Uninstalling SPMS Application Client
The following section describes the steps to remove the SPMS programs. If you want to completely remove SPMS from your servers, you must manually delete the SPMS database components from the database after uninstalling the application.
  1. Open the Control Panel and select Programs, Programs and Features.
  2. Select Oracle Hospitality Cruise Property Management Desktop Apps from the program listed.
  3. Click Uninstall on the menu bar.
  4. Follow the instructions on the screen.
