connected to an offline QCI Sync database.
Input Parameters
psFunction= “SpaBooking” — below is the list of psParam or poParam.
Table 4-164 psParam
Parameter Type Description Required
pnAccID
Integer
Unique Guest ID.
Yes
pnLocation
Integer
Location ID.
Yes
pnItem
Integer
Treatment Item ID.
Yes
pdDate
Date
Treatment Date and Time.
Yes
psNotes
String(255)
Notes (Default Empty).
Optional
psPin
String(4)
Pin Code (Default Empty).
Optional
psSource
String(10)
Booking Source (Default Empty).
Optional
pbForceBooking
Boolean
True = Allow posting even the guest who does not have credit limit or posting is disabled, False = Normal posting.
Yes
pbIsUnassignedBooking
Boolean
True = Allow booking without Treatment Date and Time in order to be manually confirmed onboard, False = Regular Booking with Treatment Date and Time.
Yes
pnPackageID
Integer
Package ID.
Optional
pnPackageControlNo
Integer
Unique ID Grouping Package Treatments and Retail Items.
Optional
pnAccID
Unique Guest ID, return from SearchPassenger.
pnLocation
The field identifies the unique location ID. The field is an internal, unique code. This value is retrieved from the SPALocation message type. For Package Treatments, the value is 0, because originally, packages can contain treatments from multiple/different locations. In this case, the function will automatically find the appropriate location schedule for the requested date and time.
pnItem
The field identifies the unique treatment item identification. The field is an internal, unique code. This field is retrieved from SPATreatmentItem.
pdDate
The field identifies the date and time in which the treatment takes place. This field is retrieved from SPATreatmentAvailability. If pbIsUnassignedBooking is True, then pdDate must be empty.
psNotes
The field identifies the additional information send by third-party.
psPin
The field identifies the telephone PIN code of the reservation account. The valid characters are 0,1,2,3,4,5,6,7,8,9. Leading zero support depends on SPMS Parameter setting.
psSource
The field identifies the source of the booking. For example, Workstation ID, Kiosk ID, and so on or any other details describing the location where the booking was made.
pbForceBooking
True = Allow posting even if the guest does not have a credit limit or posting is disabled. This is applicable to check-in guest only.
True = Allow booking without Treatment Date and Time in order to be manually confirmed onboard.
pnPackageID
The field identifies the unique Package ID. The field is an internal, unique code. This value is retrieved from GetSPAPackages WebMethod.
pnPackageControlNo
The field identifies the grouping of Treatments and Retail Items that belong to the same package and are sold together in one transaction. When booking the first Package Treatment, this field must always be “0” in order to return the new Package ControlNo value upon booking of the first package treatment with return value CResponse.oObj(1). For the rest of treatment bookings, this value must contain the same Package ControlNo as returned after the 1st Package Treatment Booking.
Return Values
CResponseXml.bSuccess = True when Booking is successful.
CResponse.oObj(0) return the booking ID (spa_id).
CResponse.oObj(1) return the Package ControlNo (spa_control).
CResponseXml.bSuccess = False when Booking has failed.
Example:
For Regular single Treatments
oResponse = goWS.FidelioSPMSWSXML("SpaBooking", "SESSIONID", New Object() {12345, 37464, 1, 123, #1/1/2011 3:00 pm#, "", "", "", False, False})
For Unassigned single Treatment without Treatment Date & Time assignment
oResponse = goWS.FidelioSPMSWSXML("SpaBooking", "SESSIONID", New Object() {12345, 37464, 1, 123, "", "", "", "", False, True})
For 1st Regular Package Treatment
oResponse = goWS.FidelioSPMSWSXML("SpaBooking", "SESSIONID", New Object() {12345, 37464, 0, 123, #1/1/2011 3:00 pm#, "", "", "", False,False,4,0})
CResponse.oObj(0) return the booking id (spa_id) = 1342
CResponse.oObj(1) return the Package ControlNo (spa_control) = 1341
For rest of Regular Package Treatments
oResponse = goWS.FidelioSPMSWSXML("SpaBooking", "SESSIONID", New Object() {12345, 37464, 0, 133, #1/1/2011 3:00 pm#, "", "", "", False,False,4,1341})
For 1st Unassigned Package Treatment
oResponse = goWS.FidelioSPMSWSXML("SpaBooking", "SESSIONID", New Object() {12345, 37464, 0, 123, "", "", "", "", False,True,4,0})
For rest of Unassigned Package Treatments
oResponse = goWS.FidelioSPMSWSXML("SpaBooking", "SESSIONID", New Object() {12345, 37464, 0, 133, "", "", "", "", False,True,4,1341})
SpaBookingPackageRetail
This function creates a spa package retail booking in SPMS after all Package Treatments Bookings have been completed.
Input Parameters
psFunction= “SpaBookingPackageRetail” — below is the list of psParam or poParam.
Table 4-165 psParam
pnAccID
Integer
Unique Guest ID.
Yes
pnRetailItem
Integer
Retail Item ID.
Yes
pnPackageID
Integer
Package ID.
Yes
pnPackageControlNo
Integer
Yes
psNotes
String(255)
Optional
psPin
String(4)
Optional
psSource
String(10)
Optional
pbForceBooking
Boolean
Yes
pnAccID
pnRetailItem
The field identifies the unique retail item identification. The field is an internal, unique code. This field is retrieve from GetSPAPackageItems or GetSPAPackageItems ForPeriod.
pnPackageID
pnPackageControlNo
The field identifies the grouping of Treatments and Retail Items that belong to the same package and are sold together in one transaction. Since all included Package Retail Items can only be booked after all Package Treatments have been booked, the Package Control No is already known because it has already been returned after the 1st Package Treatment Booking.
psNotes
The field identifies the additional information sent by third-party.
psPin
psSource
The field identifies the source of the booking. For example, Workstation ID, Kiosk ID and so on or any other details describing the location where the booking was made.
pbForceBooking
True = Allow posting even the guest who does not have credit limit or posting is disabled (This only apply to check-in guest only), False = Normal posting.
