Upgrading Oracle Hospitality Cruise Property Management
If you already have a previous installation, follow these steps to upgrade the program. You would need an Administrative privilege to perform this task.
Locate the
installer.propertiesfile in the previous installation folder. -
Copy the
installer.propertiesfile into the folder where latest CruisePropertyManagement_23.2.x installer is located. This is to ensure the previous settings like database connections, installation paths, and other configurations are retained.Note:
When upgrading to SPMS 23.2.2 or later, all the configurations are auto-filled provided- A previous version of SPMS is already installed.
- The
installer.propertiesfile is in the same folder as the SPMS 23.2.2 Installer. - You only need to re-enter the Database Keystore Path, SSL Keystore Password, SSL Keystore Alias on condition that the installer.properties file is in the same folder as SPMS 23.2.2 Installer. Otherwise, all the configurations has to be entered manually.
Start the installation program by right-clicking the CruisePropertyManagement_23.2.x.exe and select Run as Administrator. The data of previous setup will pre-populate when the condition above is met.
Click Upgrade to begin and follow the instructions on screen.
At the end of the installation, the previously installed version is replaced with the latest features, fixes, and updates included in this release.
Downgrade Prevention:
Installing a lower version over SPMS 23.2.2 is not permissible once the program is upgraded to SPMS 23.2.2 or later. The system will prompt a notification to terminate the installation.
