Modifying / Uninstalling Oracle Hospitality Cruise Property Management
Any modification or uninstallation are done through Windows Control Panel in a Maintenance mode. This would allow user to select the options to perform like add features, remove, or uninstall the product.
Start the installation program by right-clicking the CruisePropertyManagement_23.2.x.exe and select Run as Administrator.
If you have already installed the application, the Setup would start in Maintenance mode. Choose one of the options presented.
Add Features: InstallAnywhere will guide you through adding features to the installed set. The feature will be disabled if it is already installed.
Remove Features: InstallAnywhere will guide you through removing features of the installed product. User can uncheck the product features (WebApp / API /Mustering) that need to uninstall. Checked features will remain installed.
Uninstall Product: InstallAnywhere will remove all the features that were installed during product installation. Files, folders and windows services will also be removed.
Click Next/Uninstall and follow the wizard instructions.