Return Values
Example:
For 1st Package Treatment
oResponse = goWS.FidelioSPMSWSXML("SPABookingPackageRetail", "SESSIONID", New Object() {12345, 123, 4, 1341, "", "", "", False})
SpecialRequestCompleted
This function updates the special request status as “Completed.”
Input Parameters
psFunction= “SpecialRequestCompleted” — below is the list of psParam or poParam.
Table 4-166 psParam
pnSrtID
Integer
Special Request Unique ID.
Yes
Return Values
CResponseXml.bSuccess = False when Update failed.
CResponseXml.bSuccess = True when Update successful.
Example:
oResponse = goWS.FidelioSPMSWSXML("SpecialRequestCompleted", "SessionID", New Object() {12334})
UndoAmenityCompleted
This function updates the amenity status as “Not complete”.
Input Parameters
psFunction= “UndoAmenityCompleted” — below is the list of psParam or poParam.
Table 4-167 psParam
pnAmeID
Integer
Amenity Unique ID.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UndoAmenityCompleted", "SessionID", New Object() {12334})
UndoSpecialRequestCompleted
This function updates the special status as “Not complete”.
Input Parameters
psFunction= “UndoSpecialRequestCompleted” — below is the list of psParam or poParam.
Table 4-168 psParam
pnSrtID
Integer
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UndoSpecialRequestCompleted", "SessionID", New Object() {12334})
UpdateAmenity
This function adds or updates the guest amenity.
Input Parameters
psFunction= “UpdateAmenity” — below is the list of psParam or poParam.
Table 4-169 psParam
pnAmeID
Integer
Unique Amenity ID (0 for add new record).
Yes
pnAccID
Integer
Unique Account ID.
Yes
psCode
String(6)
Amenity Code.
Yes
psNote
String(2500)
Yes
pnAmount
Double
Amenity Price each.
Yes
pnQuantity
Integer
Amenity Quantity.
Yes
psSender1
String(255)
Sender 1.
Yes
psSender2
String(30)
Sender 2.
Yes
psMessage
String(255)
Message for sender.
Yes
pdDeliveryDate
Date
Expected Delivery Date and Time.
Yes
psLocation
String(30)
Location.
Yes
psOccurrence
String(10)
Occurrence.
Yes
psExtCode
String(15)
External Code.
Yes
pnCost
Double
Cost.
Yes
psComments
String(2500)
Comments.
Yes
psExtID
String(20)
External ID.
Yes
psVID
String(100)
Unique External ID.
Yes
psOdiID
String(6)
Delivery Division.
Yes
psCurID
String(6)
Currency Code.
Yes
psFlag
String(1)
Flag
Yes
Return Values
CResponseXml.bSuccess = False when Update/Add failed.
CResponseXml.bSuccess = True when Update/Add successful, CResponseXML.oObj = ame_id (Unique Amenity ID).
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateAmenity", "SessionID", New Object() {12345,1234576,"Code","Note",1.23,1, "Sender1", "Sender2", "Message", DateTime.SpecifyKind(#01-01-2013 3:00:00 pm#, DateTimeKind.Unspecified), "Location", "Once", "ExtCode", 0.45, "Comments", "ExtID", "", "GRP", "US", "")
UpdateCabCleanStatus
This function updates the cabin clean status.
Input Parameters
psFunction= “UpdateCabCleanStatus — below is the list of psParam or poParam.
Table 4-170 psParam
psCabID
String(20)
Cabin Number.
Yes
psCabCleanStatus
String(2)
Available value is OD,OC,VD,VC,PU,FA,VF.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateCabCleanStatus", "SessionID", New Object() {"05002", "OD"})
UpdateCabState
This function updates the cabin status, reason for cabin blocking and blocking period.
Input Parameters
psFunction= “UpdateCabState” — below is the list of psParam or poParam.
Table 4-171 psParam
psCabId
String
Unique Cabin ID.
Yes
psCabStat
String
Cabin Status (OO, OV, BL, AV).
Yes
psComment
String
Cabin Blocking Reason.
pdBlockFromDate
Date
Cabin Block From Date.
pdBlockToDate
Date
Cabin Block To Date.
Return Values
CResponseXml.bSuccess always return True, always show the CResponse.sErrMsg.
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateCabState", "SessionID", New Object() {12345,’OO’,<Comment>,<BlockFromDate>,<BlockToDate>})
UpdateComment
This function adds or updates the guest comment.
Input Parameters
psFunction= “UpdateComment” — below is the list of psParam or poParam.
Table 4-172 psParam
peQuickAssignment
Integer
0-None,1-Same Cabin,2-Same Booking No,3-Same Group, this apply to new comment only, when adding a new comment. If the value is > 0, it will add the same comment to those related guest.
Yes
pnCplID
Integer
Unique Comment ID (0 for add new).
Yes
pnCplLinkID
Integer
This is the comment link ID, use to update the comment create with Quick Assignment only apply to parent comment.
Yes
pnAccID
Integer
Unique Account ID.
Yes
psComment
String(1500)
Comment Description.
Yes
psCommentCategory
String(6)
Yes
pnCost
Decimal
Comment/Resolution Cost.
Yes
psDepartmentInvolve
Array of String(6)
List of Department Involve Code (TYP_CDI.TYP_ART).
Yes
psDescCode
String(6)
Yes
psDesc
String(1500)
Yes
psExternalCode
String(20)
External ID.
Yes
psFileName
String(300)
This the original filename of the uploaded document. For picture, it uses the file extension to determine if the document is a doc or a picture, file extension .DOC, .DOCX and .PDF will be considered a document and the rest as a picture file.
Yes
pbInternal
Boolean
Internal Flag.
Yes
psInvolvePerson
String(50)
Person who resolved the issue or Person who reported the complaint.
