Adding, Editing and Copying a Stateroom
  1. From the Stateroom Setup menu, select Staterooms from the drop-down list.
  2. In the Cabin Setup window, click New.
  3. In the New Cabin form, enter the Cabin number, No of Berth, and Berth Setup and select the Deck from the drop-down list.
  4. In the Feature section, select the Type, Category, Features, Classification and Common Access Area.
  5. Select the With Special Need Feature if the cabin is equipped with special needs amenities.
  6. Select the HK Section, Life Boat, Muster Station, Location and Vertical Zone in the Assignments section.
  7. In the Crew Assignment section, select the Keeper, Assistant Keeper, Head Waiter, Waiter and Assistant Waiter.
  8. Enter the Phone extension of the cabin in the Phone Numbers section.
  9. If the cabin is linked to another cabin and has a common door, check the cabin number in the Link Cabin section.
  10. Click OK to save the cabin number.
  11. Repeat the same for the remaining cabin or use Copy Cabin to copy cabin of the same category and features.
Editing a Cabin
  1. Select the Cabin number from the Cabin Setup window.
  2. Click Edit.
  3. Click OK to save the changes.
Copying a Cabin Code
The Copy Cabin function enables you to copy the cabin of the same type, and category and has the same features.
  1. In the Cabin Setup window, select the cabin number to copy.
  2. In the Cabin Setup form, enter the new cabin number and the telephone number.
  3. Click Add to List.
  4. Continue to add the cabin number until you complete the list.
  5. Click OK to save.
