5 Setting Up SPMS Desktop Application Clients
The SPMS Application Clients can be installed on any machines that have the full Oracle Client installed, including the Oracle Data Access Components (ODAC) component.
Prerequisites
  1. Ensure you uninstall all the components older than SPMS 23.2. However, if you choose not to uninstall, you may follow the steps depicted in section Alternate option to upgrade existing SPMS Desktop Application Clients version 23.1.0 or later.
  2. Ensure that the Microsoft .NET Framework 2 and 3.5 and 4.8 are enabled in Window Features before installing Oracle Full Client and CruisePropertyManagementDesktopApps_23.2.exe file.
  3. Oracle 19c Database client with ODAC is installed on the target machine. See topic Oracle Database Client and ODAC Installation.
  4. SAP Crystal Report runtime engine for .NET Framework (32-bits) version 13.0.33 is installed on the target machine. See How to Install/ Upgrade Crystal Reports runtime engine for .NET Framework (32-bit) for further information.
  5. SPMS 23.2 Installer is downloaded and available in the target machine. See topic SPMS Installation File for download instructions.
  6. SPMS 23.2 Package is downloaded and available in the target machine. See topic SPMS Package File for download instructions.
  7. Ensure that the Windows Regional and Language Settings on the target machine is configured to US/UK and the language setting is set to English. This important to ensure that you get the expected SPMS functionality.