Yes
pbComment
Boolean
True = Comment, False = Resolution.
Yes
pbSensitive
Boolean
Sensitive Flag.
Yes
pbUrgent
Boolean
Urgent Flag.
Yes
pbyPicture
Array of Byte
This can be a document or a picture, max size 4,000,000.
Yes
psReportType
String(6)
Report Type (TYP_CPI.TYP_ART).
Yes
pdRequestDate
Date
Requested resolution date.
Yes
pbResolved
Boolean
This only applies to resolution.
Yes
pdResolvedDate
Date
Resolved Date
Yes
pnVendorID
Integer
Vendor ID, we either send the Account ID or Vendor ID.
Yes
psVid
String(100)
Yes
pnXDocID
Long
Unique XDOC ID, the table where the picture is stored.
If the value pass in = 0 and picture pbyPicture is passed in, it will create a new record and delete the old record.
If the value pass in > 0 and picture pbyPicture is pass in, it will overwrite the existing record.
If the value pass in = 0 and pbyPicture is nothing then it will delete the existing record.
If the value pass in > 0 and pbyPicture is nothing then it will keep the existing record.
Yes
Return Values
CResponseXml.bSuccess = True when Update/Add successful.
CResponseXML.oObj(0) = cpl_id, comment unique ID.
CResponseXML.oObj(1) = cpl_link_id, comment link ID.
Example:
Add new comment
oResponse = FidelioWS("UpdateComment", New Object() {0, 0, 0,12345, "Comment", _
"CAT1", 0.00, New String() {"HSE"}, "MISB", "Missing Bag", "", "Bag.jpg", False, "Person Name", True, False, Yes, File.ReadAllBytes("Bag.Jpg"), "FD", DateTime.SpecifyKind(Now(), DateTimeKind.Unspecified), False, DateTime.SpecifyKind(Now(), DateTimeKind.Unspecified), 0, "", 0})
Update existing comment
oResponse = FidelioWS("UpdateComment", New Object() {0, 456, 457, 12345, "Comment", "CAT1", 0.00, New String() {"HSE"}, "MISB", "Missing Bag", "", "Bag.jpg", False, "Person Name", True, False, Yes, File.ReadAllBytes("Bag.Jpg"), "FD", DateTime.SpecifyKind(Now(), DateTimeKind.Unspecified), False, DateTime.SpecifyKind(Now(), DateTimeKind.Unspecified), 0, "", 0})
UpdateCompleteStatus
This function updates the maintenance work order completion status.
Input Parameters
psFunction= “UpdateCompleteStatus” — below is the list of psParam or poParam.
Table 4-173 psParam
pnMwrID
Integer
Unique Work Order ID (0 for add new record).
Yes
pnStatus
Integer
Completion Status, must be 0, 25, 50, or 100.
Yes
pdCompleteDate
Date
Completion Date, only use when pnStatus = 100.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateCompleteStatus", "SessionID", New Object() {12345, 100, DateTime.SpecifyKind(#01-01-2013 3:00:00 pm#, DateTimeKind.Unspecified))
UpdateCreditCardInfo
This function to updates the guest credit card information.
To deactivate all credit card pass in, set psCardNumber and psCCTrack = Blank String.
Input Parameters
psFunction= "UpdateCreditCardInfo” — below is the list of psParam or poParam.
Table 4-174 psParam
pnAccID
Integer
SPMS Internal Account Number.
Yes
psCardNumber
String
Credit Card Number.
Yes
psCardExpMMYY
String
Card Expiry Date in MMYY format.
Yes
psCardName
String
Card Holder Name.
Yes
psCardCtlNo
String
3 Digits CVV.
Yes
psCCTrack
String
Credit Card Track data.
Yes
pbySignature
Byte Array
Byte Array of the signature image, this only apply when PAR->General->Enable Signature Capture for Credit Card is enable.
Yes
pbyEncTrack1
Byte Array
Papagena Encrypted Track 1.
Optional
pbyEncTrack2
Byte Array
Optional
pbyEncTrack3
Byte Array
Optional
psDeviceSerial
String(32)
Papagena Device Serial Number.
Optional
psKSN
String(32)
Papagena KSN Number.
Optional
psToken
String(120)
Papagena Token.
Optional
pbAssignInvoice1
Boolean
Assign the Credit Card to Invoice 1 (Default = True).
Optional
pbAssignInvoice2
Boolean
Assign the Credit Card to Invoice 2 (Default = True).
Optional
pbAssignInvoice3
Boolean
Assign the Credit Card to Invoice 3 (Default = True).
Optional
pbAssignInvoice4
Boolean
Assign the Credit Card to Invoice 4 (Default = True).
Optional
pnParcelado
Enum
0 – Unknown (Pass in this value, the system will check is the card entitle for Parcelado).
1 – No (Default).
2 - Yes.
Optional
pnDCC
Enum
0 – Unknown (Pass in this value, the system will check is the card entitle for DCC).
1 – No (Default).
2 – Yes.
Optional
pbAllowRegisterSameCard
Boolean
True = Allow to register credit which already register to other guest
False = Allow to register credit which already register to other guest depend on PAR.
Optional
psCardCurrency
String(3)
Three characters of ISO currency code.
Optional
Note: For the first card, it always assigns to all invoice regardless of the pbAssignInvoice?
Value
If pnParcelado = “Unknow” and the card entitle for Parcelado, it will return an error. If the error ends with “?”. This means you can ask for a user confirmation. The error message will be per below, and you can check for the word Parcelado to determine if this is the question for Parcelado, or else the question will be for pnDCC.
If the user answer yes, pass in pnPaceldo = 2, if the user answer no, pass in pnParcelado = 1.
“This card is eligible for Parcelado Handling – would you like to enroll this card?”.
