Batch Check-In/Out
The Batch Check-In/Out function allows you to send triggers by batch to enable/disable the Telephone, ITV, or Dining System.
Figure 9-31 Batch Check In/Out Window
Table 9-12 Batch Check-In/Out Filters
| Field Name | Description |
Include All Check In Guest/Crew |
Sends triggers for all check-in/out for all guest. |
Include Check In Guest Only |
Sends triggers for check in/out guest only. |
Include Check In Crew Only |
Sends triggers for check in/out crew only. |
Include Guest/Crew with below disembarkation date |
Sends triggers for check/out guest/crew with specified disembarkation date. |
Include Guest Only with below disembarkation date |
Sends triggers for check/out guest with specified disembarkation date. |
Include Crew Only with below disembarkation date |
Sends triggers for check/out crew with specified disembarkation date. |
From the Stateroom Setup menu, select Batch Check-In/Out.
Select from the available filter and select a Date.
Select the type of batch to execute.
Click Close to exit.