If pnDCC = “Unknow” and the card entitle for DCC, it will return and error ending with “?” This means you can ask for a user confirmation. If the user answer = yes, pass in pnDCC = 2, If the user answer = no, pass in pnDCC = 1.
pnAccID
You can get this value from the poUxpRes field uxp_a_id.
psCardNumber
This is the credit card number. Supply this field only when the credit card was manually entered.
psCardExpMMYY
This is the credit card expiry date (MMYY). Supply this field only when the credit card was manually entered.
psCardName
This is the credit card holder name. Supply this field only when the credit card was manually entered.
psCardCtlNo
This is the CVV number printed on the back of the credit card. This field is optional.
psCCTrack
This is the credit card track data. Supply this field only when the credit card was swiped.
The field must include the track preamble and postamble.
For example:
%B4509190000858834^VISA <NAME>^2019010142780000000000182000000?;4xxxxxxxxxxxxxxx=20190101427818200000?
pbySignature
Byte Array of the signature image, this only applies when PAR. ‘General’,’Enable Signature Capture for Credit Card’ is enabled. You only pass in when the signature capture device is available.
Return Values
CResponseXml.bSuccess = True when update is successful.
CResponseXml.bSuccess = False when update has failed.
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateCreditCardInfo", "SESSIONID", New Object() { 1234, <CardNumber>, <ExpiryDate>, <CardName>, <Card CVV>, <Card All Track>, <Signature Byte Array>})
UpdateCreditLimit
This function updates the guest credit limit. The credit limit also depends on the payment type. If the credit limit is greater than the payment type credit limit, it will take the payment type credit limit.
Input Parameters
psFunction= “UpdateCreditLimit” — below is the list of psParam or poParam.
Table 4-175 psParam
peSearchType
Enum
0 = Internal ID.
1 = PGID.
2 = BoardCard.
3 = Pax ID.
Yes
psSearchStr
String
Unique Payer Account ID or
Board Card or
PGID or
Pax ID depends on the peSearchType.
Yes
psCreditLimit
Decimal
The credit limit, -1 for unlimited.
Yes
pbDailyLimit
Boolean
This applies to the buyer only. This requires the PAR->General->Check Buyer Limit to be enabled.
True – The amount is daily limit.
False – The amount is cruise limit.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateCreditLimit", "SessionID", New Object() {0,12345,5000.00,False})
UpdateCrewPinCode
This function updates the crew pin code.
Input Parameters
psFunction= “UpdateCrewPinCode” — below is the list of psParam or poParam.
Table 4-176 psParam
pnAccID
Integer
Unique Crew Account ID.
Yes
pnNewPinCode
New pin code.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateCrewPinCode", "SessionID", New Object() {12345, 1234})
UpdateDayNeeded
This function updates the maintenance work order day needed to complete the task.
Input Parameters
psFunction= “UpdateDayNeeded” — below is the list of psParam or poParam.
Table 4-177 psParam
pnMwrID
Integer
Yes
pnDays
Double
Number of Days Needed.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateDayNeeded", "SessionID", New Object() {12345, 1.5)
UpdateEmail
This function allows you to update the e-mail address (RES_EMAIL_SHIP) to SPMS.
Input Parameters
psFunction= “UpdateEmail” — below is the list of psParam or poParam.
Table 4-178 psParam
pnAccID
Integer
SPMS Guest Unique ID.
Yes
psOldEMail
String
Old E-Mail address.
Yes
psNewEMail
String
New E-Mail address.
Yes
pnAccID
psOldEmail
This is the existing e-mail address for validation purpose. If there is no previous e-mail address pass in an empty string.
psNewEmail
This is the new e-mail address to update to the DB.
Return Values
CResponseXml.bSuccess = True when UpdateEmail is successful.
CResponseXml.bSuccess = False when UpdateEmail has failed.
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateEmail", "SESSIONID", New Object() {12345, “[EMAIL ADD]”, "[EMAIL ADD]", 0, ""})
UpdateGuestInfo
This function updates the guest information retrieved from GuestSearch function. There could be instances whereby, after the GuestSearch function is called, some updates could have taken place to the same account in the SPMS system on the customer side. In cases like this, an error message ‘xxxxxx’ will be returned by the function. This is to prevent the new information from being overwritten on either end. When this error message occurs, you must make another function call to the GuestSearch function or a refresh of the underlying data table and then only make a call to the UpdateGuestInfo function, to update the account details.
Input Parameters
psFunction= “UpdateGuestInfo” — below is the list of psParam or poParam.
Table 4-179 psParam
poUxpRes
String/Datatable
This is the data table send from GuestSearch. However, only one record is allowed at one time, JSON – string, XML = Datatable.
Optional when pnAccID is required.
pbyPicture
Byte Array
Byte Array of the picture content.
Yes
psPictureSource
Integer
How picture is capture (This is required when the pbyPicture exists)
0 – Unknown source.
1 – From Web Cam.
2 – From RFID passport.
3 – From Scan passport image.
Yes
pnAccID
Integer
SPMS Internal Account Number (For JSON pass in 0 to add new reservation).
Optional when poUxpRes is required.
psReason
String
Reason for change cabin.
Optional
psNatID
String
Nationality ID.
Optional
Below are the descriptions of the parameters:
For XML pass in poUxpRes.Rows(0)!uxp_a_id = 0 to add new reservation.
To update picture only pass in poUxpRes as nothing for XML, empty string for JSON
poUxpRes
This is the data table returned from the GuestSearch function. However, only one record is allowed at any one time. Therefore, if the GuestSearch function returns more than one record, you must copy the record that you want to a new data table. Refer to the sample code below on how this is done. Do note that not all fields will be updated. Below is the list of fields currently allowed for an update.
For FidelioSPMSWSXML function, the poUxpRes need to serialize first before using the function below.
Public Function SerializeObject(ByVal poObject As Object) As String
    Dim oWriter As XmlSerializer
    Dim oMemory As MemoryStream
    oWriter = New XmlSerializer(poObject.GetType)
    oMemory = New MemoryStream
    oWriter.Serialize(oMemory, poObject)
    SerializeObject = System.Text.UnicodeEncoding.Default.GetString(oMemory.ToArray)
    oMemory.Dispose()
    oMemory = Nothing
    oWriter = Nothing
  End Function
Table 4-180 Data Field Codes
Code Description Required
RES_AWARD_LEVEL
If no changes, please skip this field. See SPMS Data Dictionary for further description.
Optional
RES_BOARDCC_EXT
Optional
RES_BOOKNR
Optional
RES_CAB
Optional
RES_CANCEL
Optional
RES_CLASSIFICATION
Optional
RES_CRUISE_DAYS
Optional
RES_DIS_E
Optional
RES_EMAIL_SHIP
Optional
RES_EMB_E
Optional
RES_GRP
Optional
RES_HANDICAPCODE
Optional
RES_HANDIREMARKS
Optional
RES_NOOFCRUISES
Optional
RES_PAXCLASS
Optional
RES_PPD_TAG
Optional
RES_QUEUEID
Optional
RES_RFID
Optional
RES_SIGNOFFPORT_ID
Optional
RES_SIGNONPORT_ID
Optional
RES_TRAVEL_TYPE
Optional
RES_V_GUESTID
Optional
RES_V_PRIMARY
Optional
UXP_A_CITY
Optional
UXP_A_COUNTRY
Optional
UXP_A_FRQ_CARDNO
Optional
UXP_A_FSTN
Optional
UXP_A_HANDICAPED
Optional
UXP_A_LOYALTY
Optional
UXP_A_NAME
Yes
UXP_A_OTHNAME
Optional
UXP_A_SALUT
Optional
UXP_A_STATE
Optional
UXP_A_STREET
Optional
UXP_A_STREET2
Optional
UXP_A_STREET3
Optional
UXP_A_TITEL
Optional
UXP_A_TRAV_INSURE
Optional
UXP_A_ZIP
Optional
UXP_C_INSURE
Optional
UXP_H_BIRTHD
Optional
UXP_H_BIRTHNAT
Optional
UXP_H_BIRTHP
Optional
UXP_H_CONT_CITY
Optional
UXP_H_CONT_ZIP
Optional
UXP_H_CONT_COUNTRY
Optional
UXP_H_CONT_EMAIL
Optional
UXP_H_CONT_MOB_PHONE
Optional
UXP_H_CONT_NAME
Optional
UXP_H_CONT_PHONE
Optional
UXP_H_CONT_STATE
Optional
UXP_H_CONT_STREET
Optional
UXP_H_CONT_STREET2
Optional
UXP_C_RELATIONSHIP
Optional
UXP_H_EMAIL
Optional
UXP_H_EMAIL2
Optional
UXP_H_MNAME
Optional
UXP_H_NATION
Optional
UXP_H_PASSDI
Optional
UXP_H_PASSEX
Optional
UXP_H_PASSNO
Optional
UXP_H_PASSPI
Optional
UXP_H_PASSPI_COUNTRY
Optional
UXP_H_REPEATER
Optional
UXP_H_REPEATER_OTHER
Optional
UXP_H_SEX
Optional
UXP_H_TELNO
Optional
UXP_P_PROFESSION
Optional
UXP_P_VISA_ADDRESS1
Optional
UXP_P_VISA_ADDRESS2
Optional
UXP_P_VISA_CITY
Optional
UXP_P_VISA_EMAIL
Optional
UXP_P_VISA_PHONE
Optional
UXP_P_VISA_STATE
Optional
UXP_P_VISA_STREET
Optional
UXP_P_VISA_ZIP
Optional
RES_REMARKS2
Optional
UXP_H_LANG
Optional
UXP_H_LANG2
Optional
UXP_H_LANG3
Optional
UXP_H_LANG4
Optional
UXP_C_EXTERNALID
Optional
UXP_H_MARTIAL
Optional
UXP_H_HAIR
Optional
UXP_H_EYES
Optional
UXP_H_WEIGHT
Optional
UXP_H_HEIGHT
Optional
UXP_H_MOB_TELNO
Optional
UXP_H_STAFF_DIV
Optional
UXP_H_STAFF_POS
Optional
UXP_C_BOOKNO
Optional
UXP_C_BKDATE
Optional
UXP_C_BKPASSEX
Optional
UXP_C_BKPASSPI
Optional
UXP_C_BKPASSPI_COUNTRY
Optional
UXP_A_OTHFSTN
Optional
pbyPicture
This is the byte array of the picture file.
pnAccID
You can get this value from the poUxpRes field UXP_A_ID.
psReason
Input is optional when the absent of psNatID.
Input is required when the present of psNatID, pass this value as empty string if NO input reason needed.
psNatID
Return Values
When success CResponseXml.oObj(0) = <uxp_a_id>
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateGuestInfo", "SESSIONID", New Object() { SerializeObject(oUxpRes), <Picture Byte Array>, 1})
UpdateGuestMessage
This function adds or updates the guest message.
Input Parameters
psFunction= “UpdateGuestMessage” — below is the list of psParam or poParam.
Table 4-181 psParam
pnMsgD
Integer
Unique Message ID (0 for add new record).
Yes
pnAccID
Integer
Unique Account ID.
Yes
psSender
String(50)
Sender.
Yes
psMessage
String(1000)
Message to the guest.
Yes
peDeliveryMode
Enum
0-NoDelivery.
1-DeliverAtAdvanceQCIWizard.
2-DeliverAtGangway.
Yes
peAcknowledgement
Enum
0-NoAcknowledge.
1-UserAcknowledgeWithLog.
2-ManagerAcknowledgeWithLog.
3-DoNotContinue (8.0 only).
Yes
peType (8.0 only)
Enum
0-Standard.
1-Priority.
2-Silent.
Yes
pdStartDate (8.0 only)
Integer
Nothing=Always Active.
Yes
pdExpiry (8.0 only)
Date
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateGuestMessage", "SessionID", New Object() {12345,1234576,"Guest","Guest have parcel in front desk",2,1, 0,DateTime.SpecifyKind(#01-01-2014 3:00:00 pm#, DateTimeKind.Unspecified), DateTime.SpecifyKind(#06-01-2014 3:00:00 pm#, DateTimeKind.Unspecified))
UpdateInvoiceStatus
This function updates the Invoice batch print status in SPMS.
Input Parameters
psFunction= “UpdateInvoiceStatus” — below is the list of psParam or poParam.
Table 4-182 psParam
pnAccID
Integer
Unique Guest ID.
Yes
pbBatchPrint
Boolean
True = Print in Quick Billing Screen.
False = Do not print in Quick Billing Screen.
Yes
psEMail
String(72)
Ship Email Address.
Yes
pnAccID
pbBatchPrint
True – Print in Quick Billing Screen.
False – Do not print in Quick Billing Screen.
psEMail
e-Mail address to send the invoice to.
Return Values
CResponseXml.bSuccess = True when UpdateInvoiceStatus is successful.
CResponseXml.bSuccess = False when UpdateInvoiceStatus has failed.
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateInvoiceStatus", "SESSIONID", New Object() {12345, True, “[EMAIL ADD]”})
This function links the luggage to the guest. If the luggage is already linked to a different guest, it will overwrite it.
Input Parameters
psFunction= “UpdateRFIDEncoded” — below is the list of psParam or poParam.
Table 4-183 psParam
psSearchStr
String
Board Card or
PGID or
Yes
psRFIDUID
String(16)
Convert the value to HEX.
Yes
peSearchType
Enum
InternalID = 0 'res_acc
PGID = 1 'res_pgid
BoardCard = 2 'res_boardcc
PaxID = 3 'res_referenz
Cabin = 4 'res_cab
Default value = InternalID
Optional
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateLuggageLink", "SessionID", New Object() {12345, ”E01581A07C123B”})
UpdateMessageStatus
This function updates the message delivered status.
Input Parameters
psFunction= “UpdateMessageStatus” — below is the list of psParam or poParam.
Table 4-184 psParam
pnMsgID
Integer
SPMS Unique Message ID.
Yes
pbDelivered
Boolean
True = Set the message status to delivered.
False – Set the message status to not delivered.
Yes
pnMsgID
SPMS Unique Message ID, return from GetMessage.
pbDelivered
Return Values
CResponseXml.bSuccess = True when UpdateMessageStatus is successful.
CResponseXml.bSuccess = False when UpdateMessageStatus has failed.
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateMessageStatus", "SESSIONID", New Object() {12345, #1/1/2011#, #1/12/2011#, 0, ""})
UpdatePostingStatus
This function updates the guest posting status.
Input Parameters
psFunction= “UpdatePostingStatus” — below is the list of psParam or poParam.
Table 4-185 psParam
peSearchType
Enum
0 = Internal ID.
1 = PGID.
2 = BoardCard.
3 = Pax ID.
Yes
psSearchStr
String
Board Card or
PGID or
Yes
pnStatus
Byte
0 – Posting disable
1 - Posting enable.
2 – Posting disable but manual posting allow.
Yes
psReason
String(900)
The reason to change the status.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdatePostingStatus", "SessionID", New Object() {0,12345,0,”Credit Limit Exceeded”})
UpdatePromoterStatus
This function notifies the SPMS that the promotion has been view in the web client.
Input Parameters
psFunction= “UpdatePromoterStatus” — below is the list of psParam or poParam.
Table 4-186 psParam
pnPrdID
Integer
Promotion ID.
Yes
pnAccID
Integer
Unique Account ID.
Yes
psCode
String(20)
Promotion Code. This code is return from field ESE_ID in WSFunction, GetPromotWebClient.
Yes
Return Values
CResponseXml.bSuccess = False when update failed.
CResponseXml.bSuccess = True when update successful.
Example:
oResponse = FidelioWS("UpdatePromoterStatus", New Object() {3565, 12345, "73B"})
UpdateRFIDEncoded
This function marks the RFID as encoded successfully. The GETRFIDEncodingData, ENCODED field will return “1” when this function is called and successfully executed.
Input Parameters
Table 4-187 psParam
psRFIDUID
String(16)
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateRFIDEncoded", "SessionID", New Object() {”E01581A07C123B”})
UpdateSpecialRequest
This function adds or updates the guest special request.
Input Parameters
psFunction= “UpdateSpecialRequest” — below is the list of psParam or poParam.
Table 4-188 psParam
pnSrtD
Integer
Unique Special Request ID (0 for add new record).
Yes
pnAccID
Integer
Unique Account ID.
Yes
psCode
String(6)
Yes
psVid
String(100)
Special Request Unique External ID.
Yes
psDescription
String(1000)
Yes
pnExtID
Double
Special Request External ID.
Yes
psExtCode
String(15)
Special Request External Code.
Yes
pnQuantity
Integer
Yes
pdDeliveryDate
Date
Yes
psLocation
String(30)
Location.
Yes
psOdiID
String(6)
Delivery Division.
Yes
pdEventDate
Date
Special Request Event Date.
Yes
Return Values
CResponseXml.bSuccess = True when Update/Add successful. CResponseXML.oObj = srt_id (Unique Special Request ID).
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateSpecialRequest", "SessionID", New Object() {12345,1234576,"Code","Vid","Description", 2, "ExtCode", 1, DateTime.SpecifyKind(#01-01-2013 3:00:00 pm#, DateTimeKind.Unspecified), "Location", "GRP", DateTime.SpecifyKind(#01-01-2013 3:00:00 pm#, DateTimeKind.Unspecified))
UpdateTravelDoc
This function adds or updates the travel document.
Input Parameters
psFunction= “UpdateTravelDoc” — below is the list of psParam or poParam.
Table 4-189 psParam
pnVisID
Integer
Unique Travel Document ID (0 for add new record).
Yes
pnAccID
Integer
Unique Account ID.
Yes
psCountry
String(6)
Country.
Yes
psNumber
String(20)
Document Number.
Yes
psVisType
String(6)
Internal Document Type.
Yes
pdIssueDate
Date
Issue Date.
Yes
psIssuePlace
Date
Issue Place.
Yes
pdExpiryDate
Date
Expiry Date.
Yes
psVid
String(100)
Unique External ID, for Data Import.
Yes
pdRMUDate
Date
RMU Date.
Yes
psDocType
String(6)
Document Type.
Yes
psFirstName
String(40)
First Name.
Yes
psMiddleName
String(20)
Middle Name.
Yes
psLastName
String(40)
Last Name.
Yes
pdBirthDate
Date
Birth Date.
Yes
psRemoteID
String(30)
Remote ID
Yes
psMrz1
String(100)
MRZ 1.
Yes
psMrz2
String(100)
MRZ 2.
Yes
psMrz3
String(100)
MRZ 3.
Yes
psDocName
String(100)
Document Name.
Yes
psGUID
String(50)
GUID, for CMS.
Yes
pnEntry
Integer
Number of Allow Entry.
Yes
pdValidFrom
Date
Valid From.
Yes
pnDurationOfStay
Integer
Duration of Stay.
Yes
pbyDocImage
Byte Array
Document Image.
Yes
pbyDocPhoto
Byte Array
Document Photo.
Yes
pbyMultiPageDocImage
Byte Array
Multipage Scan document image.
Yes
psFileName
String(100)
Original File Name for file upload.
Yes
pbAssignPhotoToAccount
Boolean
True – Assign the Document Photo to Guest Photo.
Yes
Return Values
CResponseXml.bSuccess = True when Update/Add successful, CResponseXML.oObj = vis_id (Unique Document ID).
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateTravelDoc", "SessionID", New Object() {12345,1234576,"US","Bxxxx","P",DateTime.SpecifyKind(#01-01-2009#, DateTimeKind.Unspecified), "Florida", DateTime.SpecifyKind(#01-01-2019#, DateTimeKind.Unspecified), "", DateTime.SpecifyKind(#12:00:00 AM#, DateTimeKind.Unspecified), "P", "FirstName", "", "LastName", DateTime.SpecifyKind(#01-01-1960#, DateTimeKind.Unspecified), "", "", "", "", "Passport", "", 999, DateTime.SpecifyKind(#01-01-2009#, DateTimeKind.Unspecified), 30, Nothing, Nothing, Nothing, "", False)
UpdateTravelDocAdvance
This function updates the travel document with selected fields. To add a new record you must use function UpdateTravelDoc.
Input Parameters
psFunction= “UpdateTravelDocAdvance” — below is the list of psParam or poParam.
Table 4-190 psParam for XML
poVis
String/Datatable
You must create a WSF to return all fields from VIS view and the data table. One record is allowed at one time, JSON – string, XML = Datatable. Contact Oracle Support to obtain the WSF scripts.
Yes
Boolean
Yes
Table 4-191 psParam for JSON
poVis
String/Datatable
You must create a WSF to return all fields from VIS view and the data table. One record is allowed at one time, JSON – string, XML = Datatable. Please contact Oracle Support to obtain the WSF scripts.
Yes
pnVisID
Integer
Unique Travel Document ID.
Yes
Boolean
Yes
Below are the descriptions of the parameters.
poVis
This is the data table returned from the WSF (SELECT * FROM vis WHERE vis_id = <PARAMNUM1>). However, only one record is allowed at any one time. For FidelioSPMSWSXML function the poVis need to serialize first using the below function
    oMemory.Dispose()
    oMemory = Nothing
    oWriter = Nothing
  End Function
Table 4-192 xxxx
pnVisID
Integer
Yes
pnAccID
Integer
Unique Account ID.
Optional
psCountry
String(6)
Country.
Optional
psNumber
String(20)
Document Number.
Optional
psVisType
String(6)
Optional
pdIssueDate
Date
Issue Date.
Optional
psIssuePlace
Date
Issue Place.
Optional
pdExpiryDate
Date
Expiry Date.
Optional
psVid
String(100)
Optional
pdRMUDate
Date
RMU Date.
Optional
psDocType
String(6)
Document Type.
Optional
psFirstName
String(40)
First Name.
Optional
psMiddleName
String(20)
Middle Name.
Optional
psLastName
String(40)
Last Name.
Optional
pdBirthDate
Date
Birth Date.
Optional
psRemoteID
String(30)
Remote ID.
Optional
psMrz1
String(100)
MRZ 1.
Optional
psMrz2
String(100)
MRZ 2.
Optional
psMrz3
String(100)
MRZ 3.
Optional
psDocName
String(100)
Document Name.
Optional
psGUID
String(50)
GUID, for CMS.
Optional
pnEntry
Integer
Optional
pdValidFrom
Date
Valid From.
Optional
pnDurationOfStay
Integer
Duration of Stay.
Optional
pbyDocImage
Byte Array
Document Image.
Optional
pbyDocPhoto
Byte Array
Document Photo.
Optional
Byte Array
Optional
psFileName
String(100)
Optional
pnVisID
You can get this value from the WSF field vis_id.
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateTravelDocAdvance", "SESSIONID", New Object() { SerializeObject(oVis), True, <VIS_ID>})
UpdateWorkOrder
This function adds or updates the maintenance work order.
Input Parameters
psFunction= “UpdateWorkOrder” — below is the list of psParam or poParam.
Table 4-193 psParam
pnMwrID
Integer
Yes
psWorkOrder
String(20)
Work Order Number.
Yes
psPublicLocation
String(6)
Public Location, link to TYP_MWL.TYP_ART.
Yes
psCabin
String(20)
Cabin Number.
Yes
psTaskDesc
String(1000)
Task Description.
Yes
pnCompleteStatus
Integer
Completion Status. Must be 0, 25, 50, or 100 (This only applies to Insert new entry).
Yes
psLocation
String(10)
Location, link to ARE_CODE.
Yes
psPictureFileName
String(50)
Filename of the picture file uploaded.
Yes
psTask
String(6)
Task Code, link to TYP_MWT.TYP_ART, default value XXX.
Yes
psType
String(6)
Task Type, link to TYP_WOT.TYP_ART, default value WOT01.
Yes
pnXDocID
Long
Yes
psPriority
String(6)
Priority Code, link to TYP_MPI.TYP_ART.
Yes
psLocationStatus
String(6)
Location Status, link to TYP_MLS.TYP_ART.
Yes
pbyPicture
Byte Array
Picture File, only needs to send when the picture is added or update. Send nothing or empty array when no picture to update. Existing picture will not be deleted even when no picture is send.
Yes
pbPrint
Boolean
Indicate to print the work order, PAR->Maintenance->Use Work Order Printer Service must be enabled in order to print.
Yes
psComment
String(2000)
Comment Field.
Yes
psReportByCabID
String(20)
Reported By Cabin Number.
Yes
pbRejected
Boolean
Rejected Status.
Yes
psReportByUser
String(50)
Reported By Person.
Optional
pdReportedDate
Date
Reported Date.
Optional
Note: psPublicLocation, psCabin and psLocation, only one of the three variable needs to pass in.
Return Values
CResponesXml.oObj = mwr_id when bSuccess = True.
  1. pnXDocID = 0 and picture upload during update/insert means the add new picture.
  2. pnXDocID = 0 and no picture upload during update mean sremove picture.
  3. pnXDocID = 0 and no picture upload during insert means no picture.
  4. pnXDocID > 0 and picture upload during update/insert means overwrite the existing picture.
  5. pnXDocID > 0 and no picture upload during update/insert means use the existing picture.
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateWorkOrder", "SessionID", New Object() {12345,"1234576","LOC1","","Testing", 0, "", "", "XXX", "WOT01", 0, "1" , "1", Nothing, True)
UpdateWorkOrderAssignment
This function will assign person/group to the maintenance work order.
Input Parameters
psFunction= “UpdateWorkOrderAssignment” — below is the list of psParam or poParam.
Table 4-194 psParam
pnMwaID
Integer
Unique Work Order Assignment ID (0 for add new record).
Yes
pnMwrID
Integer
Yes
psAssignGroup
String(6)
Assignment Group, link to TYP_MWG.TYP_ART.
Yes
psAssignCrew
Integer
Unique Crew ID.
Yes
psRemark
String(1000)
Remarks.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateWorkOrderAssignment", "SessionID", New Object() {12345,123457, "1", 12345, "Testing")
UpdateWorkOrderImage
This function adds or updates the maintenance work order additional image.
Input Parameters
psFunction= “UpdateWorkOrderImage” — below is the list of psParam or poParam.
Table 4-195 psParam
pnMwpID
Integer
Unique Work Order Image ID (0 for add new record).
Yes
pnMwrID
Integer
Yes
psFileName
String(50)
Original filename of the image file.
Yes
psComment
String(100)
Comment on the image.
Yes
pbyImage
Byte Array
Image.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateWorkOrderImage", "SessionID", New Object() {12345,123457,"Cabin.jpg","Shower not working",<Image byte array>)
UpdateWorkOrderItem
This function adds or updates the maintenance work order item required.
Input Parameters
psFunction= “UpdateWorkOrderItem” — below is the list of psParam or poParam.
Table 4-196 psParam
pnMwiID
Integer
Unique Work Order Item ID (0 for add new record).
Yes
pnMwrID
Integer
Yes
pnItemCode
Integer
Unique Maintenance Item ID, link to MIT_ID.
Yes
pnQuantity
Integer
Quantity.
Yes
pnPrice
Double
Price.
Yes
psRemark
String(500)
Remarks.
Yes
Return Values
Example:
oResponse = goWS.FidelioSPMSWSXML("UpdateWorkOrderItem", "SessionID", New Object() {12345,123457,1,1,2.0, "Testing")
ValidateCrewPinCode
This function validates the crew PIN code to see if it matches with the existing PIN code.
Input Parameters
psFunction= “ValidateCrewPinCode” — below is the list of psParam or poParam.
Table 4-197 psParam
pnAccID
Integer
Yes
pnPinCode
Integer
New pin code.
Yes
Return Values
Example:
Version
This function returns the version number of the OHCWeb Services in use. This is used to determine a list of available services for each version as more services will be added from time to time. It is advisable to check the version number of the OHCWeb Services to ensure the client application is backward compatible and to determine the list of services available before proceeding.
Input Parameters
psFunction= “Version”. There is no input parameter and sends NULL to psParam or poParam.
psParam
None.
Return Values
CResponseXml .oObj = Version number of the web service in use.
Example:
oResponse = goWS.FidelioSPMSWSXML("Version", "SESSIONID", Nothing)
WSFunction
This function retrieves information from SPMS by calling a user defined function. You must read a separate document on the available function as they differ from customer to customer.
Input Parameters
psFunction= “WsFunction” — below is the list of psParam or poParam.
Table 4-198 psParam
poParam
Array
Array of parameter, this parameter different from function to function.
Optional
poParam
The first element is the function name, the rest depends on one function to another.
If the parameter is date field, you must pass in a date string in YYYYMMDDHHMMSS format.
Return Values
CResponseXml.bSuccess = False when input values are invalid or no record found.
CResponseXml.bSuccess = True and CResponseXML.oTables = Array of ADO.NET data table when input values are valid.
Example:
oResponse = goWS.FidelioSPMSWSXML("WSFunction", "SESSIONID", New Object() {"GetCabin", "05002"})
